Any recommendation for a high quality light weight tripod for back pack?
danielyamseng Goldmember 2,053 posts Likes: 17 Joined Oct 2007 More info | Jul 29, 2008 09:41 | #1 Any recommendation for a high quality light weight tripod for back pack?
jhom Goldmember 1,320 posts Joined Apr 2007 Location: Dallas, TX More info | Jul 29, 2008 10:50 | #2 You might want to consider a 1 or 2 series Gitzo with a Markins Q3 ballhead. If you do a search on this forum, you will find several threads regarding this setup. Jim
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 29, 2008 12:37 | #3 Heres my review on about the best travel tripod solution possible [Gear List | Flickr
Tareq "I am very lazy, a normal consumer" More info | Jul 31, 2008 04:27 | #4 I recommend Gitzo 1 or 2 series as well, i have GT1540T, amazing lightweight and high quality, and now i am waiting my Q3T to play with in travel. Galleries:
fishfoto -Krazy Glue- 840 posts Likes: 1 Joined Mar 2008 Location: Live: HVN Work: The World More info | Jul 31, 2008 12:51 | #5 What is the size you'd like? There are some excellent full-size tripods available that are durable and light weight.....and there are some very compact travel tripods that can holda full-size body, most hand-holdable pro lenses and be stuffed in your waist pack as you travel. - Fish
I'd prefer the small one and weight less than 3lbs.The tripod should be able to hold a load of 10lbs.
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Jul 31, 2008 22:18 | #7 danielyamseng wrote in post #6023676 I'd prefer the small one and weight less than 3lbs.The tripod should be able to hold a load of 10lbs. BTW what's the difference of carbon fiber and Basalt based tripod? The ultimate lightweight setup: Gitzo GT0530 + Markins Q3
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | Jul 31, 2008 22:24 | #8 I looked at the Gitzo options and found them out of my budget; I then found Feisol's range of tripods and now own the CT-3442 and Markins M-10 ballhead. Fantastic combination - the tripod goes to above my head height with no column extension (I'm 172cm tall though, so not a giant) and weighs 1kg and <19" folded, including head. Gear Listhttp://www.codastudios.com.au
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 31, 2008 22:38 | #9 Wow those legs are lighter than the 1541T! Cheaper too. Just doesnt fold down as small or hold as much weight. If those arent a big deal then this is a VERY cool setup! [Gear List | Flickr
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Jul 31, 2008 22:57 | #10 ben _ this setup work outstandingly well hiking through out Glacier Nat'l Park recently. Strapped to my Gregory Z30 pack you hardly knew it was there. I've been quite pleased at its stability for such a compact setup as it holds the 40D and 70-200 f/4L with ease.
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 31, 2008 23:20 | #11 Tsmith wrote in post #6024005 ben _ this setup work outstandingly well hiking through out Glacier Nat'l Park recently. Strapped to my Gregory Z30 pack you hardly knew it was there. I've been quite pleased at its stability for such a compact setup as it holds the 40D and 70-200 f/4L with ease. Im sure it did! That is so light weight! [Gear List | Flickr
bmwm3csl Member 78 posts Joined Sep 2007 Location: Houston, TX More info | Aug 01, 2008 16:42 | #12 For the money, the Feisol CT-3441S is hard to beat.
| Latest registered member was a spammer, and banned as such! 2797 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
