Thread started 21 Jul 2008 (Monday) 03:06
Battery Grip question
AlexinS.A.
Jul 21, 2008 03:06 |  #1
O.K. this may sound silly and I am sure that I will find out when I get it but I am curious. I have just ordered a battery grip online and should get it tomorrow. My question is, what happens to the camera's battery compartment door when affixing the grip? I notice that when I open it, it sticks out at a 45 degree angle.:confused:
Alex Bond-Smith, Cape Town,South Africa. Canon 50D.Website http://www.alexbondsmi​thphotography.co.za/ (external link)
according ­ to ­ jim
Jul 21, 2008 03:08 |  #2
It comes off. Quite simply actually, and save it to put back on without the grip. The directions with the grip will show you.
Jim
SlowBlink
"I like dog butts"
Jul 21, 2008 03:33 |  #3
There's a slot in the grip that holds it so you don't have to keep it separate.
Rob
Anatidaephobia - The Fear That You are Being Watched by a Duck.
AdamC
Jul 21, 2008 03:34 as a reply to  @ according to jim's post |  #4
As Jim said, it just unclips. There is a spot on the battery grip to store it safely should you need it again (I doubt I will, I haven't fired a shot without by BG since I got it!)
[gallery (external link)|gear|flickr (external link)|blog (external link)]
Shutterbug ­ Doug
"Ducks Gone Wild"
Jul 21, 2008 04:59 |  #5
It's clipped on with a similar type pin used for attaching watch bands to watches. It has a little knob/"pokey thingy" that sticks out that just slides the pin back and off it comes.
AdamC wrote in post #5951910 (external link)
Interesting, I never noticed that before....guess I should have read the grip manual a little closer......
I store the battery compartment door to my 30D in the box the grip came in so it's right were I need it if I need to box the grip up for a sale or repair return.
Bodies: Canon 7DMK2 w/gripX2 - Canon 5D w/grip Lenses: Canon 16-35 f2.8L USM - Sigma 18-50 f2.8-4.5 DC OS - Canon 24-70 f2.8L USM - Canon 70-300mm f/4-5.6 IS USM - Canon 70-200 f2.8L IS USM Primes: Opteka 6.5mm f3.5 Fish-eye CS - Canon 24 f2.8 - Canon FD/EF convert 35mm f2.8 T/S - Canon 50 f1.4 USM - Canon 100 f2 USM - Canon 400mm f5.6L USM Accessories:Canon 420EX - Canon 580EXII x2 - Manfrotto 679B monopod - Manfrotto 3021BPRO w/390RC2 - Canon EF 1.4x II
gofer
Jul 21, 2008 05:40 |  #6
Shutterbug Doug wrote in post #5952124 (external link)
I'm not sure what the OP camera is but if it's a 40D Canon have changed the method used for retaining the battery door. On the 40D is simply a pullout assembly.
Steve.
AlexinS.A.
Jul 21, 2008 23:15 as a reply to  @ gofer's post |  #7
Thanks, I have a 400D and have now worked it out. Door comes off easily and I am :confused:very technically challenged! Just looked closely at pic on site of my battery charger and it does also seem to have a slot for the door.
ironron
Jul 22, 2008 08:43 |  #8
MY 10d, does'nt have a slot!:eek:
AlexinS.A.
Jul 22, 2008 09:21 as a reply to  @ ironron's post |  #9
Received the grip today and it does not have a slot for the door, but found removing it quite easy thanks.:D
Stuperfox
Gallery: 12 photos
Jul 22, 2008 10:56 |  #10
It does, on the post that goes to into the battery compartment. It is on the side, I believe the outside.
I have circled if on this picture.
IMAGE: http://i48.photobucket.com/albums/f228/nicolas41390/bg-e3.jpg
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
ironron
Jul 22, 2008 11:18 |  #11
Cheers foxy.Do you know i would never have looked there.
:D
AlexinS.A.
Jul 22, 2008 23:35 as a reply to  @ ironron's post |  #12
Thanks very much. My door is NOW stored in the slot in the grip that you showed us!:D
john-in-japan
Jul 22, 2008 23:54 |  #13
Greetings - Piggybacking on this thread please..... in using the dual battery pack (mine is on the 5D), is one battery used before the other (and which one?) and when you charge them do you rotate the batteries? In other words is the one on the left or right depleted first, or are they depleted together? I have never had full depletion of the batteries, but it seems that they take different times to fully charge when charging them prior to an outing, so I do rotate them just in case.
Thanks!
John
JohnW
5D Mark II Dual Battery Grip, [COLOR=black], 200 f/2.8L, 70-200 f/2.8L II IS, 24-70 f/2.8L 180Macro f/3.5L[COLOR=black], 85 II f/1.2L[COLOR=black], 17-40 f/4L, 50 f/1.4, 50 f/2.5 Compact Macro, MPE-65, 550EX, 400L f.2.8L IS, 580EXII, Canon RingFlash, RRS Perfect Portrait Pkg., Velbon with PH275 and Slider, bunch of filters, Canon 1.4X & Having Fun! http://kamogawa.smugmu​g.com/external link
Ridebmx
Jul 23, 2008 00:21 as a reply to  @ john-in-japan's post |  #14
the left one is the main one, atleast on my 350D, it has a picture showing to put the main battery there if you only have 1 battery, so common sense says it uses that one as the main. but it uses both batteries at the same time
Camera gear: 40D, 350D Gripped, AE-1 Program, 70-200mm f/4L, Tokina 12-24mm, Thrifty Fifty 1.8, 75-205 3.5-5.6 macro, 28mm 2.8, 188A, 430EX, Nikon Sb-28, Skyport Triggers
Tom_D
Jul 23, 2008 00:38 |  #15
While I loved the battery grip on my XT I have not felt the need to get one for the 40D.
I think eclectically the batteries are in parallel. That being the case, the battery that is charged the most should discharge to the point the batteries are at the same voltage and then discharge evenly as long as the batteries are similar age and condition.
Gallery (external link)
7DMkII, 40D, 17-55, 70-200 f/2.8 IS and more...
More Wag, Less Bark
2,950 views & 0 likes for this thread, 12 members have posted to it.
659 guests, 121 members online
