Thread started 22 Jul 2008 (Tuesday) 16:53
Error 99 on 20d. Only @ Aperture other than f/4
Sublimejoe
Jul 22, 2008 16:53 |  #1
So I have read a lot of posts about error 99, but so far I still haven't heard of anyone having the same problem as me so I will post about it. I only get an Error 99 when using my Tokina 12-24mm f/4 and only if the aperture is set at anything except 4.0. I can shoot all day at f/4 with no codes and no problems, but as as soon as I change the aperture it immediately throws an Error 99.
Anyone have any ideas?
http://www.ShootJoeC.c​om (external link)
http://blog.shootjoec.​com (external link)
Doug ­ Pardee
Jul 22, 2008 17:08 |  #2
Most likely the lens is failing to stop down when commanded to by the camera.
Has this lens worked on this camera in the past? If so, it may just be a problem with the electrical contacts. The first step would be to try removing and refitting the lens.
Sublimejoe
Jul 22, 2008 17:10 |  #3
I have been using the lens for over a year with no problems. I have taken it on an off, cleaned the contacts, reset all the settings on the body etc. Still having the exact same problem.
DDCSD
GIVIN' GOOD KARMA
Jul 22, 2008 17:21 |  #4
You didn't say if your 50 has the problem also?
If your 50 works fine then there is something wrong with the 12-24.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
StuffNJunk
Jul 22, 2008 20:01 |  #5
DDCSD wrote in post #5963612 (external link)
If you 50 works fine then there is something wrong with the 12-24.
I agree...sounds like it is most likely a lens problem...especially if your other lenses work with not problems...good luck :)
~Dale~ Professional Pharmacist...Amateur Photographer
My Gear: Canon EOS 5D | Canon EOS 300D | Canon EF 50mm f/1.4 | Canon EF 24-105mm IS f/4L | Canon EF 70-200mm IS f/4L | Canon EF 100-400mm IS f/4.5-5.6L | Canon 430EX Speedlite | Canon Backpack 200EG
DDCSD
GIVIN' GOOD KARMA
Jul 22, 2008 20:04 |  #6
If it is the lens and it is out of warranty, drop it (the lens) from about 2 feet (not attached to the camera) onto a carpeted floor. That might loosen things up.
Derek
Sublimejoe
Jul 22, 2008 23:21 |  #7
50mm works fine.
I called Tokina and they said that I should send it in (even though I don't have a receipt) with the warranty card and they will fix it. They said they have about a two week turnaround time. Wish me luck :/
DDCSD
GIVIN' GOOD KARMA
Jul 22, 2008 23:24 |  #8
Let us know how it turns out!
Derek
Sublimejoe
Jul 23, 2008 00:12 |  #9
For sure! Im not looking forward to being without that lens for 2 weeks (or however long it will actually take)
1,986 views & 0 likes for this thread, 4 members have posted to it.
1505 guests, 131 members online
