Thread started 21 Jul 2008 (Monday) 00:10
Flash on Slave not shooting at the same time!
bluetorch
Jul 21, 2008 00:10 |  #1
Hello all! first post! I hope you guys have the answer:
I have a Canon XTi and found in my uncle's old stuff an external Vivitar V-160 and a Metz Mecalux 10 slave.
I have the slave with the flash on top on a tripod, when I shoot my camera's flash in order to triger the slave, it appears that the slave shoots FASTER?
I can't get the flash light in the picture. I've tried slower speed to see if the slave was slower than my camera, and it looks the other way.
Any way to fix this?
FlashZebra
This space available
Jul 21, 2008 00:26 |  #2
The built in flash on the XTi always produces a preflash before the actual exposure flash.
The off camera flash is triggering on the preflash, so is not recycled and ready to fire when the camera actually open the shutter.
Enjoy! Lon
bluetorch
Jul 21, 2008 01:45 as a reply to  @ FlashZebra's post |  #3
Thanks! but nop!
I knew about the pre-flash focusing thing, and I did it on manual focus... same thing.
qtfsniper
Jul 21, 2008 02:41 |  #4
bluetorch wrote in post #5951622 (external link)
Thanks! but nop!
manual focus doesn't cause the preflash. it's the flash mode you are using. are you sure you are doing it right? I mean... optical flash slave triggering has been around for a very long time now.. It has to be user mistake.
tim
Light Bringer
Jul 21, 2008 05:19 |  #5
You can't use the built in flash to trigger optical slave flashes, you have to use an external flash in manual mode. A manual workaround is to hit the * button on the camera, wait 10 seconds for the slaves to recharge, then shoot, but that wastes time and batteries. You can get a wein product that has an optical slave trigger that knows about the preflash and only fires strobes on the 2nd flash, but they're not cheap.
Be careful putting old flashes on the camera hotshoe, the voltage can fry them. The Wein Safesync can protect against that, but again, not particularly cheap.
riyazi
Jul 21, 2008 05:48 as a reply to  @ tim's post |  #6
As Tim said above, you can press "*" to set off the pre-flash (which will trigger the slave flash) and then press the shutter button to set off both flashes at the same time. So effectively you will be triggering the slave flash twice for each shot. However, you may not need to wait for 10 secs depending on how fast the slave flash recycles. On my one (model YinYan :rolleyes:) it recylces within about 1-2 secs if I got some fresh batteries on. So I trigger the preflash with "*" and then take the shot with the shutter button as soon as the ready red light comes back on the slave flash.
You should also try shooting in manual mode (NOT manual focus mode but the "M" mode instead of "Av" or "Tv" modes). I beleive this disables the preflash so that you just need to press the shutter button to take the shot with both flashes firing. Needless to say if you put your camera flash on manual mode or take off the option of preflash it would work as well.
Website (external link) | Facebook (external link) | Tweets (external link) | Google+ (external link) | flickr (external link) | Blog (external link) | Gear
tim
Light Bringer
Jul 21, 2008 06:03 |  #7
I'm fairly sure the preflash can be disabled on the internal flashes of eos cameras, no matter what mode you're in. Even in M the camera needs the preflash to figure out the required flash power.
dpds68
Jul 21, 2008 06:26 |  #8
^^^ That's what I thought as I was looking at doing the same thing after some research I found that you cant disable the preflash .
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
PacAce
Joined Feb 2003
Jul 21, 2008 07:31 |  #9
tim wrote in post #5952361 (external link)
No, the preflash cannot be disabled for the internal flash because there's no way to set the internal flash to manual mode.
...Leo
speedygonzo
Jul 21, 2008 15:50 |  #10
I have the same problem. I am using the XTi and a 430EX flash monted on the camera, as a second flash I am using an old Vivitar 283 flash with a Vivtar slave. The Vivitar 283 does fire, but it is not in sync with the 430EX. I can see both flashes go off as I look thru the viewfinder, but when you look at the finished rusults there is no evidence of the 283 flash ever firing. So how do I get the Vivitar flash to sync with the camera and 430EX?
Thanks; Speedy
PacAce
Joined Feb 2003
Jul 21, 2008 16:08 |  #11
speedygonzo wrote in post #5955643 (external link)
Thanks; Speedy
Put the 430EX into manual mode.
...Leo
speedygonzo
Jul 21, 2008 17:56 as a reply to  @ PacAce's post |  #12
Thanks, that worked....
888 views & 0 likes for this thread, 8 members have posted to it.
2831 guests, 155 members online
