anyone have tips on how to clean up the hair in this photo. i want to edges to look softer...
ryan148 Member 60 posts Joined Feb 2007 More info | Jul 31, 2008 14:01 | #1 anyone have tips on how to clean up the hair in this photo. i want to edges to look softer...
DavidSR Goldmember 1,308 posts Joined May 2008 Location: Rowlett, TX More info | Jul 31, 2008 14:56 | #2 I can't offer any help on the hair, but it looks like you should leave bigger gaps in between shots..it looks like he's overlapping himself in a few shots..when he starts and when he lands..a portion of the board is missing. T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
j-paka Member 215 posts Joined Oct 2007 Location: gold coast qld australia More info | Jul 31, 2008 15:58 | #3 hair cut lol 400d,40d,18-55,75-300,10-20,17-85IS,430ex,55-200,50 1.8,sigma 8mm fisheye
slapstix55 Senior Member 306 posts Joined Jul 2008 Location: San Diego, CA More info | Jul 31, 2008 16:01 | #4 I agree spaced to close, But good shots!
BassBiggieD Senior Member 539 posts Joined Jul 2006 Location: Arizona More info | Jul 31, 2008 21:38 | #5 yes more space in between |Gear|Zenfolio
D_CeLiRaToR Member 220 posts Likes: 1 Joined Aug 2007 Location: Racine, WI More info | Jul 31, 2008 21:50 | #6 how many fps is that? -Mike
phamster Cream of the Crop 6,315 posts Likes: 51 Joined Apr 2008 Location: Purdue - Go Boilers More info | Jul 31, 2008 21:58 | #7 it is nice, but more space.. "Lighting will make or break your photo"
poloman Cream of the Crop 5,442 posts Likes: 7 Joined Dec 2006 Location: Southern Illinois More info | Aug 02, 2008 21:29 | #8 Hi Ryan....try using lowering the opacity of your brush when you are doing your selection in those areas that you want softer. This will make them semi-transparent. If you take your time and work in layers, you can get a great result. "All those who believe in psychokinesis, raise my right hand!" Steven Wright
thanks for the comments... it was about 8fps with a 1d mark ii, ill cut some of the shots out and see what it looks like, this was the first try with the new body so i just threw them all in. but thanks
manutd101 Goldmember 1,261 posts Likes: 1 Joined May 2008 Location: Southern NH More info | Aug 13, 2008 15:10 | #10 |
digadv Senior Member 427 posts Likes: 1 Joined Oct 2007 Location: Dallas, TX More info | Aug 13, 2008 21:45 | #11 Maybe gradually lower the opacity of the shots as you go back in time. That effect usually works pretty well and then you don't have to worry about softening the hair.
jbergdoll Goldmember 1,176 posts Joined Apr 2008 Location: Tempe, AZ More info | Permanent banmake a selection around the hair's edges, probably with the magic wand tool, feather it, and then delete that selection. make sure his body isn't in the selection. -Joseph
teo-bingus Senior Member 276 posts Joined Oct 2007 Location: Rochester, NY More info | Aug 15, 2008 18:06 | #13 I think you could take out every other frame where he's really overlapping. Good sequence! Photo Newb
tomcat360 Senior Member 413 posts Joined Oct 2007 Location: Nomad More info | OT, but what aperture did you shoot at? Is the last frame a bit out of focus? http://www.https …book.com/tommypenickphoto
82NoMe Goldmember More info | Looks good but I might try every other frame. Cheers... jim
| Latest registered member was a spammer, and banned as such! 2811 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
