Thread started 19 Jul 2008 (Saturday) 08:13
how to get white balance on flash and background?
Fabian9931
Jul 19, 2008 08:13 |  #1
So im trying to learn more flash photography, and I have a question.
- In M mode, I set my Shutter, Aparture and ISO to expose my background.
- Then turn my flash on on ETTL and let it automatically light up my subject.
How would I set my White Balance on my image if my background is light up by tungsten ambient light and my subject is flash?
Canon 60D EOS | Canon 50mm f1.4 | Canon 70-200mm IS f2.8 L | Canon 16-35mm 2.8 L II | 430 EX Speedlite x2 | PocketWizard x2 | Alienbee 400 | DIY Beauty Dish for 430ex and AB400 |
JeffreyG
Gallery: 42 photos
Jul 19, 2008 08:15 |  #2
You need to put a CTO gel over the flash to make the flash color the same as the lights. If you shoot it with a naked flash, there is no PP in the world that can white balance two distinctly different color temperatures in the same photograph.
John ­ E
Jul 19, 2008 08:23 |  #3
I had this problem at a recent wedding in a large hotel ballroom. The people up close looked fine but the people in the background were yellow. The camera flash produces white (daylight) light, whereas tungsten light is very yellow. As JeffreyG said, the only way to fix this is to put a yellow "CTO" colored gel (a piece of thin plastic) over the flash (usually adhered with velcro.) That way the light from your flash is the same color as the tunsten (all the same color) and corrected easily with software.
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
Fabian9931
Jul 19, 2008 09:04 as a reply to  @ John E's post |  #4
ahhhh, very nice... i do have a set of gels which i would have about 20 different yellows to choose from. just eye ball the ambient tungsten light with the gel and put it on and fire away right? sounds good. i will try this tonite.
ForHisGlory
Jul 19, 2008 21:22 |  #5
Go to photovision and get one of these http://www.photovision​video.com …_Code=P&Categor​y_Code=DCT (external link)
take your shot. go to custom WB off the menu. select the image you just took. Go to WB on the little pad on your camera on the right and click it. select custom white balance.
then you will have the perfect white balance, ISO and exposure the first time :)
Claire ~ Canon Rebel XTi EOS 400D & Grip, Speedlite 580EX II, 28-135 mm, 85mm f1.8,
Sigma 150-500mm, Dynatran Ball Head Tripod. WWW.ClaireGuthrie.com (external link)
To look through lens and press the shutter,
Is to capture the spirit of the created;
That the Creator may be glorified.
Player9
Jul 19, 2008 21:58 |  #6
Flash is rather blue and tungsten lights used in households are orange, so a gel is necessary. Many of the gels are matched to studio tungsten hotlights, which are higher in temperture than the typical household lights. Because of this, it may be difficult to find the perfect match, there will probably be some difference between the subject lit by the gel covered flash and the ambient light background, but it will be very minor.
RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
ANGUS
Jul 19, 2008 22:01 |  #7
Fabian9931 wrote in post #5941354 (external link)
NO! It must be a proper CTO Colour Balanced Gel, Like the Rosco ones.
Angus
| 1D MkIV | 1D MkIII | 5D MkII | 15FE | 16-35 f2.8 L | 24-70 f2.8 L | 70-200 f2.8 IS L II | 35 f1.4 L | 135 f2 L | 300 f2.8 IS L | 580 EX II | 580 EX II |
troypiggo
Jul 19, 2008 22:34 |  #8
General concept:
http://strobist.blogsp​ot.com …sing-gels-to-correct.html (external link)
https://photography-on-the.net …280&highlight=g​el+ambient
Fluro: https://photography-on-the.net …248&highlight=g​el+ambient
Do an advanced search in this forum for "gel ambient".
"Interesting. You're afraid of insects and women. Ladybugs must render you catatonic." - Sheldon
Flickr (external link) | Gear List | Macro Rig | Astro Rig | Astro Software Post
tmonatr
Jul 19, 2008 23:10 |  #9
ForHisGlory wrote in post #5944578 (external link)
This won't work if you have 2 different temperature lighting sources.
Tim
Bartender - "So, you guys are dictionary salesmen."
Roy Munson - "You would be punctilious in assuming that."
Fabian9931
Jul 20, 2008 09:27 |  #10
NSWESP wrote in post #5944764 (external link)
YES! that is the gels that i have, Rosco. Theres about 500 different colors, So ill just match one up to the ambient light and use that one.
R-C-G
Jul 20, 2008 09:42 |  #11
Fabian9931 wrote in post #5946822 (external link)
No, you'll want to use one of the first five in the pack, assuming you haven't disassembled it, that are labeled CTO and are gel number 3407, 3411, 3408, 3409, 3410.
gear
kuchsphotography.com (external link)
Fabian9931
Jul 20, 2008 21:39 |  #12
R-C-G wrote in post #5946865 (external link)
Ok, i see what your saying, yes its still in order. I see the CTO gels in the front... I will try that.
chawki12
Jul 21, 2008 13:54 as a reply to  @ Fabian9931's post |  #13
Suggest taking pictures in RAW and doing white balance later.
Fabian9931
Jul 21, 2008 14:18 |  #14
chawki12 wrote in post #5954899 (external link)
i always shoot in raw. i love it raw :lol:
René ­ Damkot
Jul 21, 2008 15:12 |  #15
Unfortunately, like the CWB mentioned before, that will not help one bit in this case: You can get good WB for flash or for ambient, but not for both, unless you gel the flash...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
3,674 views & 0 likes for this thread, 13 members have posted to it.
2831 guests, 155 members online
