Are there any other car mounts available? I'm aware of the groofwin pod and one made by kirk, both are about $250.
Jul 23, 2008 08:54 | #1 Are there any other car mounts available? I'm aware of the groofwin pod and one made by kirk, both are about $250. Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 23, 2008 09:31 | #2 Well Bogen makes this one that is significantly cheaper: LINK [Gear List | Flickr
Jul 24, 2008 14:30 | #3 That one won't work as it only supports 5.5lbs. I will be using the 500L with 1.5x TC attached to a 40D. Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 24, 2008 16:57 | #4 Wow a 500? Why dont you just get one of those bean bag deals and set the lens directly onto that? [Gear List | Flickr
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 24, 2008 16:59 | #5 Like this one: LINK
[Gear List | Flickr
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jul 26, 2008 19:50 | #6 badams wrote in post #5976711 That one won't work as it only supports 5.5lbs. I will be using the 500L with 1.5x TC attached to a 40D. I don't mind paying $250 for one, but was just wondering what others are available. Don't know as I'd want to put that on a rolled down car window . . . Jon
Vetteography Goldmember 2,032 posts Likes: 1 Joined Apr 2005 Location: Miami FL, USA More info | Jul 26, 2008 19:59 | #7 Just do a search for Spotting Scope window mount. There are a lot of less expensive options out there. Heck, Nikon has a $30 one you can buy (if you want to paint over the Nikon
Jan 13, 2009 13:49 | #8 Well I'm going to bring my old thread back to the top as I never made a decision last year. Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
sirockalot Senior Member More info | this one seem good, and it suports upto18lbs, so you should be ok with your gear...
| Latest registered member is semonsters 1048 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
