How's the light quality different between a shoot through umbrella and a bounce umbrella? I'll be firing either a 580ex or a 430 ex into/through it at 1-3 subjects not too far from the flash
MikeZip007 Senior Member 751 posts Joined Apr 2007 Location: Los Angeles, CA More info | Jul 23, 2008 07:43 | #1 How's the light quality different between a shoot through umbrella and a bounce umbrella? I'll be firing either a 580ex or a 430 ex into/through it at 1-3 subjects not too far from the flash Equipment: Sensor, Glass, Light, Mind
ean36 Senior Member 625 posts Joined Jun 2006 Location: West Palm Beach, Florida More info | Jul 23, 2008 07:47 | #2 One difference, shooting thru, will allow you to get your light 50% closer to your subject. be safe and well. George
TheHoff Don't Hassle.... 8,804 posts Likes: 21 Joined Jan 2008 Location: Vancouver, BC More info | Jul 23, 2008 08:48 | #3 Umbrella will be more flattering as you can have the light be more direct or 3/4 angle, rather than overhead, which can cause raccoon eyes. ••Vancouver Wedding Photographer
stathunter "I am no one really" 5,659 posts Likes: 60 Joined Aug 2006 Location: California & Michigan More info | Jul 23, 2008 08:57 | #5 It depends on the shoot you are doing. If you want a large spread of light I bounce the light against the umbrella but the light tends to be more harsh. For softer light you can shoot through---this is my preferred way ---but you also --at least I do-- have the umbrella pretty close to the subject. Scott
MPowered Goldmember 1,476 posts Joined Oct 2007 More info | Jul 23, 2008 15:29 | #6 When I need to travel light, I use shoot through. Easier to aim, think of it as a curved softbox Canon 5D Mark III | EF 24-70 f/ 2.8 L II
Jul 24, 2008 08:01 | #7 Well, if M powered says Shoot through... Equipment: Sensor, Glass, Light, Mind
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Mike, Robert
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Jul 24, 2008 08:52 | #9 TMR is right. What you want to use, depends on what you want as a final image. I have been known to use shoot through from one side and reflected on the other. (I doubt that is unique.) But I think you are doing the right thing when you said you would get 2 of both. That way you are covered no matter what.
MPowered Goldmember 1,476 posts Joined Oct 2007 More info | Jul 24, 2008 15:08 | #10 Just get the convertible umbrellas, turn shoot through into a bounce; its got a black cover on it that velcros to the back. Its like $40 bucks or something. Canon 5D Mark III | EF 24-70 f/ 2.8 L II
Jul 25, 2008 01:14 | #11 TMR Design wrote in post #5974736 Mike, You have to look at what is being said and understand that soft light with lower contrast is not the only or right way. Soft light is a choice, not a requirement. M Powered is giving a recommendation based on his preference and use of soft light. It's only one technique of many and too often people that are new to lighting just keep hearing about soft light and large diffused light modifiers. There's more to lighting than that and you that can be very limiting unless you have a specific market or clientel giving you that type of work. There are times when more contrast and greater specularity are desirable. In a bright sun (which is specular light), if you're incorporating ambient light in the shot rather than overpowering it you'll find out that there isn't much you can do to soften the light with a shoot through umbrella at 4 feet. You may as well use a silver bounce umbrella or even a bare flash head. Save your batteries. If soft light is your choice then certainly white shoot through umbrella's will give the softest and most natural looking light. If you wanted to create additional depth and enhance features or characteristics of the face then you might want to use lighting that is not quite as soft and gives a slightly harder gradation between highlight and shadow. Rather than getting 4 umbrellas why not start with 2 that can be used as bounce or shoot through. The interior will be white and not silver but there's nothing that says a bounce has to be silver. It all boils down to what I said in my second sentence. Soft light is a choice, not a requirement. Thanks for the write up. I am very aware of the qualities of light. comment was more sarcastic because I know M powered from another forum and have previously expressed my liking for his photography. M Powered wrote in post #5976912 Just get the convertible umbrellas, turn shoot through into a bounce; its got a black cover on it that velcros to the back. Its like $40 bucks or something. Recommendations to where I can check these out? Equipment: Sensor, Glass, Light, Mind
Jul 25, 2008 01:29 | #12 just search for convertible photo umbrella and such. Found these at B&H, they also have more listed as well. Bodies: Canon 7DMK2 w/gripX2 - Canon 5D w/grip Lenses: Canon 16-35 f2.8L USM - Sigma 18-50 f2.8-4.5 DC OS - Canon 24-70 f2.8L USM - Canon 70-300mm f/4-5.6 IS USM - Canon 70-200 f2.8L IS USM Primes: Opteka 6.5mm f3.5 Fish-eye CS - Canon 24 f2.8 - Canon FD/EF convert 35mm f2.8 T/S - Canon 50 f1.4 USM - Canon 100 f2 USM - Canon 400mm f5.6L USM Accessories:Canon 420EX - Canon 580EXII x2 - Manfrotto 679B monopod - Manfrotto 3021BPRO w/390RC2 - Canon EF 1.4x II
Rudi Goldmember 3,751 posts Likes: 1 Joined Mar 2002 Location: Australia More info | Jul 25, 2008 05:42 | #13 TMR Design wrote in post #5974736 In a bright sun (which is specular light), if you're incorporating ambient light in the shot rather than overpowering it you'll find out that there isn't much you can do to soften the light with a shoot through umbrella at 4 feet. I understand what you're saying, Robert, and I know you would be aware of this, but let's not forget that you can use a shoot-through umbrella to soften sunlight, too. I only mention it because a lot of people get all hung up on shaping strobe light, and forget that they can also shape sunlight! • Wedding Photographer - Sydney and Wollongong
Olar Member 36 posts Joined Mar 2007 Location: Southern Ontario, Canada More info | Jul 25, 2008 07:44 | #14 Rudi wrote in post #5981247 I understand what you're saying, Robert, and I know you would be aware of this, but let's not forget that you can use a shoot-through umbrella to soften sunlight, too. I only mention it because a lot of people get all hung up on shaping strobe light, and forget that they can also shape sunlight! Now theres an interesting technique that I'm going try right away. Am I correct in saying that the shoot-thru umbrella would soften/reduce the sunlight enough so that it actually becomes the fill-light source and a strobe would act as the key? Or would the thru-umbrella sunlight still be bright enough that it would have to be considered the key-light and fill with strobe? Canon 7D, 40D, 1 - "L", 1 - almost L, 3 - primes, 3 speedlites, PW's and L358.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | Umbrellas and diffusion panels work very well to soften and diffuse light and are great tools for subtractive lighting, when you want to reduce the output or control the effective brightness of the sun in your shot. Robert
| Latest registered member was a spammer, and banned as such! 2753 guests, 145 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
