Thread started 31 Jul 2008 (Thursday) 11:08
Question about my 300/2.8IS....lens plate
thatkatmat
Gallery: 41 photos
Jul 31, 2008 11:08 |  #1
If I'm not using a Arca Swiss or Wimberly tripod head yet, do I need the lens plate. Will it fit on my Manfrotto head? So do these keep the wear off the original plate....balance better, what are the pros?
I know the benefits of the heads to which these are to be mounted and plan on taking advantage of those benefits in the future, but funds are limited now and I'd like to keep the lens as clean and un-marred as possible. But I also don't want to buy the plate if wear on the original lens plate is the only advantage (without a head to match).
[SIZE=2]Thanks:D
My Flickr (external link)
Stuff
mackidbrendan
Jul 31, 2008 11:36 |  #2
no, you need a lens plate to attach the lens to your ball head. everything that attaches to a ballhead needs a lens plate, everything.
angela6571
Jul 31, 2008 12:00 |  #3
mackidbrendan wrote in post #6020116 (external link)
Completely incorrect information.
You dont need a plate for your 300. It will attach just fine to your monopod.
The point of using a plate is that the lens is held to the mount through the large area of the plate instead of the screw. I, and innumerable others, use a 300 or 400 on monopods without plates all day long. Its not something you need right now.
mackidbrendan
Jul 31, 2008 12:11 |  #4
angela6571 wrote in post #6020268 (external link)
no...your incorrect
were talking about mounting a lens to a ballhead. no one mentioned a monopod.
thatkatmat
Gallery: 41 photos
Jul 31, 2008 12:31 |  #5
I appologize....I did not state in my original post the fact that I was considering the Wimberly plate (which was the point of me posting this thread and would have been nice so you could dicern what the he!! I was talking about):oops:
But I did get two good responses, I can mount my 300 directly to a monopod. and of course I need a plate to attach to a ballhead, but what is the advantage of a wimberly plate? (other than using it on a particular style of head?)
Stuff
Bubble
Jul 31, 2008 12:34 as a reply to  @ mackidbrendan's post |  #6
the main benefit for lens plate is balance. It will distribute the weight of your lens evenly. In addition, you can just slide it off from you ballhead/tripod.
Canon 5D II, 7D | 16-35L II | 24-70L | 24-105L | 50L | 85L II |  iMac 27 | Redrock Micro DSLR Cinema Bundle | Elinchrom Ranger RX-AS Kit| Elinchrom Digital Style 1200RX/600RX | Turbo SC |
thatkatmat
Gallery: 41 photos
Jul 31, 2008 12:38 |  #7
Excellent, thank you
Stuff
dbdors
Jul 31, 2008 12:43 |  #8
thatkatmat wrote in post #6019975 (external link)
Which Manfrotto head do you have? What kind of mount is it? Does it have a 1/4"-20 stud?, Manfrotto quick release?, or is it an Arca style clamp? Without know what you have its hard to say what you need.
Certainly they will keep the original tripod collar from wearing, but this is not the reason most purchase quick release plates.
[SIZE=2]Thanks:D
Lens plates are generally used because one wants a quick release system to quickly mount and dismount the lens. Not to prevent wear on the tripod collar.
Depending on the ball head you have, why not get an Arca style clamp from Kirk or RRS and a plate for you lens. You can always use the plate later and the clamp can be sold later.
Darrell
My SmugMug Nature/Landscape Gallery (external link)
dbdors
Jul 31, 2008 12:46 |  #9
thatkatmat wrote in post #6020437 (external link)
Sorry, I was composing my note when you wrote this. But what is the mount on the ballhead you have now? Is it a screw or quick release?
Edit: Never mind, I looked at your gear list. You really aught to invest in a good ball head now and blow that grip action head. You've spent a lot on gear, it would be a shame to wimp out on the support system.
Darrell
Bubble
Jul 31, 2008 12:48 |  #10
Kirk lens plate for 300IS is not that expensive. Around $40-50. Get it. :)
thatkatmat
Gallery: 41 photos
Jul 31, 2008 12:56 |  #11
dbdors wrote in post #6020497 (external link)
Certainly they will keep the original tripod collar from wearing, but this is not the reason most purchase quick release plates.Lens plates are generally used because one wants a quick release system to quickly mount and dismount the lens. Not to prevent wear on the tripod collar.
I have a 488RC4 Midi Ball Head (Rapid Connect 4 System) with a 1/4"-20
Stuff
thatkatmat
Gallery: 41 photos
Jul 31, 2008 13:00 |  #12
dbdors wrote in post #6020512 (external link)
yeah, I did, I wasn't using a tripod much before, but have since begun using it more often and it quickly became obvious that the grip wasn't working out for me. I like the 488RC4 much better but with the 300 I'm looking to get into a better system.
Stuff
Bubble
Jul 31, 2008 13:05 |  #13
i would recommend:
Acratech V2 Conventional Ballhead with Arca-Style Quick Release
around $300. It is a SOLID product. It can handle lens from 300IS up to 600IS. I used it on all of my big lens on my Monopod.
sample:
http://www.aphanphoto.​com …userpics/10001/​12~3~0.jpg (external link)
http://www.aphanphoto.​com …yimage.php?albu​m=16&pos=6 (external link)
Invest it RIGHT one time. :)
Permagrin
Jul 31, 2008 13:07 as a reply to  @ thatkatmat's post |  #14
with this lens I use a larger lensplate for my gimbal head but for my monopod I use a regular ball head & acra QR plate.
Double ­ Negative
*sniffles*
Jul 31, 2008 13:27 |  #15
You do not need a lens plate unless you have compatible QR clamps.
To attach the 300 (or any super tele) to a monopod/tripod, just screw the 1/4-20 stud into the lens foot.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
2,486 views & 0 likes for this thread, 11 members have posted to it.
1627 guests, 142 members online
