i have a canon xt with a sync speed of 1/200. if i try to use a flash with a better beamer with a shutter speed over 1/200 will that not work? i was hopeing to be able to shoot at around 1/400 due to handheld. what are my options?
mrbass111 Senior Member 929 posts Joined Dec 2007 Location: palm bay florida More info | Jul 18, 2008 08:24 | #1 i have a canon xt with a sync speed of 1/200. if i try to use a flash with a better beamer with a shutter speed over 1/200 will that not work? i was hopeing to be able to shoot at around 1/400 due to handheld. what are my options? canon 40d/ canon 100-400 L IS 5.6
Jul 18, 2008 08:27 | #2 Nope. it's not about flash power. it's about the shutter itself and how it mechanically works at faster speeds. At faster speeds part of the shutter is still in front of the sensor for the duration of the flash itself. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Gatorboy Goldmember 2,483 posts Likes: 2 Joined May 2005 Location: Bel Air, MD More info | Jul 18, 2008 08:32 | #3 Why do you need a faster shutter speed? When using flash, you use it to freeze action, not shutter speed. Dave Hoffmann
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jul 18, 2008 08:55 | #4 mrbass111 wrote in post #5935115 i have a canon xt with a sync speed of 1/200. if i try to use a flash with a better beamer with a shutter speed over 1/200 will that not work? i was hopeing to be able to shoot at around 1/400 due to handheld. what are my options? What kind of flash do you have? Does it support High Speed Sync? If so, there's no reason you can't shoot at 1/200, 1/400 or whatever shutter speed you want to use as long as HSS is turned on if the shutter speed is faster than 1/200. ...Leo
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jul 18, 2008 08:58 | #5 Gatorboy wrote in post #5935149 Why do you need a faster shutter speed? When using flash, you use it to freeze action, not shutter speed. Usually that doesn't apply when using the flash in broad daylight or when the ambient light is contributing significantly to the exposure. ...Leo
Jul 18, 2008 09:31 | #6 Gatorboy wrote in post #5935149 Why do you need a faster shutter speed? When using flash, you use it to freeze action, not shutter speed. i shoot handheld. and need the higher shutter speed to eliminate hand shake. canon 40d/ canon 100-400 L IS 5.6
Jul 18, 2008 09:39 | #7 mrbass111 wrote in post #5935472 i shoot handheld. and need the higher shutter speed to eliminate hand shake. IF your flash is the main light source contributing to the exposure then the duration of the flash becomes the effective shutter speed...which is extremely fast so no worries about hand-held steadyness at lower shutters. Think about this extreme example. You are in a cave, no ambient light. You set the shutter for 30 seconds. You use a flash. You take a picture. The flash goes off. The shutter is open. You take the camera by the strap and swing it around in circles while the shutter is open. The shutter closes. You look at the image and it looks fine, no motion blur. This is because the flash provided all the light and the rest of the time the shutter was open there was no light to expose the sensor. This same thing is true in a much less dramatic sense when you take any image with a dependance on flash for the main exposing light source. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Jul 18, 2008 10:43 | #8 hey ron, thanks alot. that made sense to me. i guess ill just have to get out in the field and see what happens. canon 40d/ canon 100-400 L IS 5.6
JeffreyG "my bits and pieces are all hard" More info | Jul 18, 2008 10:55 | #9 PacAce wrote in post #5935295 What kind of flash do you have? Does it support High Speed Sync? If so, there's no reason you can't shoot at 1/200, 1/400 or whatever shutter speed you want to use as long as HSS is turned on if the shutter speed is faster than 1/200. Combining HSS with a better beamer is kind of going two directions at once. The beamer modestly increases flash range while the HSS drastically reduces it. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jul 18, 2008 11:51 | #10 JeffreyG wrote in post #5935959 Combining HSS with a better beamer is kind of going two directions at once. The beamer modestly increases flash range while the HSS drastically reduces it. I second trying to eliminate ambient light from the image first to see if you can freeze everything with the flash. I use the better beamer with the camera set to HSS mode all the time when shooting birds. I don't see where there's a conflict with using the BB with the flash set to HSS mode. The purpose of the BB in my case is to concentrate the light to better match the focal lengths of the telephoto lenses I'm using. ...Leo
Jul 18, 2008 11:54 | #11 PacAce wrote in post #5936284 I use the better beamer with the camera set to HSS mode all the time when shooting birds. I don't see where there's a conflict with using the BB with the flash set to HSS mode. The purpose of the BB in my case is to concentrate the light to better match the focal lengths of the telephoto lenses I'm using. I agree that BB will help when used in conjunction with HSS, but I think the help will be slight. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jul 18, 2008 12:05 | #12 Dermit wrote in post #5936301 I agree that BB will help when used in conjunction with HSS, but I think the help will be slight. I think you're missing the point about the BB and HSS. Sometimes, you have no choice but to use fast shutter speeds. Have you ever tried shooting at f/2.8 or f/4 in broad daylight in Av mode? ...Leo
Jul 18, 2008 12:18 | #13 PacAce wrote in post #5936355 I think you're missing the point about the BB and HSS. Sometimes, you have no choice but to use fast shutter speeds. Have you ever tried shooting at f/2.8 or f/4 in broad daylight in Av mode? ![]() No, actually I totally understand about it. About 75% of my paid shoots are outdoor on location and I ALWAYS use flash. And if you note where I shoot (Arizona) the sun is always extreme. So I absolutely know about and constantly use HSS. My flashes are set to HSS most of the time. My shutter speeds are almost always faster than the sync. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
Jul 18, 2008 12:33 | #14 PacAce wrote in post #5936284 I use the better beamer with the camera set to HSS mode all the time when shooting birds. I don't see where there's a conflict with using the BB with the flash set to HSS mode. The purpose of the BB in my case is to concentrate the light to better match the focal lengths of the telephoto lenses I'm using. heres what i found on my flash that i think is the same as hss. canon 40d/ canon 100-400 L IS 5.6
Jul 18, 2008 12:59 | #15 mrbass111 wrote in post #5936520 heres what i found on my flash that i think is the same as hss. its sounds greek to me but this flashes FP flash. does this sound like the HSS function? It sounds like it could be. Just try it. Set the camera in manual mode to 1/400 at f/8 indoors/dim light, flip the flash on set to this FP and take a shot of something, oh, 10 feet away. If it does not work you will see a portion of the image black, like the bottom 1/4 of the image. if it does work the image should be OK. 5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
| Latest registered member was a spammer, and banned as such! 2773 guests, 152 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
