Thread started 31 Jul 2008 (Thursday) 09:32
Spot meter stupidity
reneethomas
Demoted and banished by the TF
Jul 31, 2008 09:32 |  #1
Okay I am really confused and I am sorry for such a stupid question. Spot meters- are they used when using a flash or can it be used in natural lighting? I am getting frustrated being told my pictures look underexposed when my camera meter is reading correct exposure. However in looking up spot meters I keep ready about flash. Is there a model that is good for reading for just ambient light?
Thanks so much for the help!!
Racquel is my real name
Gear List Flickr (external link) BugGuide (external link)Facebook (external link)
Mike
ugly when I'm sober
Gallery: 51 photos
Jul 31, 2008 09:50 |  #2
Spot meter - do you mean the one on the camera? That can be used in all lighting types.
Oh - I just re-read, you mean the hand-held meters. Never used one but they are also called incident light meters, I think.
Also, don't let the camera tell you that the exposure is correct. If you have a range of different tones the camera will take an average reading from across the scene. Best bet is to stick it in Manual and chimp until you are happy with your exposure and use the histogram to check that you are not clipping the highlights.
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
yogestee
Jul 31, 2008 10:10 as a reply to  @ Mike's post |  #3
In built camera meters are very easy to fool.. Usually strong backlighting is the main culprit.. If you meter for a subject which is strongly backlit and rely souly on your meter there is every chance your subject will be underexposed.. Experience will tell you to overexpose to what your meter tells you by 1 to 2 stops.. On the other side of the coin if you meter say an African-American skin tone against a black background your exposure will be overexposed by about 1-2 stops..
All meters are calibrated to read what is call 18% Reflectance Grey,, for all intents and purposes a midtone grey irrespective of what colour the subject is,, usually.. Strong reds can effect the metering..
Thats the advantage of shooting in Manual Mode and being able to guestimate where your meter should lie.. Spot meters are quite accurate where you meter exactly the subect.. Incident meters are even more accurate where you meter the light falling on the subject not the light thats being reflected.. Spot and Incident meters are both available in flash and available light meters.. Many of the topshelf models measure both..
Jurgen
chtgrubbs
Joined Jul 2003
Jul 31, 2008 11:10 |  #4
Spotmeters measure a very small area (usually 1%) of the subject. They all measure continuous light, and newer models will read flash as well. They are the most difficult type of meter use properly. Usually several meter readings are made and careful calculations of correct exposure are made giving consideration to where on the range of light to dark the readings fall on. The classic exposure system which lends itself to the spotmeter is the Zone System.
If you need a handheld meter for general work then I would suggest an incident meter which measures the actual level of illumination rather than subject reflectance. Your biggest skill advancement would probably be to learn to use the histogram to check your exposure.
pprice
Jul 31, 2008 17:25 |  #5
So, if you have a backlit subject and you use your cameras spot meter to take the light from the front of your subject (the darker area of the frame), this should give you the correct exposer for the whole sceen, or would it blow out the background?
Hope you dont mind me adding a question to your thread :) .
1D MKIII 16-35 2.8L MKII 24-70 2.8L 70-200 2.8L [COLOR=black]IS 300 2.8L IS (few others) Bunch of AB lighting
Southern by the grace of God
yogestee
Jul 31, 2008 17:40 |  #6
pprice wrote in post #6022128 (external link)
Your background will blow out..
Jurgen
pprice
Jul 31, 2008 18:52 |  #7
OK, in other words, read and figure it out pprice :) .
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 31, 2008 20:08 |  #8
See post #3
Tips for Xmas Ball Please
Mike
ugly when I'm sober
Gallery: 51 photos
Aug 01, 2008 02:43 |  #9
You will overexpose the background and blow the highlights. The thing to understand is that cameras cannot always expose for everything and you will often be sacrificing some element of the photo in order to capture the essential elements. This is especially the case with high contrast scenes, such as your backlit subject.
One way to get around this is to use fill in flash. Meter for the background and then add flash to illuminate your subject. It's not always going to work but it'll help to balance the exposure.
Gear
UK South Easterners
pprice
Aug 01, 2008 03:45 |  #10
michaelgreen78 wrote in post #6024873 (external link)
That was a good answer!
Thanks!!
Oh, PhotosGuy, you have some great write-ups!!
PacAce
Joined Feb 2003
Aug 01, 2008 11:57 |  #11
reneethomas wrote in post #6019432 (external link)
Do you have a sample picture of what you are talking about? Getting a spot meter may not necessarily fix your exposure problem. You need to first determine what the problem is and what's causing it before you can decide on how to fix it. :)
...Leo
Lonnie
Joined Feb 2006
Aug 02, 2008 02:52 |  #12
I've been reading 'Understanding Exposure' - the author recommends to walk or zoom in closer to your subject and take a reading from them, then recompose the shot, and use the settings from your reading. You could also use your exposure lock button.
Highlights will still be blown of course, this is just a way to ensure your meter is not fooled.
My YouTube Vlog: https://www.youtube.co​m/c/GarageFlips (external link)
poloman
Aug 02, 2008 09:56 |  #13
If you have the chance to determine the background, you can do a lot to influence the final product. If you are shooting candid, watching your background will still help.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
PhotosGuy
Joined Feb 2004
Aug 03, 2008 10:19 |  #14
Or there's this info in the link I posted: Need an exposure crutch?
reneethomas
Aug 04, 2008 21:59 as a reply to  @ PhotosGuy's post |  #15
Here is one people commented on the exposure.
It was a cloudy day after a rain and to me it looks like it did that day but people have commented on the exposure not being correct.
2,465 views & 0 likes for this thread, 15 members have posted to it.
2844 guests, 138 members online
