Thread started 23 Jul 2008 (Wednesday) 00:29
Does anyone have any info on this flash?
mindchatter
Jul 23, 2008 00:29 |  #1
I can't find any specs for the Digital Concepts 952AF. I found it here http://www.adorama.com​/DC952AFCAN.html (external link) however it does not mention if it works with the 40D? I'm interested in knowing more about it's manual controls and how much control you can have over the power output. Does anyone have this unit or maybe use it with a 40D? Now with that said, It'll mostly be used for off camera but I'm interested in it because it offers the ability to use it on canon's. Thank You.... I seem to be having a tough time deciding on a second flash.
Canon EOS 40D Gripped
Canon 28-135mm IS lens-Canon 50mm 1.8
Canon 430ex speedlite-Digital Concepts 952AF-
Calumet Genesis 200-Cybersync triggers
http://www.flickr.com/​photos/mindchatter (external link)
http://www.jerrybutzph​otography.com/ (external link)
cdifoto
Don't get pissy with me
Jul 23, 2008 00:31 |  #2
No specs? Skip it.
mindchatter
Jul 23, 2008 00:34 |  #3
Thats why I'm reaching out to the forum hoping that just maybe someone has had there hands on one
Curtis ­ N
Master Flasher
Jul 23, 2008 00:38 |  #4
If it works on the other cameras listed, it should work on the 40D (caveat: read the review). However, you won't be able to control the flash settings via camera menu like you could with the newer EX Speedlites (580EX II, 430EX II).
One limitation of most aftermarket E-TTL compatible flash units is lack of high speed sync. There are numerous other differences between the various aftermarket brands and EX Speedlites.
The one review on Adorama's site isn't favorable. You get what you pay for.
mindchatter
Jul 23, 2008 00:39 |  #5
I found these specs on Amazon
Technical Details
* Five level of power ratio 1/1, 1/2, 1/4, 1/8/ and 1/16
* Swivel Bounce Zoom Head, Horizontal angle from 0 to 270, Vertical angle: 0,45,60,75,90
* Digital Power Auto Zoom and manual zoom flash head from 24/28/35/50/70/85 mm
* Built-in reflecting plate and diffuser with Focus bean to assist in low light conditions
Doesn't look bad...but can it work on a 40D?
cdifoto
Jul 23, 2008 00:41 |  #6
I'd skip it because there's no mention of Guide Number - which means you have NO idea how powerful (or weak) the flash is.
dFreezy
Jul 23, 2008 07:51 |  #7
Your signature says you have a 430EX...are you just looking for another flash for off-camera endeavors? If so, its probably in your best interest to go with a tried & true flash even if you're on a budget.
Sony: A7R2, 16-35/4, 24-70/4, 55/1.8, 85/1.8
Canon: 135/2L 80-200/2.8L, 100-400L mkI
dpds68
Jul 23, 2008 08:30 |  #8
Check this out as a alternative.
http://www.bhphotovide​o.com …965_285HV_Auto_​Flash.html (external link)
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
gromeo
Jul 23, 2008 08:41 |  #9
Looks like it is made by a company named SAKR here is the link http://www.sakar.com/p​-1227.aspx?categoryid=1​44 (external link)
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
mindchatter
Jul 23, 2008 15:45 |  #10
dpds68... I'm looking into the vivitar but I have a question about it. There is a sensor on the front of it that needs a clear line of sight to the subject, what if I'm gonna be shooting it though an umbrella? Also, does that fit the 40D, incase I would want to mount it? Thanks
mattograph
"God bless the new meds"
Jul 23, 2008 15:51 |  #11
If you are shooting through an umbrella, the sensor won't work, but I cannot imagine using ttl functions with an umbrella - too many variables.
This space for rent.
msowsun
"approx 8mm"
Gallery: 18 photos
Jul 23, 2008 16:48 |  #12
The Sakar Digital Concepts 952AF, http://www.sakar.com/p​-1227.aspx?categoryid=1​44 (external link)
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/952af.jpg
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/photo%20stuff/952a.jpg
Looks like a re-branding of the Soligor DG-420 Z Zoom Flash. http://www.soligor.de …ItemsPerPage=20​&pid=58447 (external link)
There may even be other versions under different names.
They are available for Canon and both should work fine.
Specifications:
• for Canon digital and (D)SLR cameras with hot shoe
guide no. 42 at ISO 100/85mm• ETTL flash control
• ETTL control light
• power zoom for focal lengths 24, 28, 35, 50, 70 and 85mm
• bounce angle vertical 0°/45°/60°/75°/90°
• swivel head max. 270°
• flash recycling time 0.5–8s
• slave-adaptor
• flash duration: app. 1/1,000s–1/20,000s
• number of flashes: app. 150 to 1,500 flashes with 1 set of fresh alkaline batteries
• colour temperature: 5600K (in accordance with daylight)
• auto focus illumination 1–8m
• thyristor circuit
• 5 power ratios: full, 1/2, 1/4, 1/8, 1/16
• auto power off
• flash ready indicator
• exposure control display
• power supply: four 1.5V AA batteries Mignon type or NiMH rechargeable batteries of the same size
• 172x72x57mm
• weight approx. 278g (w/o batteries)
mindchatter
Jul 23, 2008 19:56 |  #13
GN of 42...... thats not good is it?
mattograph
Jul 23, 2008 20:27 |  #14
Good enough for basic snap shot stuff. Not the best for working with off camera light.
msowsun
"approx 8mm"
Gallery: 18 photos
Jul 23, 2008 20:38 |  #15
mindchatter wrote in post #5971642 (external link)
That is good enough. It is about equal to a Canon 420EX or 430EX.
2,674 views & 0 likes for this thread, 8 members have posted to it.
2876 guests, 152 members online
