Thread started 29 Jul 2008 (Tuesday) 12:54
which bag? crumpler 7MDB or slingshot 200 AW?
LeoChanPhotography
Jul 29, 2008 12:54 |  #1
hey guys!
i'm wondering which bag you'd recommend for me to use. i want something easy to use, so i can switch lenses without having to put my bag down, something that won't be too heavy (my shoulders are normally really tight, so i'm a bit unsure about a shoulder bag with so much gear) and something that'll offer good protection for my stuff. i'm debating between the crumpler 7MDB or the slingshot 200. the slingshot seems to be better for distributing the weight better on the body, but it doesn't seem like you can easily switch lens without putting down the bag first (from what i understand, if you have the bag on, and open it fully, the lens would fall out!! yikes).
this is a list of my gear so far:
canon 40d
17-85mm IS
50mm 1/8
580ex II
55-250mm IS
70-200mm F/4
i'm debating on either getting rid of the 55-250 or the 70-200mm right now.
which bag would be better? thanks!! :)
SMP_Homer
Gallery: 29 photos
Jul 29, 2008 13:18 |  #2
I have the Slingshot 200, and if you re-organize the dividers, you can make everything accessible to the side.
I have a 40D with 17-55 2.8 mounted, a 70-200 f4 IS with hood reversed, 50 1.8 and 85 1.8 sharing 1 slot, and a 580EX. There's room for another flash or lens. All this is in the main compartment. I've once had a 70-200 f4 IS and a 70-200 2.8 IS (borrowed) in this bag as well, along with all other lenses (just no hoods).
With all my gear, this bag is just over 9 lbs. I don't mind this too much if I'm travelling (aka is not on my back all that much) but if I'm walking around or hiking, it's really too much for 1 shoulder. But if the camera (& lens) is in my hands, the rest of the gear doesn't feel all that bad on 1 shoulder...
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
Haru
Jul 29, 2008 13:56 |  #3
The crumpler itself is not a lite bag. Add lenses, flash, camera, accessories, it starts to weigh a lot. If you have problems with your shoulders I would not suggest buying it.
Gear: Stone slab, hammer, chiseL, and crushed barries.
eelnoraa
Jul 29, 2008 14:12 as a reply to  @ Haru's post |  #4
I will advice AGAINST the Slingshot 200. It actually really sucks at weight distribution. I had one for 6 monthes, and now sold. The major problem with the design that that you can only wear on one shoulder, cannot switch side. With shoulder bag like 7MDH, at least you can switch shoulder. The bag is quite large and bulky externally but feel small in use. You gears will not all fit in the main compartment, some has to go on the top. And it will not fit body+70-200F4L attached.
If you like the idea of side access, at least take a look at the lowepro fastpack instead.
eel
5Di, 5Diii, 28, 50, 85, 16-35II, 24-105, 70-200F2.8 IS
SMP_Homer
Gallery: 29 photos
Jul 29, 2008 14:29 |  #5
eelnoraa wrote in post #6007899 (external link)
eel
Simply not true.
My 40D with a 70-200 f4 IS will fit when attached. It's the very limit of what this bag will accept, but it will fit. One of my requirements when I got this bag is that I could put away my camera into this bag regardless of which lens is attached.
_aravena
Jul 29, 2008 15:04 |  #6
Check out my review of the 7MDH. It's definitely large enough for what you want. I love mine will never give it up. Perfect for weddings at it's stylish and a conversation piece (orange and blue ;)).
If you do want a side loading bag check out the Fastpack. I hated the 200AW.
