http://reallyrightstuff.com/tripods/04.html![]()
Anyone have a review? Opinion?
Scott
PM720 Senior Member 323 posts Likes: 1 Joined Dec 2007 Location: Las Vegas More info | Jul 21, 2008 18:44 | #1 http://reallyrightstuff.com/tripods/04.html 1DsMkII, 1DMkIIn, XTi, Kit 18-55, 16-35L, 70-200L 2.8IS, 50 1.4, 85 1.8, 100 2.8, 500/4, Sigma 10-20, Extender 1.4 & 2.0, 580EX's.
Jul 21, 2008 20:54 | #2 I guess if you use a mono-pod a lot. But is seems like a lot of cost for what it is. Darrell
blonde Buck Naked Floozies 8,405 posts Likes: 1 Joined Oct 2005 Location: Boston, MA More info | Jul 21, 2008 20:58 | #3 if you have a big lens (300 2.8, 400 2.8, 500 f4 or 600 f4) and you use a monopod alot and still like to have the ability to tilt up and down, this is the head for you. the build quality is outstanding and it held my 500 and 1D at all angles without a problem.
jhom Goldmember 1,320 posts Joined Apr 2007 Location: Dallas, TX More info | Jul 21, 2008 21:08 | #4 So far, all the comments I've read have been very positive. I've use the 3232 and did not like it. I am considering the MH-01. RRS makes excellent components that function well. Compared to the 3232, it is pricey. But if it works as described, then it is well worth it. Jim
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 21, 2008 21:31 | #5 Compared to how cheaply built the Bogen is, the RRS seems to be the only solution to consider thats made with any real quality. If I do decide to get another monopod it will be a CF Gitzo and more that likely Ill top it with this little RRS gem. [Gear List | Flickr
Thanks guys! I should have figured that Blonde would have the hands on experience! 1DsMkII, 1DMkIIn, XTi, Kit 18-55, 16-35L, 70-200L 2.8IS, 50 1.4, 85 1.8, 100 2.8, 500/4, Sigma 10-20, Extender 1.4 & 2.0, 580EX's.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 22, 2008 11:52 | #7 PM720 wrote in post #5958493 Thanks guys! I should have figured that Blonde would have the hands on experience! ![]() Now, should I get this BEFORE or AFTER I get the 500? ![]() ![]() Scott AT THE SAME TIME!!!! Whats an extra $150 when youre buying a 500? [Gear List | Flickr
Good point! 1DsMkII, 1DMkIIn, XTi, Kit 18-55, 16-35L, 70-200L 2.8IS, 50 1.4, 85 1.8, 100 2.8, 500/4, Sigma 10-20, Extender 1.4 & 2.0, 580EX's.
blonde Buck Naked Floozies 8,405 posts Likes: 1 Joined Oct 2005 Location: Boston, MA More info | Jul 22, 2008 15:16 | #9 i would honestly get it after you get the 500. before you buy it, you will need to decide if you will actually use the monopod enough to justify it. also, the $150 figure is a bit misleading because you will also need a clamp to go with it
Jul 22, 2008 19:29 | #10 Yes, it is actually $226 with the clamp. 1DsMkII, 1DMkIIn, XTi, Kit 18-55, 16-35L, 70-200L 2.8IS, 50 1.4, 85 1.8, 100 2.8, 500/4, Sigma 10-20, Extender 1.4 & 2.0, 580EX's.
GSansoucie Senior Member 788 posts Likes: 2 Joined Jul 2005 Location: Southern Maine More info | Jul 22, 2008 20:03 | #11 I have this setup: -=Glen=-
| Latest registered member is johntmyers418 1090 guests, 193 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
