I found it very hard to read the histogram under brightly lit environment. Even I tried to cover it with my hand, is still difficult to read.
Am I making a wise decision if I get a Sekonic 758 as to solve my problem?
danielyamseng Goldmember 2,053 posts Likes: 17 Joined Oct 2007 More info | Jul 27, 2008 19:50 | #1 I found it very hard to read the histogram under brightly lit environment. Even I tried to cover it with my hand, is still difficult to read.
yogestee "my posts can be a little colourful" More info | Jul 27, 2008 20:46 | #2 danielyamseng wrote in post #5995883 I found it very hard to read the histogram under brightly lit environment. Even I tried to cover it with my hand, is still difficult to read. Am I making a wise decision if I get a Sekonic 758 as to solve my problem? Nope,,,,you still need to meter your subject via the camera's meter.. I have found the current crop of DSLRs meters are very accurate.. Nearly all metering problems arise from user error and inexperience.. Jurgen
DocFrankenstein Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | Jul 27, 2008 21:33 | #3 yogestee wrote in post #5996224 Nope,,,,you still need to meter your subject via the camera's meter.. I have found the current crop of DSLRs meters are very accurate.. Nearly all metering problems arise from user error and inexperience.. IMHO handheld meters are a waste of time unless the lighting conditions are very tricky.. With experience you will be able to access the scene/subject, where to meter and where approximately the histogram will lie.. Don't rely too much on chimping.. Funny. National Sarcasm Society. Like we need your support.
FlyingPhotog Cream of the "Prop" 57,560 posts Likes: 178 Joined May 2007 Location: Probably Chasing Aircraft More info | Jul 27, 2008 21:39 | #4 Gotta love human interpretation... Jay
I'm trying to find a solution on the difficulty reading the histogram under an extremely bright condition i.e desert and the beach.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 28, 2008 01:13 | #6 yogestee wrote in post #5996224 Nope,,,,you still need to meter your subject via the camera's meter..... NOT. The camera's meter does not have to be part of the equation at all. Skip Douglas
Yeah that's right Skip. In you opinion, Am I making the right decision?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 28, 2008 06:34 | #8 danielyamseng wrote in post #5997863 Yeah that's right Skip. In you opinion, Am I making the right decision? I often choose to use my Sekonic L-358 with the camera set to manual mode. Most often, I use the meter in incident mode (reading the light falling on the subject rather than light reflected from it). I frequently find this both faster and more accurate than using the camera's built-in meter. So, yes, I think you would be making a wise decision to obtain a good handheld meter. Skip Douglas
yogestee "my posts can be a little colourful" More info | I think everyone misread my reply.. What I meant to say is you still have to meter the subject before you shoot and check the histogram.. A handheld meter although a very useful tool is a substitute for the camera's inbuilt meter.. Jurgen
PhotosGuy Cream of the Crop, R.I.P. More info | Jul 28, 2008 09:20 | #10 This works for me as a starting point. First set the f-stop & shutter speed you need. Then adjust the ISO. FrankC - 20D, RAW, Manual everything...
TheHoff Don't Hassle.... 8,804 posts Likes: 21 Joined Jan 2008 Location: Vancouver, BC More info | Jul 28, 2008 09:25 | #11 danielyamseng wrote in post #5997863 Yeah that's right Skip. In you opinion, Am I making the right decision? A Sekonic 758 is likely overkill for what you need. If you do a lot of multi-light flash setups then it is perfect but if you just want a good light meter you can get away with spending $100 or $200 instead of $450. The Sekonic L-398 is based off of a classic design that has been used for decades and does not require any batteries. ••Vancouver Wedding Photographer
Jul 28, 2008 10:37 | #12 Just short of the Zone System, an Incident meter (used correctly) is the most accurate way to get a correct exposure. I've used the Incident metering method for over 40 yrs & it has never let me down. On the other hand I've let it down occasionally by using it incorrectly when in a hurry. Tim
yogestee "my posts can be a little colourful" More info | Jul 28, 2008 18:47 | #13 Tixeon wrote in post #5999714 Just short of the Zone System, an Incident meter (used correctly) is the most accurate way to get a correct exposure. I've used the Incident metering method for over 40 yrs & it has never let me down. On the other hand I've let it down occasionally by using it incorrectly when in a hurry. Very accurate.. I came up using old blue cell Sekonics and Gossens.. Primitive by today's standards but still accurate.. BTW,,we had a draw full of stuffed Sekonics and Gossens which had been dropped dislodging the needle.. Jurgen
How about Sekonic 358?Does it serve my purpose? It is portable enough for me to backpacked and travel with it?
DocFrankenstein Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | Jul 28, 2008 22:19 | #15 danielyamseng wrote in post #6003586 How about Sekonic 358?Does it serve my purpose? It is portable enough for me to backpacked and travel with it? Well, even the largest multimeter like 758 is about 300 grams. National Sarcasm Society. Like we need your support.
| Latest registered member was a spammer, and banned as such! 2886 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
