Thread started 28 Jul 2008 (Monday) 11:22
Reflectors
v35skyline
Jul 28, 2008 11:22 |  #1
Let me start off by saying that I don't mind spending the extra dollar on quality products, but won't if I don't have to.
I understand why one would spend top dollar for glass, strobes, etc. I know because I've already done so!
My question for you is, are all reflectors equal? That is, what difference am I going to see (besides build quality) if I choose to go with a cheap collapsible reflector versus an expensive name brand collapsible reflector. I want to pick up a good size 5-in-1 reflector for outdoor portraiture use. Can anyone recommend what size/brand I should be looking at? Links would be nice!
Thanks!
X100s | X-Pro1 | X-T1 | XF 14 | XF 18 | XF 35 | XF 56 | XF 60 | XF 10-24
Gear List & Feedback
cdifoto
Don't get pissy with me
Jul 28, 2008 11:23 |  #2
I got mine on eBay. Cheaply made, sure, but I don't know how much better a named brand jobby would really be. $15 vs $60...
Mine's just gold/silver though, not a 5-in-1.
cdifoto
Jul 28, 2008 11:30 |  #3
This one might be worth a look:
http://cgi.ebay.com …em&rd=1&item=13​0240941600 (external link)
Same seller as my smaller 2-sided.
v35skyline
Jul 28, 2008 11:30 |  #4
cdifoto wrote in post #5999988 (external link)
That's the honest answer I was hoping for. Like I said, I have no problem with spending more money on something if it's worth it. But if I'm only going to be spending more money so I can have the name behind it, then no thanks!
I'm not specifically looking for a 5-in-1, but that's the first thing I saw on eBay. :)
cdifoto
Jul 28, 2008 11:32 |  #5
Well here's what I have:
http://cgi.ebay.com …em&rd=1&item=35​0082472273 (external link)
I didn't go with a 60" (or bigger) right off because I wasn't sure if I'd need, want, or be able to handle something that large. It's not made well, but it's not made poorly either. In other words, it works.
v35skyline
Jul 28, 2008 11:44 |  #6
cdifoto wrote in post #6000047 (external link)
Do you find the 27"x47" is large enough for full body applications? Now having owned this one, would you consider getting a larger one?
cdifoto
Jul 28, 2008 11:45 |  #7
I have no idea. I haven't had a chance to use it for that yet. So far my only real-world application has been blocking the sun from a client's eyes. :lol:
In all seriousness, I don't think it'd be big enough for that, unless it's a child, short adult or the adult is sitting/kneeling/crouc​hing, etc. If you can back away with the reflector a ways it might work when the sun is strong, but you need to be close most of the time with a reflector...especially if the sun isn't right behind the subject. I don't have enough experience with it to know all the limitations though - just theory. I'm just basing it on softboxes...generally you need the softbox to be as big as your subject, if not bigger. So if the person is 6' tall you need a 6' softbox. I presume it's the same with reflectors.
v35skyline
Jul 28, 2008 11:49 |  #8
cdifoto wrote in post #6000137 (external link)
By it, do you mean the 27x47 or the larger 40x60 reflector?
cdifoto
Jul 28, 2008 11:50 |  #9
Sorry I meant the 27x47. I think you'd need the 60" or even bigger if you can get one. This is the one I have on my eBay "wishlist" for if/when I get into using reflectors frequently: http://cgi.ebay.com …em&rd=1&item=20​0216240085 (external link). Different seller though so I'm not 100% certain on the quality of it. I expect it's similar to the other one I do have.
lulugus
Jul 28, 2008 11:55 as a reply to  @ cdifoto's post |  #10
Cdifoto - newbie question: In your reflector set up, how would you attach the reflector onto the tripod behind it? Just wondering if there would be a simple way I could attach one of thes to one of my light/umbrella stands without having to buy a bunch more hardware I'd have to lug around.
gracias
cdifoto
Jul 28, 2008 12:01 |  #11
I never figured out a super simple & cheap way, so I bought a reflector holding arm (external link) and grip (external link). He's got a combo listing here (external link) but I think it'd be cheaper to bid out since they almost always end at the opening bid and you'd pretty much just be paying the high shipping costs. In other words, you'd save about 10 bucks by being patient.
It's extra hardware but it's really not that heavy and it's a godsend. The grip itself weighs a little bit but it's not bad enough to prefer leaving it at home, in my opinion.
lulugus
Jul 28, 2008 12:36 as a reply to  @ cdifoto's post |  #12
Thanks!
I've tried jerry-rigging with clips and stuff but it's a pain, so I'll probably purchase this.
cdifoto
Jul 28, 2008 13:54 |  #13
I used elastic bands hot-glued to foam core back when I was using that stuff and it worked ok, but when I invest in proper equipment (no matter how inexpensive), I prefer to do things as designed. There's usually a reason for it. lol.
Titus213
Jul 28, 2008 15:02 |  #14
I use a 5-in-1 from Amvona.com - 40x60 was $45. I just checked and they don't seem to carry them any more....It's a nice size for the work I do.
Dave
Perspiring photographer.
M ­ Powered
Jul 28, 2008 15:11 |  #15
IMO reflectors are all the same. The question is how EASY do you want it to paint your subject with the light? Sun Bounce are stretched on an aluminum frame and the ease of use that comes with it are remarkable.
Cheaper flimsy reflectors will suffice, but you will need an assitant and quite often you will have to fight to get it to reflect the proper light.
Heres a shot with a cheap $20.00 reflector
Canon 5D Mark III | EF 24-70 f/ 2.8 L II
http://www.keslertran.​com (external link)
http://keslertran.tumb​lr.com (external link)
3,231 views & 0 likes for this thread, 14 members have posted to it.
Reflectors
2726 guests, 150 members online
