Thread started 19 Jul 2008 (Saturday) 14:13
ISO help
rhodesx6
Jul 19, 2008 14:13 |  #1
Can I get some help with ISO selection. I have read about and understand the relation between ISO, SS and Aperture. I read Understanding Exp and get the similar ideas about how it works. Where I am struggling is when to choose what. I believe it was in Und Exp he said he takes just about everything @ 200. Is that what you guys are doing? I know experience means a lot but not a lot here. Thanks
René ­ Damkot
Jul 19, 2008 14:26 |  #2
Just choose an aperture for the Depth of Field you want, set a shutterspeed that allows you to hand hold or, when on a tripod, that will freeze the motion of the subject (or not, if that's what you want).
Set an ISO that gives you correct exposure.
If there is no ISO that will give you correct exposure, go back to step one and alter your settings (or alter the light: flash, ND filter, whatever).
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
yogestee
Jul 19, 2008 20:35 as a reply to  @ René Damkot's post |  #3
Mostly 400ISO is my standard setting,, I shoot street candids/documentary photography..
I always select the ISO setting to suit the subject/lighting conditions then shutterspeed then aperture.. I mainly shoot in manual mode..
Jurgen
Persephone
Jul 19, 2008 20:43 |  #4
200 ISO by default, I usually raise it to 800 or 1600 ISO when trying to shoot indoors without flash.
Gear list
"Do you think it was my choice to wed a man I did not love? Live a life I did not choose? I was betrayed by the very gods that once saw me as their own. But no more." - Περσεφόνη (external link), God of War
rral22
Jul 19, 2008 20:44 |  #5
I shoot at the lowest ISO that will give me a useable shutter speed for the aperture I want.
midnight_rider
"Thrown under the bus."
Jul 19, 2008 20:46 as a reply to  @ Persephone's post |  #6
ISO is my last setting. I always choose my aperture first, then shutter speed, and then I select the proper ISO. It really depends on what you are shooting and how the lighting is. May I ask what camera you have?
I never, Not once claimed to read your post...
gjl711
Jul 19, 2008 20:56 |  #7
midnight_rider wrote in post #5944413 (external link)
Thats pretty much my routine except that aperture and shutter speed can change places depending on the effect. Actually, usually I am more concerned with shutter speed first, then aperture but in either case ISO comes last.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
John_B
Gallery: 178 photos
Jul 19, 2008 21:00 |  #8
rhodesx6,
I do it the same way rral22 does it ;)
rral22 wrote in post #5944406 (external link)
click to see (external link)
Riff ­ Raff
Jul 19, 2008 21:15 |  #9
It depends entirely on what you're shooting. I use ISO 1600 about 90% of the time, because I'm typically shooting low-light action and that ISO is what's needed for decent shutter speeds. If I'm using flash indoors, I usually go with ISO 800. If I'm shooting outdoors, I typically start with ISO 200 and adjust upward or downward based on cloud conditions, shade, and such.
Shawn McHorse - Shawn.McHorse.com (external link) / AustinRocky.org (external link)
DSLR: 5D Mark III Compact: S100 Flash: 580EX II Bag: Tamrac Rally 5
Lenses: 16-35mm f/2.8L II, 24-70mm f/2.8L, 70-200mm f/2.8L IS,
50mm f/1.4, 85mm f/1.8
rhodesx6
Jul 19, 2008 22:26 |  #10
40D
jrader
Jul 19, 2008 22:37 |  #11
It really depends on what you are shooting, how long you can hold the camera still (whether in hand or, better, if you have a tripod), and how much noise you can personally stand in your images prior to post production. For example, I shoot landscapes mostly and spend most of my time at low ISO setting (the 30D only goes down to 100 :( ), but I am also using a tripod much of the time and am using mid to high F# and longer exposures to maximize depth of field.
Recently, my tripod was stolen, so I have had to do everything handheld (which is really annoying after using a tripod for so long). So now, I use a lower F# and a higher ISO setting to get a exposure that is not too long for my hand to hold still and still get decent sharpness in my pictures. In reality, it's all give and take.
Best of luck.
John
www.GreatEscapePhotogr​aphy.com (external link)
Facebook Page (external link)
Instagram: @greatescapephotograph​y (external link)
polarbare
Jul 19, 2008 22:54 |  #12
I shoot 100 until my shutter speed drops below a level i feel comfortable - mostly shooting in AV mode.
Brad Moore
My Sportshooter (external link) Page
Polarbare Photo Blog (external link)
Photojournalist for Bostonist.com (external link)
http://www.flickr.com/​photos/polarbare (external link)
jasonleehl
Jul 20, 2008 00:23 |  #13
It's mainly ISO 200. If it's indoor shoots, I pump up to 1600. If I can use flash indoors, it is either 200 or 400.
You're welcome to follow me at Instagram (external link) or visit my gallery at http://www.timestoodst​ill.sg (external link)
DStanic
Jul 20, 2008 01:01 |  #14
As mentioned, it's usually the last thing I adjust. But I generally know what to set it to based on experience. Here are some examples with my XTi..
ISO100= outdoors bright sunlight (when ISO200 is overexposing at fast aperture)
ISO200= my general outdoor setting
ISO400= outdoors in lower light, faster shutter speed for my telephoto. Indoors with good light, indoors low light with flash in M... etc
ISO800= indoors low light with or without flash
ISO1600=indoors low light no flash (I only use it when I have to)
These are just some examples that come to mind. There are exceptions and different circumstances that I might use differrent ISOs. If I am shooting handheld or with tripod for example. I mostly shoot in Av mode or M.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
midnight_rider
Jul 20, 2008 09:52 |  #15
rhodesx6 wrote in post #5944899 (external link)
40D
Well then feel free to play around. My 40d has very low noise all the way up to 1250 ISO.
832 views & 0 likes for this thread, 13 members have posted to it.
ISO help
2785 guests, 132 members online
