Thread started 13 Jan 2005 (Thursday) 08:58
Aperture values and F Stops
quickben
Fairy Gapped
Gallery: 17 photos
Joined Mar 2004
Jan 13, 2005 08:58 |  #1
I'm confused.
Everyone talks about f stops in apertures and shutter speeds, but I don't know what they mean. My 50 1.4 on my 10D has a range, in AV mode, of : 1.4, 1.6, 1.8, 2.0, 2.2, 2.5, 2.8, 3.2, 3.5, 4.0, etc...
What I can't my head around is when people talk about f2.8 being ONE stop faster than f4.0 ? Surely it's THREE i.e 2.8 - 3.2 - 3.5 - 4.0 ?
Please enlighten me.
Gary.
Fighting the war against the unnecessary use of the Book Worthy Smiley
My name is Gary, not Ben.
6D 24-70/2.8VC 85/1.8
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Jan 13, 2005 09:20 |  #2
One stop is either a halving or doubling of the amount of light which hits the sensor/film. The values you list are showing 1/3-stop at a time, which is one of the choices with the 10D, the other being 1/2-stop.
The full stops are: 2.8, 4, 5.6, 8, 11, 16, 22, 32, 45
Given the same shutter speed, twice as much light hits the sensor at f/2.8 than at f/4. f/4 gives twice as much light as f/5.6, which is twice as much light as f/8.
You just happen to have the camera set at 1/3 stop increments, that's all.
You'll also find that your shutter speeds are showing 3 steps between full stops. For instance, 1/30 second is twice as much light as 1/60, right? But I bet your camera shows 3 values between 1/30 and 1/60.
Edit: Oops: There would be 2 stops between 1/30 and 1/60, or 3 stops from 1/30 to 1/60. Luckily Bob didn't catch me....
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
quickben
Fairy Gapped
Gallery: 17 photos
Joined Mar 2004
Jan 13, 2005 10:08 as a reply to  @ Scottes's post |  #3
Thanks alot, Scottes.
I had an idea, just wanted to clarify it. Although I didn't know that one stop either way can halve or double the light. I still can't use the camera in fully manual mode. I'm scared of it :-) How do you gauge which settings to use ?
Cheers.
Gary.
Jon
Joined Jun 2004
Jan 13, 2005 10:22 |  #4
Figure how much depth of field (DoF) you want in the picture (larger apertures give less DoF), and how fast a shutter speed you need to stop subject/camera motion, then try to find a compromise. If you can't reach a reasonable compromise, change the ISO. Or just bracket like hell.
Jon
Cocker Spaniels
Scottes
Joined Nov 2003
Jan 13, 2005 10:30 as a reply to  @ quickben's post |  #5
I shoot a lot.
I had a really big answer written and realized that this is a very tough subject. I can point you to 2 things, a book titled "Understanding Exposure" by Bryan Peterson, and an article called "Understanding Exposure" on the Luminous Landscapes web site: http://www.luminous-landscape.com …/understandexpo​sure.shtml (external link)
Either will get you started abit.
robertwgross
Joined Nov 2002
Jan 13, 2005 10:41 as a reply to  @ quickben's post |  #6
If you ask a beginner, fresh out of photography class, what the purpose is in Aperture, the beginner will say that it balances shutter speed and ISO in the exposure calculation. That is true.
However, if you ask the experienced photographer the same question, you will get a slightly different answer. Balancing with shutter and ISO is true, but Aperture controls the depth of field, and some consider it to be a bigger purpose than exposure.
---Bob Gross---
quickben
Fairy Gapped
Gallery: 17 photos
Joined Mar 2004
Jan 13, 2005 11:19 |  #7
Thanks for the advice, guys. That SUNNY 16 theory looks good, but I'll need a little time to be able to put into practice.
I have one question, however. Is it really any better shooting fully manual ?
Is using either, Aperture priority, or Shutter priority just as accurate (if not more) and quicker ?
In that Luminous-Landscape article, his D30 metered the scene pretty-much the way he would have done it himself.
Gary.
Scottes
Joined Nov 2003
Jan 13, 2005 11:46 |  #8
Unless I'm using flash I shoot 99.9% of the time in either Av or Tv, mostly Av. Either of these modes, combined with Exposure Compensation, gives as much control as Manual while retaining much of the pleasure and ease of use of fully automatic.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 13, 2005 11:46 |  #9
Just to make things more confusing.. aperture value and actual f/stop are not the same..... :mrgreen: :rolleyes:
CDS' HOT LINKS
Longwatcher
obsolete as of this post
Joined Sep 2002
Jan 13, 2005 12:41 as a reply to  @ CyberDyneSystems's post |  #10
My favorite trick is:
When in doubt set Camera on "P" take two pictures, ignore the first*, read the settings on the second, set to manual with the read settings and then adjust as needed for desired depth of field or problems with certain areas. one dial click on shutter, one on aperture, repeat as needed (Make sure custom settings have not been changed to make these different values). Change ISO from 100 only when needed.
Please note: I am more and more often getting it right from experience on the first try anyway. 5 years of digital and 40,000+ pictures later will tend to do that.
*=I never trust the first picture my D60 or 10D take. Not yet confident in 1DsMkII, but looking better.
Just my opinion and experience. Feel free to ignore.
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
PacAce
Joined Feb 2003
Jan 13, 2005 14:07 as a reply to  @ Longwatcher's post |  #11
Tim, instead of switching to P and then getting the shutter and aperture settings, why wouldn't you just use the meter in the viewfinder to see what the camera would recommend for exposure (this is while you're in manual mode)? All that has to be done is set the digital needle to the center of the meter to get the "proper" exposure. You can then adjust the settings from there.
...Leo
robertwgross
Joined Nov 2002
Jan 13, 2005 15:54 as a reply to  @ Scottes's post |  #12
Completely wrong. I don't know where you are going with this.
The difference between 1/30 and 1/60 is one stop, pure and simple. Or, if you want to use 1/3-stop steps, then the same difference is three steps.
---Bob Gross---
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jan 13, 2005 16:06 |  #13
If you read the paragraph ahead of that one.. you can sort of make out what he meant..
He meant three "steps" as in adjustment steps between 1/30 and 1/60... just above Scottes says that 1/30 to 1/60 is a full "stop"
The old.. "do what he means.. not what he types". Good thing no one has any trouble understanding what I'm typing ;)
CDS' HOT LINKS
Scottes
Joined Nov 2003
Jan 13, 2005 16:57 as a reply to  @ robertwgross's post |  #14
Darnit! I knew you'd get me anyway!
My original sentence said "3 values between..." and I managed to screw up the correction by saying "stops" when I shoulda said "values" again. Grrrr.
Whatever. It's a good thing you're here to keep us accurate.
Scottes
Joined Nov 2003
Jan 13, 2005 16:59 as a reply to  @ CyberDyneSystems's post |  #15
Hold on and get out the record book! Apparently you typed a full message without a single spelling mistake!
Swapping out your keyboard for a Sanskrit one is actually helping... My plans always backfire. :-)
6,443 views & 0 likes for this thread, 12 members have posted to it.
1224 guests, 126 members online
