Thread started 12 Jan 2005 (Wednesday) 08:47
How often should a UV filter be replaced
Longwatcher
obsolete as of this post
Joined Sep 2002
Jan 12, 2005 08:47 |  #1
I was reading another post about lens cleaning and that usually like me they keep UV filters over the lens. Part of the reason is so I don't have to clean my front elements of my lenses, the other is added protection in case of stupidity or accidents.
But the thought came to me... How often should I plan on replacing my UV filters?
To date I haven't replaced any, but one is starting to look like it may start becoming unacceptable. I haven't noticed any loss of quality, but have noted a couple of minor scratches near the edges, it is also the one that has taken a touch of damage on the outer ring, making it a bit harder to screw on another filter (polarizer or IR). I suspect when the tripod head decided to let it down not so gently and it banged against one of the legs to be the culprit. Did I mention I am rough on my equipment?
Just a thought. Anybody else have any thoughts on this topic?
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
Jon
Joined Jun 2004
Jan 12, 2005 09:48 |  #2
I think you've answered your own question. If the filter's starting to look shabby, it's probably ready for retirement.
Jon
Cocker Spaniels
robertwgross
Joined Nov 2002
Jan 12, 2005 09:56 as a reply to  @ Jon's post |  #3
I'll use a filter until either the screw threads get damaged or until the outer ring looks damaged. I've never scratched the glass.
---Bob Gross---
Longwatcher
Joined Sep 2002
Jan 12, 2005 12:41 as a reply to  @ robertwgross's post |  #4
---Bob Gross---
Probably from too many times going through bushes, rivers or maybe sand in the camera bag. That's what I get for taking pictures on location and why I have the UV filters on. Shore lines are the most dangerous places, darn waves try to get me. Did get my model once - no damage.
And the questions wasn't should that one be replaced, it was more of a budgeting question. How long should I expect them to last?
recognize the complexity of the question, just a thought that came to my mind.
Jon
Joined Jun 2004
Jan 12, 2005 12:51 |  #5
The filter on your primary lens, on the camera and out in the open all the time while you dune-buggy over beaches and crawl through undergrowth - you'd be doing well to get a year or two out of it. The filter on your TS-24 which gets pulled out of storage once or twice a year in the studio - forever. Really, there's no expected life with a filter - there aren't any moving parts to go out of whack; it's just a question of how much abuse it gets while it protects your lens. If you're worried about its condition, it's time.
Jon
Cocker Spaniels
12345Michael54321
Joined Jun 2003
Jan 12, 2005 13:48 |  #6
Just thought I'd mention that you really shouldn't screw a polarizer onto the UV filter, if you can avoid it.
Okay, even if we allow that a single layer of glass (the UV filter) has no significant image degradation effect, stacking a UV filter and a polarizer leaves us with 3 layers of glass (since a polarizer contains two glass layers). And at some point, you do begin to degrade the image by sticking multiple layers of glass in front of the lens.
As for your primary question - when to replace? - the other answers pretty much cover it. Replace your UV filter when it starts showing signs of wear (either to the glass or the ring) that impair its fit or function to an objectionable degree. With a lightly and gently used filter, this can mean replacing it every other century. With a filter that sees a lot of hard use under extreme conditions, it can mean replacing it at the end of every day's shoot.
Cadwell
Joined Jan 2004
Jan 12, 2005 14:06 as a reply to  @ 12345Michael54321's post |  #7
If the damage to the filter is imparing it's function (wrecked thread) or its scratched enough to show on the image replace it. Otherwise don't bother. Scratches that don't show up on the final image don't exist (for all practical purpose).
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 12, 2005 15:46 |  #8
When they get all scratched up like a good Bee gees album should be...
CDS' HOT LINKS
Danny ­ Boy
Joined Jul 2004
Jan 12, 2005 16:57 as a reply to  @ CyberDyneSystems's post |  #9
There's a good Bee Gee's album?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 12, 2005 22:58 |  #10
.... only when there scratched up....
[rimshot}
//thanks for being my straight man.... ;)
CDS' HOT LINKS
3,625 views & 0 likes for this thread, 7 members have posted to it.
1224 guests, 126 members online
