Thread started 16 Jul 2008 (Wednesday) 12:55
please help me with color management basics!
jane ­ fritz
1 post
Jul 16, 2008 12:55 |  #1
Hello. I recently purchased an NEC 2490wuxi LCD monitor and an HP Desktop running 64-bit Vista and an NVidia GeForce 8500 GT graphics card for my home photography business. I am relatively new to color management, since I have not been a photographer for very long, and I need some guidance on how to get started, basically from the very beginning. I don't even have Photoshop installed on this new machine yet, so there are no issues with Adobe Gamma running, but I just really don't know where to begin.
I ordered the Spyder3Elite last week, and I need a little help understanding how the process works.
1) Before calibrating the monitor, what settings do I need to change in Windows? I see that Vista has a new, and very confusing color management system - WCS. There are a ridiculous number of menus with various choices, and i've heard that some things need to be set so that Vista doesn't automatically override the new profile you create with the calibration software at startup. Also, do I need to change anything in the NVidia settings? I have read that I am supposed to disable "color correction" under NVidia.
2) Am I supposed to keep the actual monitor settings at the factory defaults, or am I supposed to make changes before I run the calibration? Specifically, am I supposed to change the color mode from Native to sRGB (6500), change the luminosity to around 120 cd/m2 or so, and make sure the gamma is set at 2.2? What about contrast, etc? Exactly what should I change on the monitor before calibrating?
3) Do I even need to calibrate this monitor, since I could just set the color to SRGB, set the gamma to 2.2, and set the luminosity to 120 (recommended settings for most photographers doing color work)?
I know that I have WAY too many questions, but any and all help would be greatly appreciated. I am very new to this, but since I have made such a big investment in all of this hardware, I want to make sure that i'm doing everything correctly, right from the start. I don't want to have missed a step, or have something else in the background (i.e. Vista, NVidia, etc) to interfering with what I do.
Thank you so much! :)
mangaloreaviators
Jul 16, 2008 13:46 |  #2
Welcome to POTN Jane,
Please do a search and you will get everything that you need.
Colour problems
All the best
WaltA
Gallery: 10 photos
Joined Feb 2006
Jul 16, 2008 15:35 |  #3
Also, check out this skickey in the PostProcessing forum
https://photography-on-the.net/forum/showthre​ad.php?t=296149
Walt
400D, 5D, 7D and a bag of stuff
mangaloreaviators
Jul 17, 2008 13:18 |  #4
WaltA wrote in post #5923337 (external link)
It is the same one that I also refered to :)
poloman
Jul 18, 2008 09:27 |  #5
Make sure you turn off Adobe Gamma Loader.
You need to turn off all the stuff that nvidia loads at start up. Don't worry, it won't hurt anything to do so. I have an nvidia card in my desk top. Otherwise Vista will rerun this stuff sometime after boot up and mess up your calibration. You can test for this problem by running the Spyder setup in startup just before you run your editing program. If there is a color change, you need to address this problem.
You should set your monitor for sRGB and leave all other settings alone.
When you calibrate, let the software do it all. Don't try to adjust any of it yourself.
Spend the time it takes to read the links the others have placed for you above. With a little work, you should be able to get your prints to match your screen.
Wise of you to get calibrated. Now you can embark on the nuances of editing.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
615 views & 0 likes for this thread, 4 members have posted to it.
2588 guests, 164 members online
