Thread started 20 Jul 2008 (Sunday) 15:29
580EX II Are you having the same problem????
pyterps
Gallery: 6 photos
Joined Dec 2004
Jul 20, 2008 15:29 |  #1
My 580EX II has started getting loose on the hotshoe and when I shoot horizontal it will not flash.
Is anyone else having this issue and if you have how have you fixed it?
The 580EX is much easier as I can tighten it as much as I need to.
Dave
1DS MK III, Canon 70-200 2.8L IS, Canon 24-70 F2.8L, Canon 50 1.8, Sigma 1.4 TC, Canon 580 EX, and lots of other stuff.
PacAce
Joined Feb 2003
Jul 20, 2008 16:10 |  #2
Is it the flash that's having difficult tightening up in the hotshoe or is the hotshoe itself that's coming loose from the camera body?
...Leo
pyterps
Gallery: 6 photos
Joined Dec 2004
Jul 20, 2008 18:51 |  #3
It is really hard to tell which one is actually loose?
JWright
Joined Dec 2004
Jul 20, 2008 20:20 |  #4
pyterps wrote in post #5948426 (external link)
Dave
pyterps wrote in post #5949344 (external link)
Does it do this on both your cameras? If it does it on only one of them, then the problem is likely the camera. If it does it on both, then there is a problem with the flash.
John
NAisBEST
not few ..not really proud
Jul 21, 2008 10:37 |  #5
When it comes down to it, I also hate the new locking mechanism of the EX II. It doesn't let me affix to the camera as tight as I would like, and does "shimmy" around a tad.
Canon5DMkII - Canon 70-200 f/2.8L IS - Canon 24-70 f/2.8L - 580 EXII -
Microcosm
Jul 21, 2008 12:35 |  #6
NAisBEST wrote in post #5953647 (external link)
I see what you mean as it does swivel just a little little bit, but I doubt it's anything to worry about.
All Gear| Canon 50D | Canon Rebel XTi | EF 17-40mm f/4 L | EF 24-105mm f/4 L | EF 70-300mm f/4-5.6 IS | EF 50mm f/1.8 | EF-S 18-55mm f/3.5-5.6 | 580EX II
Nikon EM | 50f/1.8 | 100 f/2.8 | Speedlight SB-E
MyFlickr (external link)
cdifoto
Don't get pissy with me
Jul 21, 2008 12:41 |  #7
http://www.conraderb.c​om/flashrepair/ (external link)
Applies to all EOS bodies. I had to do it to my 10D and 1D II the other week.
pyterps
Gallery: 6 photos
Joined Dec 2004
Jul 21, 2008 14:15 |  #8
Thanks for all the replies and this is a very big problem when you are shooting a wedding and take a couple of images and everything fires and then you turn the camera to get a vertical and bang "no flash" when you really needed it. It only happened once ( I don't use it right now) and hope to get it working back again soon. I will check it on the other camera and then I may be able to narrow it down the the flash.
ninab
Aug 24, 2008 13:48 |  #9
Though this post is 4 weeks old, I decided to add to it – my 580 EX II started to loosen over the past 2 months and finally just completely left me hanging at a wedding yesterday - I ended up having to make a roll out of electrical tape and tape it to the bottom of the flash, which now sits between the flash and the camera body to push it back and force the contacts to touch. I was very stressed out and glad I could I "fix" it, but this is a $500 flash and this shouldn't happen! I don't shoot nearly as many weddings as other pros (i.e. overusage can't be it), I can't believe this is an issue. I will try this: http://shimworld.wordp​ress.com …hotshoe-fix/#comment-6264 (external link)
I have two more weddings this week and for my main flash to be flimsy in an area that's supposed to be improved is a huge disappointment. Wish it had a dial.
It's definitely the quick release on the 580EX II if anyone else is wondering about this!
2x5D/grip; 24-70 f/2.8L, 85 f/1.2L II, 70-200 f/2.8 ISL, 70-200 f/4L, 15 fisheye, 28-200, Sigma 105 Macro, lensbaby 2.0; 580EXII, 580EX, 550EX
focusphototahoe.com (external link)
Shooting
Aug 25, 2008 17:49 as a reply to  @ ninab's post |  #10
Mine does that in all positions..will work fine and then bam, no flash..I have to take it off the camera or bracket (doesn't matter) and put it back on to get it back working again. My hotshoe on camera and brackets and off camera cords all all tight..I made a list one time of 23 photographers all having the same problem with the 580ex II and even the promaster 7500Dx does it on a canon camera..Canon so far offers no help and no admittance that there is a problem so I guess we have to live with it... I wonder if Nikon users have their own flash problems?
2,379 views & 0 likes for this thread, 8 members have posted to it.
1690 guests, 140 members online
