Thread started 16 Jul 2008 (Wednesday) 09:39
I hate the harshness of direct flash but have to use it...
Village_Idiot
GREATEST POTN MEMBER EVER
Jul 16, 2008 09:39 |  #1
OK. What do you do when you want a good image but the only way you can shoot is with a direct flash?
Like when I was shooting a friend's band at the brass monkey in Baltimore. Is any one that reads this has ever been there by some off chance, they know it's a bad location. Interior lighting sucks. The ceiling, walls, and floors are black.
I shot with a 580EX II clamped to what passes for stage lights infront of the stage and used a stofen diffuser to attempt to diffuse the light a bit and still got a ton of harsh shadows that weren't very flattering to the photo.
I'm going to be shooting a bartending competition at TGI Friday's and I'm probably going to be in the same situation. I'm going to go check the place out again to see what it's like, but there's no room for umbrellas or softboxes. What do you do to get better photos when using just a flash without any modifiers?
My village called. I was told that they missed me.
Speedotron users, untie!
Titus213
Jul 16, 2008 09:41 |  #2
Try a bracket? It at least tends to push the shadows down and directly behind the subject.
Dave
Perspiring photographer.
whiskaz
Jul 16, 2008 09:59 |  #3
Sounds like he's already off camera with his flash... just without anything to soften it (so it wasn't really direct flash, just bare). Post some examples maybe? Placement is going to be key, of course. If you were hitting them straight on, probably not your best bet. Find some way to clamp it high and at an angle (if at all possible).
Joe McNally/Scott Kelby... Just a couple of gels attached to the front of that sb.
and...
Jeremy | Gear List | EyeDigress - A Photoblog (external link) | blinkphotography.net (external link)
"This aggression will not stand, man."
TheHoff
Don't Hassle....
Jul 16, 2008 10:10 |  #4
Try and use the flash more like fill rather than the light source. Crank up the ISO, wide open lens, etc, and see if you can tone down the output the flash has to put out to keep your shutter speed up.
••Vancouver Wedding Photographer  (external link)••| [gear list] | Latest blog: 5 steps to stopping image loss (external link)
Double ­ Negative
*sniffles*
Jul 16, 2008 10:33 |  #5
LumiQuest Softbox would help to soften the light. Doesn't sound like it's a venue with good ceilings to bounce off of...
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Dermit
Joined Nov 2005
Jul 16, 2008 10:40 |  #6
TheHoff wrote in post #5921438 (external link)
I shoot a lot of theater and here's my take on it... if the theater/venue is any good at all they have lighting crews who know what they are doing. So I depend 100% on using their lighting and NO flash at all. I mean aren't you there to try and capture the whole expereince/look of the performance? So why would you want to add something that is not a part of it by using flash? Get a fast lens, or two. Get a camera that does well at high ISO (1600, 3200) and do your best to get what you can. And if their lighting is bad, then so be it, I still do not think using flash in these situations (live performance) is a good idea.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
Big ­ Mike
Jul 16, 2008 11:03 |  #7
What about using a 2nd or 3rd flash to simulate ambient light?...which could be fill to your main light.
The last wedding I shot, we placed a flash (on a stand) on a mezzanine above the reception and put a Fong Dong on it. We then shot with on-camera flash and PWs to trigger the overhead flash. Depending on the venue, you could aim the flashes at walls or the ceiling etc.
Instructor at The Canadian Photography Learning Centre (external link).
Blog (external link)
Wilt
Jul 16, 2008 11:09 |  #8
Village_Idiot wrote in post #5921276 (external link)
OK. What do you do when you want a good image but the only way you can shoot is with a direct flash?...I shot with a 580EX II clamped to what passes for stage lights infront of the stage and used a stofen diffuser to attempt to diffuse the light a bit and still got a ton of harsh shadows that weren't very flattering to the photo.
First mistake...thinking a Stoffen would do any good when the ceiling is black! That dang thing is NO LARGER than the native flash lens, so there is no way it will be softer light! LumiQuest Softbox would help to soften the light, as suggested in another post, or even a very small softbox like a Wescott Micro Apollo or Photoflex XTC...all of those products increase the apparent area of the light source, which is what soft light is all about...SIZE matters!
As Dermit does, I rely upon the stage lighting only, the high ISO low noise of Canons for extreme ISO, along with noise reduction postprocessing
Village_Idiot
Jul 16, 2008 11:30 |  #9
No stage lighting with that.
I was thinking about using one or two of my AB's mounted up high, but I'm thinking that there's going to be a ton of hard shadows from the bottles and all the other little things at the bar. What about one Bee with a bare bulb and no reflector to flood the area and a 2nd one with a bit more power as a main light.
roman_t
Jul 16, 2008 15:01 |  #10
is there a chance to use constant lights? once i asked club manager to use dancefloor lights for shooting and it worked.
Village_Idiot
Jul 16, 2008 15:44 |  #11
They're not very bright. It's a chain restaurant like Out Back, Chili's, Apple Bee's, Ruby Tuesday, etc... The lighting inside is meant for dining and not photography, that's the tricky part.
I could shoot ISO 3200 @ f/2.8 with IS, but I'd rather use the rest of my tools and get quality shots instead of settled for shots. I'll have 2 AB B800's, a vagabond II, 2 Viv 285HV's, and a Canon 580EX II in my kit by then. I could even go all out and secure the B800's to the ceiling, maybe even purchase a 3rd, and just light up the whole bar.
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Jul 16, 2008 17:26 |  #12
Don't automatically give up on bouncing off the black ceiling or walls. I was surprised that I could bounce off a low black stippled ceiling. Of course, if the ceiling or walls are are 40 feet away, forget it. Don't use any modifier if you are bouncing-you need every ounce [new measurement for light ;)] of light you can get. Keep your iso high and your flash gelled to match the ambient to use the ambient to your advantage. A bracket like Dave suggests would also be good. Here's some where I mixed direct gelled flash with the spotlight. My flash shadow is obvious, but still I think when taken as a whole the images are acceptable. I think the horizontal one is bounced, and the rest direct. I'm sure the bounce wasn't working to my satisfaction so most are direct. Still, however, don't rule out the bounce without a few test shots.
http://brsphoto.zenfol​io.com/p508490206 (external link)
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
Wilt
Jul 16, 2008 17:33 |  #13
Bearmann wrote in post #5924044 (external link)
Which of the photos in the link are bounce...I see a good number with side shadow, which indicates direct, not indirect source
(edit) just noticed 'horizontal' mention...but that photo shows pretty clearly delineated shadows on the back wall
DDCSD
GIVIN' GOOD KARMA
Jul 16, 2008 17:46 |  #14
You could try wearing a white t-shirt and bounce the flash off of yourself.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
thebishopp
Jul 16, 2008 18:04 |  #15
In addition I would check out this thread on nightclub photos:
https://photography-on-the.net/forum/showthre​ad.php?t=415099
It's a LONG one but will show you examples of low light in building shots (nightclubs which would in some cases be similar to tgif) as well as examples of settings and advice (slow/draging shutters - ISO settings, difussers - one fellow particularly likes the gary fongs, etc.).
"Please use the comments to demonstrate your own ignorance, unfamiliarity with empirical data, ability to repeat discredited memes, and lack of respect for scientific knowledge. Also, be sure to create straw men and argue against things I have neither said nor even implied. Any irrelevancies you can mention will also be appreciated. Lastly, kindly forgo all civility in your discourse . . . you are, after all, anonymous." My Zen (external link)
2,531 views & 0 likes for this thread, 17 members have posted to it.
2737 guests, 164 members online
