I was trying to shoot my daughter, when my camera/lens started acting up. At first I thought it was the lens (17-55 f2.8 IS), as it showed "00" for the aperture value...
(I was in Manual mode), as well as the auto focus didn't work (checked the AF and made sure it was ON). I quickly dismounted the lens and blew some air on the contacts with a rocket blower. Mounted the lens back and it worked fine for a few shots, then I started having blocked FOV...
the bottom of the image would be all black. Thinking it was the lens, I swapped for the 10-22, and got the same result. It doesn't appear on every shot, and zooming in and out appears to make it come and go (no particular result for a specific zoom range).
Has anyone seen this before? I've had the camera for 7 months, and it probably has no more than 2000 clicks on it. What the hell is going on here?!?!?
Could it really be a failed shutter this early on?!?! I barely use!!!
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