Last Shot Photography
andrew748
Jul 29, 2008 15:20 |  #7
eel
i'm with eelnoraa on this one.
i have the aw200 and now after 8 months of owner ship it is starting to lose it's appeal, my main issue is space,
i carry the 40d, a 430ex, the nifty, my 17/85 kit lens a couple of cf cards a spare canon battery, 24 spare AAs,stofen diffuser, a mini tripod, extension tubes, assorted cleaning gear inc a small rocket blower, remote release, off cam flash cable and my bag is full.
now i have the 70-200 2.8L is and a monopod i'm stuffed.
and i'm soon to add a 2x extender.
if you can travel light then get one, when you start adding kit it really isn't big enough and the weight distubution isn't great as previously stated.
i'm heading in this direction for my next back pack
http://products.lowepr​o.com …Vertex-200-AW,2073,16.htm (external link)
www.andrew748.com (external link)
drawers full of slightly mouldy Leica kit, a couple of newish Japanese bits, nearly every cheap Chinese flash modifying toy ever sold on ebay and sooooo many batteries the TSA have me on a no fly list ;)
Timphoto
Creme de la Curmudgeon
Gallery: 208 photos
Jul 29, 2008 16:37 |  #8
I have the Lowepro AW200 and looked at several different shoulder bags including the Crumpler 7MDB. I settled on another Lowepro - the Stealth Reporter D400AW - primarily because I wanted room for a second camera body in the future, but also because this bag has a lot of features and is weather resistant.
I'm keeping the AW200 because it fits perfectly inside of one of my motorcycle side bags, and I generally don't drag all my gear along on my motorcycle trips.
The D400AW will hold all my gear comfortably, has excellent water protection, a top zipper that makes access quick and easy, and lots of pockets to hold the small stuff.
All of the gear listed below fits inside with room to spare. You can also make it a softer sided bag by removing some of the inserts. If you're not looking for something that big, there are other sized Lowepro Stealth Reporter bags. Its worth a look.
Tim
40D, BG-E2N, EF-S 10-22,EW-83E hood, EF 24-105 f4L w/ hood, EF 70-200 f2.8L IS w/hood, EF 1.4x II, 580 EX II, TC8N03 remote, EF-12 II, 3 CF cards, USB-2 CF Reader, 4 filters, Giotto rocket, Canon battery charger, 6 AA li-ion batteries with charger, digital voice recorder, pens, paper and a 40D Manual.
Tim
LeoChanPhotography
Jul 29, 2008 21:27 |  #9
hmmm, would the 6 million dollar bag work for my needs then? :0
_aravena
Jul 29, 2008 21:28 |  #10
It would for now.
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jul 29, 2008 22:13 |  #11
I have the 5, 6, and 7 million dollar home's. Perfect solution as I have the perfect size bag for whatever I need. Although I shot a wedding last weekend and it made me yearn for a larger bag to fit several bodies and all my stuff.
Doc Klepper in the USA
I
_aravena
Jul 29, 2008 22:22 |  #12
Time to get the Bazillion ;)
hsma
Jul 30, 2008 02:00 |  #13
I have the 7 MDH and its getting cramped with all the gear in there now. Reorganizing the dividers I was able to fit my xti gripped + 50 and my 40D gripped + 17-55 easily. Having enough room to put my 580ex and 70-200 2.8 in their own divided sections.Overall Im satisfied with all the gear + accessories I can put in there. It does get heavy but the shoulder strap is comfortable enough and you can always switch shoulders.
40D + Grip, XTi + Grip, 70-200 2.8 IS, 17-55 2.8 IS, 50 1.8,
580 EX II, 430 EX
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jul 30, 2008 06:54 |  #14
The Slingshot 300AW is a lot better for weight distribution because it has a load belt; correctly adjusted almost all the weight is on the hips. I can carry a lot of kit in this all day with no problems, it is large enough to take a 300/4 IS with 1.4X mounted on a 20D. http://www.zen20934.ze​n.co.uk/photography/my​bags.htm#300AW (external link)
I still sometimes use my Slingshot 200AW when I am only taking small amounts of kit.
I would be wary of any pack without an effective load belt even if it has two shoulder straps.
As noted early, organise the dividers so the kit can be accessed from the side, it took me a while to wake up and smell the coffee on that one.
Macrophotography by LordV
andrew748
Jul 30, 2008 06:58 |  #15
Lester Wareham wrote in post #6012340 (external link)
all tips and tricks gratefully accepted on that :D
3,157 views & 0 likes for this thread, 10 members have posted to it.
2799 guests, 167 members online
