I have suspicions that my Tamron 17-50mm f/2.8 lens is softer than it should be, and in fact is asymmetrically so across either side of the image. I have a feeling that the left-hand side is generally softer at the 17mm end, whereas at 50mm the right hand side has a soft band going down it. I don't think this is a depth-of-field issue, since in some of my images objects towards the centre are very sharp over a range that includes blurred things to the right or left.
I did some testing with the following target:
![]() | HTTP response: NOT FOUND | MIME changed to 'image/png' |
The camera is about 2m from this, lined up perpendicular (checked with a Canon 50mm f/1.4 @ f/2.0 to be sure). The lens is at 50mm here. Now, I shan't bore you with the centre 100% crop as that was always dead sharp, but the following are 100% crops from the bottom left first, and top-right second.
Aperture f/4.0:
Aperture f/5.6:
Aperture f/8.0:
Surely it shouldn't be this soft at f/4.0, or asymmetrical. Of course, it's worse at f/2.8.
Hmm... looks like it's time to pack it off to Maidenhead. Again.
