Thread started 23 Jul 2008 (Wednesday) 21:23
Does Histogram replace Light Meter job?
danielyamseng
Jul 23, 2008 21:23 |  #1
With advent of digital SLR do you guys think that light meter function can be replaced by the camera histogram?
TMR ­ Design
Joined Feb 2006
Jul 23, 2008 21:31 |  #2
danielyamseng wrote in post #5972149 (external link)
Absolutely not. The histogram doesn't tell the whole story and histogram representation in the camera is not the most accurate one.
That's not to say that people are not able to shoot and adjust exposure based on the histogram but the perfect histogram is not always a perfect exposure. An example of that would be a black background, dark clothing, and the face of your subject. The histogram for that image would have you thinking the image was underexposed, whereas the exposure on the face is perfect but it's a very small part of the image and most of the frame is filled with black.
Robert
Jim ­ M
Jul 23, 2008 21:39 |  #3
It depends. You really have to get used to what the histogram means. Most flash histograms bear little resemblance to a daylight histogram. Often they will look seriously under exposed, but if you check the right hand side of the histogram, you can usually see some meat in it even if it isn't a whole lot. Histograms only show you the relative amount of various tones in the picture. If there are a lot of dark tones in the picture, the histogram will resemble a seriously under exposed picture. If there are a lot of very light tones in the picture, the histogram will look like an over exposed picture. If you want to try not using a meter, practice a whole bunch and look at the results on a real computer screen or print them out. Don't trust the camera's LCD monitor - everything looks too good on it.
danielyamseng
Jul 23, 2008 22:09 as a reply to  @ Jim M's post |  #4
If that's the case, is it correct to say if the photograher has experience on how to read the histogram and knowhow to compensate the extreme color(away from 18% gray scale), he still able to get a correct exposure?
In other word, does light meter is for the beginners ?
Rudi
Joined Mar 2002
Jul 24, 2008 04:24 |  #5
danielyamseng wrote in post #5972464 (external link)
Definitely not!
• Wedding Photographer - Sydney and Wollongong (external link)
• Borrowed Moment (blog) (external link)
Life is uncertain. Eat dessert first.
tmonatr
Jul 24, 2008 04:31 |  #6
Actually, it seems the more experienced photographers are the ones who use meters.
Tim
Bartender - "So, you guys are dictionary salesmen."
Roy Munson - "You would be punctilious in assuming that."
danielyamseng
Jul 24, 2008 06:11 as a reply to  @ tmonatr's post |  #7
So even with DSLR cam ability to preview and reshoot, light meter still quite important in getting correct exposure.
Any attemp to correct exposure using photoshop will result lost of detail/hightlight, right?
With light metere this never happen. Just that when first time we use it we need to calibrate the light meter for once,right?
Is it possible to measure flash output without using sync cord?Say if I set it to manual flash output and set it say 1/2.
If I use the light meter to measure the fade under shades, I dont need to use fill in flash right?
egordon99
Jul 24, 2008 08:14 as a reply to  @ danielyamseng's post |  #8
If you are trying to shoot someone in the shade and not blow out the bright background, I fail to grasp how a light meter could POSSIBLY/REMOTELY alleviate the need for fill flash.....
The light meter will only spit out an exposure value (EV, basically ISO, shutter speed, f-stop) and possibly flash power to use, but you'd just plug them into your camera/flash and then take the picture like you always would. It basically tells you HOW to set the camera up, it doesn't magically increase the dynamic range of the sensor and/or change the intensity of the sun....
TMR ­ Design
Joined Feb 2006
Jul 24, 2008 08:15 |  #9
egordon99 wrote in post #5974633 (external link)
It doesn't? Uh oh ;)
Robert
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 24, 2008 08:49 |  #10
...replaced by the camera histogram?
Replaced by? No. BUT it's a great starting point & my meterS have been gathering dust since I went to digital & RAW.
Need an exposure crutch?
My 1-cent flash "meter" in images 5S & 6S.
Simple 2 Light Portrait Set-up
krb
Jul 24, 2008 09:09 as a reply to  @ egordon99's post |  #11
Beginners are the ones who take a picture, look at the histogram and reshoot. Professionals are the ones who use a light meter, grey card, etc. to get the shot right the first time.
danielyamseng wrote in post #5974113 (external link)
Preview and reshoot only works when you -can- reshoot.
-- Ken
Gear list
Bob ­ Sherwood
Joined Oct 2004
Jul 24, 2008 09:11 as a reply to  @ PhotosGuy's post |  #12
I've been in the studio business for almost 30 years with two full time operating studios. My wife and I are the main photogs. When we shot film, we always carried a minimum of 2 meters with us, plus the basic flash meters in the camera room. Since going digital in 2003, I haven't used the meters at all, if fact, I sold all but 1 to KEH.com in Atlanta. I still have s high end Gossen gathering dust in my field case. Guess I'll save it to put on display some day as an example of the "old stuff". The one thing I do use, especially in the studio is the white/black/grey target for setting exposure and white balance.
TMR ­ Design
Joined Feb 2006
Jul 24, 2008 09:15 as a reply to  @ Bob Sherwood's post |  #13
Hi Bob,
I've noticed that there is quite a bit of variation between all the so called 18% gray cards for exposure and targets specifically for white balance.
May I ask which brand and model targets you're using?
Robert
Glenn ­ NK
Jul 24, 2008 10:44 |  #14
TMR Design wrote in post #5972205 (external link)
I agree with this completely (when the face is the main subject).
My experience with flower closeups differs somewhat from this; I use a black velvet backdrop for some flowers (either to set them off better or get rid of a messy bg), and the light meter is hopeless in this situation.
In this case, much of the histogram will be bunched to the far left (the black area dominates), but there are small "tails" (for lack of a better word) that I adjust and ETTR.
These small tails are critical in getting the plant parts exposed properly without blowing the highlights (if I overexpose the highlights, the critics at NSN will immediately point it out - as well they should).
So for the black bg, I don't use the meter at all; the histogram takes over.
When did voluptuous become voluminous?
tmonatr
Jul 24, 2008 11:38 |  #15
Glenn NK wrote in post #5975447 (external link)
I don't understand why a light meter would be hopeless in this situation. Now let me first say that I do not have a light meter (although one is on the way from B&H as I type), and I have never shot under those specific conditions. But, if I understand correctly, the black background or white highlights of the flower will not "fool" the light meter (as it can your in-camera meter) and the meter is reading the actual light falling on your subject. Therefore the given exposure should be correct.
You obviously have a system that works for you, and that's great. I am just trying to gather information to improve my photography skills.
Tim
2,897 views & 0 likes for this thread, 16 members have posted to it.
2790 guests, 140 members online
