I have 58mm lenses and a number of 55mm filters, will I get vignetting if I use an adapter 58 - 55.
mickbate Hatchling 2 posts Joined Jul 2008 Location: Greenville, SC More info | Jul 16, 2008 08:21 | #1 I have 58mm lenses and a number of 55mm filters, will I get vignetting if I use an adapter 58 - 55. Mick
msowsun "approx 8mm" More info | Jul 16, 2008 11:01 | #2 Probably not if you are using a crop camera. But it depends on the camera and lens. What camera and lens do you have? Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
Jul 16, 2008 11:38 | #3 Thanks, I will. Mick
msowsun "approx 8mm" More info | Jul 16, 2008 11:50 | #4 If you use a regular EF lens there would be less chance of vignetting because only part of the image circle is used on a cropped sensor body. Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
JWright Planes, trains and ham radio... 18,399 posts Likes: 35 Joined Dec 2004 More info | A good rule of thumb when using stepping rings is "go up but not down." In other words, you can use a 58mm filter on a lens with a 55mm thread, but should not use a 55mm filter on a 58mm thread lens. John
| Latest registered member was a spammer, and banned as such! 2746 guests, 160 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
