Thread started 31 Jul 2008 (Thursday) 05:20
Why I want a 1DIII
AdamC
Jul 31, 2008 05:20 |  #1
So last night my son had a soccer game. Being just a small local soccer club, the lights for night games aren't great - which is to say they're fine for playing soccer, but not so great for shooting the games. In a vain attempt to get any sort of shutter speed from the trusty 400D, I had it at ISO 1600 and underexposed a whole two stops, while the 70-200/4 was wide open as always. Basically shooting at -2 and pushing it back in PP == red snowstorm :)
Seeing as the photos were rubbish anyway, I thought I might try something a bit different - I converted them all to B&W and left in the grainyness and excessive contrast, for a more 'arty' or, dare I say it, even 'edgy' look. What do you think? Does it work? Or is it just rubbish?
#1
#2:
#3:
#4:
#5:
#6:
#7, my first ever selective-colour picture:
[gallery (external link)|gear|flickr (external link)|blog (external link)]
cdifoto
Don't get pissy with me
Jul 31, 2008 05:37 |  #2
They look good to me this way. However, what you really need is a faster lens...f/4 is slow as for that kind of thing. A 1D III wouldn't hurt you but it wouldn't help you much if you use the same lens in those conditions. You could get away with a 40D and 70-200mm f/2.7 IS and be a head quite a bit...in both image quality and expense. You're better off getting an f/2.8 lens to expose ISO3200 properly than underexposing ISO1600 by two stops.
Of course if you can afford f/2.8 AND the 1D III you'd be golden.
Ultimate ­ CC
Jul 31, 2008 05:39 |  #3
i think you did a good job with what you had...i tool used to shoot with a 400d before i got my 1dmkIII, now i can't image how i shot without it...the high iso and unreal af system make sports so much easier...i don't miss nearly as much as i did with the 400d when 3fps limited some of the shots that i now can capture with the 10fps...why don't you look at a 1dmkii or something if you don't want to drop 3500 right now..., even the 40d is awesome for sports and has pretty darn good high iso...
My Gear And For Sale Items
www.danhonovich.com (external link)
www.danhonovich.blogsp​ot.com (external link)
AdamC
Jul 31, 2008 05:55 as a reply to  @ Ultimate CC's post |  #4
Thanks guys. 1DIII + 70-200/2.8 is my dream setup for soccer - I figure F/2.8 would be nicely complimented by ISO 3200 and good AF for low light stuff. Unfortunately my gear budget is $0 at the moment so I'm just practising "make the most of what you have." :)
Edit:
cdifoto wrote in post #6018621 (external link)
Actually, that's interesting. A while back I was able to shoot most of another night game with a borrowed 300/2.8 on my 400D, and found it didn't really help at all. Granted the lighting at that field wasn't as good as the one last night, and you did suggest teaming it up with the 40D, but after borrowing the 300/2.8 I concluded that F/2.8 still wasn't nearly enough.
Uglyone
Jul 31, 2008 07:19 as a reply to  @ AdamC's post |  #5
I have the same problem, and went down this track.
40D + 135mm F/2 L, I even some time use it with a 1.4tc, makes it f/2.8 and 189mm.
At ISO 3200 I can get 1/320 shutter speed @f/2.8
Works a treat under your average football field lighting. And the 135mm focus very well.
40D, 300D, 24 - 70mm L f/2.8, 135mm F/2 L, 50mm f/1.8, 70 - 300mm f/4.5 - 5.6 IS USM
flickserve
Jul 31, 2008 07:32 |  #6
AdamC wrote in post #6018660 (external link)
That must be really bad light. Are those your usual conditions?
Alexajlex
Jul 31, 2008 07:38 |  #7
Reality wise you can get ISO1600 underexposed by 2 stops (ISO6400) with the XTi and have minimal noise. Lighting of the subject plays a huge role in this.
Gear: 40D | XTi gripped | 85 1.8 | 50 1.8 | Sigma 20 1.8 | Canon 55-250 IS | Tamron 17-50 2.8 | Canon WD-58 WA Converter | 580EX II | Sunpak 383
"Amateurs worry about equipment, pros worry about money, masters worry about light..."
Paul ­ S
Jul 31, 2008 07:58 |  #8
If you have a flash read on.
https://photography-on-the.net/forum/showthre​ad.php?t=375847
BTW the 40D with a 2.8 lens and flash would also serve you well.
Profile / Maxpreps (external link)  (external link)
beezwax
Jul 31, 2008 08:01 as a reply to  @ Paul S's post |  #9
i dont see anything wrong with those pics other than being small
MYGEAR
GULFCOASTTUNDRAS.com (external link)
AdamC
Jul 31, 2008 08:18 |  #10
Uglyone wrote in post #6018890 (external link)
hmm, actually that's not as silly as it sounds, once you throw the TC into the mix, although I'm not sure I'd like shooting soccer with a prime. A quick check says that dollar wise, that'd add up to more than the 70-200/2.8 non-IS though..
flickserve wrote in post #6018932 (external link)
Thank goodness no! He normally plays in the middle of the day on Saturdays, but due to weather canceling a couple of games, they've had a couple of midweek makeup games.
Paul S wrote in post #6019059 (external link)
Unfortunately no flash yet! I'm not sure where I stand in the flash-at-night-sports-games debate, but I'm not sure I'd want to do it.
beezwax wrote in post #6019069 (external link)
Thanks! You can click the images for larger and EXIF.
cstewart
Jul 31, 2008 09:56 |  #11
Yes, if you only have a camera that goes up to 1600 ISO. As suggested with a 3200 ISO camera and a 2.8 lens, you would have a situation much more suited to the light you had.
Please Check Out My Work at:
Independent Sports News (external link) -- Sports Shooter (external link) --Web Site (external link) -- Facebook (external link) -- iStockphoto.com (external link)--Twitter (external link)
Gear: 1DX; 1D4; 70D gripped; 40D gripped; ; EFS10-22; EFS 17-55; EF 16-35; EF 135; EF 70-200 II; EF 300; EF 1.4X II Extender, 580 EX II Flash
bobbyz
Jul 31, 2008 11:15 |  #12
200mm is quite small for soccer, IMHO but then I use 500mm f4. 400mm f2.8 is the ideal soccer lens paired with 1 series.
Fuji XT-1, 18-55mm
geharp
Jul 31, 2008 13:05 |  #13
Love the selective color....really cool
George
GBRandy
Jul 31, 2008 14:47 |  #14
+1 Good advice
GBRandy
GearList | Nikon 1977 - 2007 |
Zander ­ Albertson
Aug 01, 2008 11:19 |  #15
When you get the $, sell the 70-200 4 and buy the 70-200 2.8 non-IS. That will give you one stop. Then buy the 40D, which goes to 3200 very cleanly relative to what you have now, and there you have your 2 stops. Looks like you have your shots down, your equipment is just failing you.
Keep practicing until you get the 70-200 2.8!
Editorial Photographer, Canon Digital.
4,918 views & 0 likes for this thread, 24 members have posted to it.
Why I want a 1DIII
2811 guests, 138 members online
