Hi there,
I just bought a BNIB 24-105mm L4 from a forum member. Apparently he bought a 5D kit from ebay, and sold this lens in its original packaging. He did not open the packaging at all. Before we get to the test images, I have a question:
A. In this situation, will Canon honor the warrantee? I have the blank warrantee card--it has nothing filled in previously. If there is a problem with the lens, can I just send it in to Canon to be adjusted?
B. Okay, let's get to the images. It may just be my imagination. I'm new to SLRs and high quality cameras, so I don't know how much tolerance there should be. But here are low-res pictures of the images we will be comparing:
24-105mm_L_ORIG![]()
24-105mm_L_zoomed_ORIG![]()
50mm_1.8_ORIG![]()
efs_17-85mm_ORIG![]()
efs_17-85mm_zoomed_ORIG![]()
Now, all pictures were taken on my 40D at f/7.1. The built-in flash was used at Av mode. The camera was mounted on a tripod at ~45deg (eyeballed) as prescribed, and a remote was used to actuate the shutter. I estimate the lens to be ~1.5ft from the focus point. The AF pattern was selected for the center box only, and I tried to make sure the focusing area to be exactly in the middle of the focus box, as best as I could.
I've included images from my 2 others lenses as well. The idea being that if the other images are fine, then it's not my camera's fault but the lens. Now here are high-res crops of the originals:
24-105mm_L_CROP![]()
24-105mm_L_zoomed_CROP![]()
50mm_1.8_CROP![]()
efs_17-85mm_CROP![]()
efs_17-85mm_zoomed_CROP![]()
I want to give my notes after I hear your opinions, as I don't want to skew your thoughts.
Please help me out!--this lens is terribly expensive for me, so I need to know if my copy is good or not, and what I can do about it if it is not.
Thank you very much,
Dean
