Thread started 24 Jul 2008 (Thursday) 15:21
Battery powered Strobes without power cords (not hotshoe)
pcunite
Jul 24, 2008 15:21 |  #1
Is there available a battery powered strobe that is 400ws and possibly 800ws?
When I say battery powered I mean a relatively small battery that can be attached to the strobe or light stand, not a vagabond type battery in which wires are running from the strobe to the ground. I may have 5 lights or more so profoto 3 or 4 heads battery packs don't help plus I don't want the wires running everywhere.
The ideal strobe will have the battery contained within or like the Qflashes easily clip able to the light stand. Thus we have only light stands placement, not cords laying about the ground.
Is the Qflash really a 400ws strobe? Pocket Wizards would be used to fire.
bobbyz
Jul 24, 2008 16:13 |  #2
Which wires go to the ground on vagabond II? You must be talking about the older version i.e. vagabond I
Fuji XT-1, 18-55mm
bobbyz
Jul 24, 2008 16:15 |  #3
OK I understand what you mean, no wires on the floor. Put separate battery for each strobe on its lightstand.
Fuji XT-1, 18-55mm
TeeJay
Joined Jun 2005
Jul 24, 2008 16:21 |  #4
have you considered the bowens and their "Travel Pak" battery?
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
René ­ Damkot
Jul 24, 2008 16:24 |  #5
Lumedyne. About the same as the QFlash.
200 Ws by default. You can stack a few boosters in between battery and generator to go up to 2400Ws.
If you don't want cables, you'ld need one pack for each head though. Not too economical.
If you regularly need that much power, I'd look into ProFoto however.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
pcunite
Jul 24, 2008 22:09 |  #6
How do you guys feel about a Sunpak 622 or Metz 76?
I will use a 60" umbrella or 24x24" softboxes usually. Yes I will put a small battery pack for these on the stands themselves. I don't really want a 9lb car type battery.
jgettis
Jul 25, 2008 08:20 |  #7
have you looked at the Norman 200c or the 400b
http://www.adorama.com​/NMA200C.html (external link)
http://www.adorama.com​/NMA400BML.html (external link)
John
pcunite
Jul 25, 2008 15:09 |  #8
This site is so interesting...
http://www.litelight.n​et/ (external link)
pcunite
Jul 25, 2008 18:34 as a reply to  @ pcunite's post |  #9
This is what I want my setup to look like...
2,040 views & 0 likes for this thread, 5 members have posted to it.
1460 guests, 137 members online
