Thread started 18 Jul 2008 (Friday) 11:17
Setting up two
No786
Jul 18, 2008 11:17 |  #1
Hi,
I have recently bought the Sigma 530 super and two light stands. Now I am wanting to buy more lights for the stands. What are my options? I know my sigma acts as a master. So I was thinking about using it on the camera and having two other on the stands. When I use the sigma off camera I have to use the cameras pop-up-flash and it gets quite annoying when it does the pre-flash and triggers the Sigma. I do not really want to spend that much money so I was thinking of a couple of sunpak/vivitar's with a slave receiver? Would this work and also what type of slave would I need? Would buying a Cactus transmitter and 3 receivers make more sense than slaving the two new flash's to the Sigma?
What do you recommend?
Sorry I'm new to this!
_no
No786
Jul 18, 2008 19:06 |  #2
Anyone?
doidinho
Jul 18, 2008 19:35 as a reply to  @ No786's post |  #3
I probably won't be able to give you the best answer; however, I can ask you one of the first question that everyone will want to know: "what do you plan on shooting with your lights?"
I would forget about the pop up flash if you are shooting people as it will just give you the dreaded red eye.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
No786
Jul 18, 2008 19:48 |  #4
I agree with the pop-up, it's no good at all.
Yes, I mainly plan on shooting portraits indoors.
I thought about getting two more Sigma 530's and Mastering one and having the other two as slaves in the umbrellas. But.... thats $$$
doidinho
Jul 18, 2008 20:45 as a reply to  @ No786's post |  #5
I'm not sure how the IR works; do you shoot in ETTL or M?
Shooting in M will give you more control over the light. If you trigger your flashes w/ a radio reciever then you can buy cheaper flashes which would offset the costs of the radio trigger and recievers a bit.
Robert McCadden
MM (external link)
No786
Jul 18, 2008 23:15 |  #6
Yes, I would be in M if possible. The thing I am trying to figure out it how to us the Sigma on camera. Would the Sigma be able to trigger a slave receiver if set to master?
Lotto
Jul 19, 2008 02:44 |  #7
You need another Sigma to be able to use in ETTL master/slave mode. Non dedicated flash can not be use in auto flash mode.
If you can bounce the flash off the ceiling, I can suggest a simple method that I use a lot. Use a Sunpak or Vivitar on camera bouncing straight up and off the ceiling as fill light, and set the Sigma to optical slave mode as the main light. Both flashes and camera in M mode of course.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
pellepiano
Jul 19, 2008 02:52 |  #8
Buy some radio triggers from Ebay or Gadget Infinity. Simple and effective and cheap and works in sunlight also.
- Pelle Piano
// Websitei
www.pellepiano.com (external link)
// My Invented Gallery Site, for all my alias
Gallery Browalls (external link)
No786
Jul 19, 2008 08:28 |  #9
Lotto wrote in post #5940438 (external link)
Wound the flash on the camera trigger the sigma?
pellepiano wrote in post #5940455 (external link)
Are those worth it? Or should I save the money for some better ones?
4rgentum
Jul 20, 2008 00:37 |  #10
the sigma has a built-in optical sensor, so when put in the right slave mode any flash will set it off.
I have ebay triggers and only use one of them on my main flash (540EX)... that flash triggers my three 500 Supers
5DII //30D
canon 15mm Fisheye //16-35L //50 1.4 //85 1.8 //200 2.8L
3 EF-500 DG Supers //2 AB800s
No786
Jul 20, 2008 17:24 |  #11
Thanks, thats what I was looking for.
1,338 views & 0 likes for this thread, 5 members have posted to it.
Setting up two
2760 guests, 153 members online
