Today I have been shooting a shoe repairer for 1,5 hours.
I shot with my new Canon 5D + ST-E2 + 580 EXII behind an umbrella + 430 EX sometimes with a CTO (CTO is for orange gell isn't it ?) + Canon 24-75
At first I used only the 580 behind the umbrella but moments ago I switched on the 430.
The flashes were opposed one another. The 580 at the left and the 480 at the right.
The place where I was with the man is very very small. I could hardly move.
What have I learned from this shots ?
* I was always or too often, balancing the flash from the right to the left and vice-versa. I think that is incorrect. I should have tested and stayed in a balance for more shots that I have.
* I shot in Aperture mode in most of the shots when I should have moved to Manual sooner, using a higher speed to get a deeper background, even if it would be necessary to change to HSS.
I am aware that using HSS the flash/s deliver less power but I think their balance would be kept.
* The 5D is very demanding in terms of focus. I mean: if we are working with rather large apertures - I am talking her about only a f/3.5 - the DoF is shallow and the focusing point is critical. Within the range 35-70 or so.
The 20D is more tolerant as the sensor is smaller...
I have make a table of DoF for both cameras to compare.
* I should have seen how harsh the shadows were with the flash on the right (430 EX).
Are you still there reading ? Good. Thank you. Nice of you.
1.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
