Is there a difference between the two? Would the umbrella provide a larger area of flash because the diffuser confines the flash?
bChan Member 178 posts Joined Apr 2008 More info | Jul 29, 2008 17:22 | #1 Is there a difference between the two? Would the umbrella provide a larger area of flash because the diffuser confines the flash? Canon REBEL XTi + BG-E3 Battery Grip:
ANGUS Cream of the Crop 6,897 posts Joined Apr 2007 Location: Sydney, Australia... More info | Jul 29, 2008 17:35 | #2 The difuser, if pointed straight at the subject (IE: Not bounced) does NOT difuse the light. An umbrella produces a larger source and therefore is a better difuser. Angus
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 31, 2008 13:38 | #3 Size matters. A Stoffen does NOTHING to change size of the apparent light source, unless it is bouncing light from adjacent walls and ceilings! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
DavidRossberg Member 93 posts Joined Feb 2008 More info | Jul 31, 2008 16:58 | #4 Although in the rare occurrence of your flash not having any type of wide setting (theoretically speaking, like if the motor is busted while zoomed out!) you could actually benefit from having a diffuser slapped onto your flash behind a shoot through umbrella! =) Treat your friends as you do your pictures, and place them in their best light.
jr_senator Goldmember 4,861 posts Joined Sep 2006 More info | Jul 31, 2008 17:19 | #5 |
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jul 31, 2008 18:09 | #6 The stofen is called the omniBOUNCE for a reason. Unless you bounce from a wall or ceiling it does nothing except waste flash power. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 31, 2008 20:14 | #7 tim wrote in post #6022348 The stofen is called the omniBOUNCE for a reason. Unless you bounce from a wall or ceiling it does nothing except waste flash power. .... and the omni part means that it puts light out in all directions instead of directing it toward the subject or a single planned bounce surface. Again, this creates a serious waste of light (and battery energy) in many situations. Skip Douglas
| Latest registered member was a spammer, and banned as such! 2724 guests, 150 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
