PhotosGuy Photographing my Artwork
Thanks for the link, he has a sunless courtyard, so this sounds perfect.
Use your 50mm F/1.8 at a small aperture,,around F/11.. Ensure your all verticals are vertical and horizons are horizontal.. Use diffused available light ,,, inside by a window is good.. Camera on a 3pod,, ISO at around 200 will do..
One test shot I did was shot from a lower position, on the camera screen it looked ok, it really showed up on my pc.
I'd say your biggest concern is going to be color management. You will need to work closely with the printer to make sure your files will fit their requirements for good reproduction. This will probably mean using a good calibrated monitor, MacBeth Color Checker charts, and some post processing.
These pictures will only be put on a CD for him to send to prospective gallery's, if any prints are needed, they will go to a local studio near me, I really do need to look into colour management though.
So far I think I have the basic concepts
Tripod
50mm at f/11, ISO 200
MLU and self timer, I will be buying a remote unit A.S.A.P.
Metering mode, a little help here would be great
Focus points, center point or not ?
Flat, leveled painting, camera level set to mid point of painting
Set up in courtyard, is it still worth using my two 500w tungsten lights
There will be no glass in any frames, he will take them all out.
All shots in RAW.
Not sure if I'm missing something, cheers everyone.
Steve
