Thread started 29 Jul 2008 (Tuesday) 00:01
Can I calibrate an apple cinema display
1kerry
Jul 29, 2008 00:01 |  #1
Hi guys, I just bought an Apple Cinema Display, but I use a PC, and dont know if I can calibrate it because I only have option to change the brightness but not color, contrast, etc.
I read in the manual, and it says that I need to go to "APPLE>SYSTEM PREFERENCES, AND CLICK DISPLAYS" in order to adjust resolution, brightness, color, etc.......so If I have a PC do Im still able to change the settings or just the brightness from the monitor.?????
Thanks!
Canon 5D MKII / Canon 60D / 35 f1.4L / 24-105 f4L IS / 15 f2.8 fishy / 28-135 f3.5-5.6 IS / 85 f1.8 / 50 f1.4 and my next lens will be a 135 F2.0L FB: https://photography-on-the.net …ead.php?t=28608​&page=1912
Damo77
Jul 29, 2008 00:08 |  #2
Barely. You're right, all you have is the brightness adjustment.
However, it can of course be profiled, and you'll get good results.
Do you have a monitor calibration device?
Damien
Website (external link) | Facebook (external link)
1kerry
Jul 29, 2008 00:12 |  #3
Yes, I have a Spyder2express Color Calibration System that I have never used, do Im still able to calibrate the CINEMA DISPLAY, even though I have a PC???
thanks in advance
Damo77
Jul 29, 2008 00:15 |  #4
Yeah, the software that comes with the device should work on either platform. And the device doesn't care what kind of monitor it is.
Damien
1kerry
Jul 29, 2008 00:17 |  #5
Oh , I see, then after a year I will know use the SPYDER, because I only have 15 days to return merchandise from BH, and tomorrow is the deadline, and I cant edit photos with the current setting, lets see if I can calibrate it...
thanks a lot for your help.
Damo77
Jul 29, 2008 00:18 |  #6
Let us know how you go.
Damien
1kerry
Jul 29, 2008 01:46 |  #7
OMG!! I cant install the spyder2express, I have WINDOWS vista, dont know if that is the problem.....ARGHH!!! its says it can locate the device, and I already delete the ADOBE GAMMA,
can some one tell me if theres any other way to change the contrast, color, etc of this monitor on a PC????
1kerry
Jul 29, 2008 02:29 |  #8
well, i download the 64bit file for vista, and finally calibrated the monitor, but got too much red on the pics, if compare it with the prints....
René ­ Damkot
Jul 29, 2008 04:41 |  #9
And are you sure the prints are correct?
Some links to check the monitor in the link from my sig.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
bohdank
Jul 29, 2008 06:46 |  #10
What Rene said.
Are you using printer profiles. At least the ones that came with my, now old, Epson 2200, has pretty good profiles provided by Epson. You can always get your printer profiled for each type of paper you use.
Isn't photography fun..... ;-)a
Moschero
Jul 29, 2008 09:18 as a reply to  @ bohdank's post |  #11
I don't know if you have access to video adjustments on a system with on board video (on board being the video chip built into the motherboard) but on my computer I have a PNY video card with a Nvidia GeForce video chip (the same one apple uses) and the drivers that ship with it give you access to the RGB values and gamma so thats the way I set up my cinema display with the spyder and it's doing fine.
EOS 20D, EOS 5-D MK2, 50 MM 1.4, 24-70 MM 2.8 L, 17-40 M.M. F4 L, 70-200 F4L, 300 F4 L IS, 580 EX, 430 EX, Hensel Integra Pro Plus 500 W.S. X 3, ST-E2 Transmitter, BG-E2 Grip, Epson R1800 Printer and a credit card that has a nervous twitch
Gerald ­ McClaren ­ Sr.
Jul 01, 2010 21:31 as a reply to  @ Moschero's post |  #12
Hi!, 1Kerry, I'm having the same problem. I had bought an Apple Cinemaview 24" HD Display for my photo restoration. I have an Hp Pavillion pc and would like to know how did you adjusted the brightness on your Apple Cinema Display. My monitor is approximately one month old and I haven't calibrated it as yet. I do have the Spyder Pro 2 calibration device. I had figured that since the monitor is very new, I don't need do any kind of calibration. I would very much appreciate some information from you since we both have a pc connected to the apple displays.
Gerald Sr.
René ­ Damkot
Jul 02, 2010 03:06 |  #13
Gerald McClaren Sr. wrote in post #10463614 (external link)
Wrong.
Use the spyder.
You probably need to turn the brightness of the display down to at least half way from factory default.
Aim for 120Cd/m^2 or less. (IIRC, that's About EV 10 for the photographers among us ;))
Mar 20, 2011 00:44 as a reply to  @ René Damkot's post |  #14
Hi!, Rene' there are no brightness adjustment controls or knobs on my apple cinema view 24" Hd display. I had calibrated this monitor with the Spyder 2 and had used backlight. The problem is how can I adjust the brightness on this kind of display.
Gerald Sr.
Damo77
Mar 20, 2011 02:01 |  #15
The slider is in the display control panel.
Damien
6,749 views & 0 likes for this thread, 8 members have posted to it.
2931 guests, 159 members online
