Thread started 31 Jul 2008 (Thursday) 22:33
Another What to Buy Post
doidinho
Jul 31, 2008 22:33 |  #1
Don't care much for these types of post, but I thought perhaps I can get some good insights on what question I need to ask myself before purchase.
Right now my lighting setup consists of two Nano stands, a 580 EXII, a Nikon SB-28, two Westcot convertible umbrellas, and Skyports. I don't have studio space and mostly like to do location shoots.
Option #1: Alien Bee AB800, 13' lightstand, AB 48" octabox, 48" grid, and Vagabond power system.
Option #2: Two more speedlights, one lightstand w/ boom, large (60") reflector, a couple of snoots for the speedlights, two more Skyport receivers and associated cords, and a few more packs of Enloop batteries.
Like I mentioned I like to do location stuff and want. I also just like to buy once and want to keep my options for upgrade open.
Any insight into this purchase would be appreciated. I'm kind of leaning toward the AB setup; however, it would be a little mroe expensive, so if option #2 makes more sense I would get it for sure.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
tim
Light Bringer
Aug 01, 2008 00:49 |  #2
Speedlites are very expensive, only go that way if you're going to use wireless ETTL or radio poppers - but I think that's unnecessary. Get some Vivitar or Sunpark flashes, they work well and cost a lot less. You can add battery packs cheaply enough too, but you lose portability.
Studio strobes come into their own if you need a lot of power or to shoot quickly or all day. They don't burn out beacuse of their fans. Shoemount flashes can, and aren't as powerful.
doidinho
Aug 01, 2008 01:02 |  #3
tim wrote in post #6024460 (external link)
When I said speedlights I mean't any brand, Nikon, Vivitar, Sunpak, ext. I don't plan to use ETTL other than one camera flash now and then, and I already have that.
Two more small flashes and excessories or one big flash and accesories. The extra power would be nice at times, but so would two smaller more compact light sources. Which option would offer more flexability? Are three light sources enough for most situations? Would four flash open up a whole new relm of possabilities?
Robert McCadden
MM (external link)
tim
Light Bringer
Aug 01, 2008 01:20 |  #4
What are you photographing, where, and how much time do you have to do it?
Haru
Aug 01, 2008 01:34 |  #5
To me, when "portability" means I have to set up multiple stands, rig multiple triggers, and set up multiple modifiers to do the same job that I could have got done with one strong strobe it seems to lose appeal. If the idea is to light your subject from many different angles then go with the hot shoe flashes. But if you just need more power, I'd go with one strong strobe, even if it means a little extra weight.
Gear: Stone slab, hammer, chiseL, and crushed barries.
Tareq
"I am very lazy, a normal consumer"
Aug 01, 2008 05:30 |  #6
Strobes all the way, many high level pros using strobes over speedlights, just learn how t make your strobes to be portable, i have 5 strobes, and if i can't buy something to make those strobes more portable then i have one 580 and i will add another 580 and using my reflector as another source of light [for fill] and i am done.
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
doidinho
Aug 01, 2008 21:49 |  #7
Tareq wrote in post #6025220 (external link)
I have two flashes and am looking for another light source; I would also like to try our a modeling light
Haru wrote in post #6024628 (external link)
Good point; pushing me towards the AB's.
tim wrote in post #6024567 (external link)
Single models on location. I have all the time in the world; they usually lose interrestbefore I tire. I also like to make the most of my home; however there is not a lot of room there. Would an AB 800 be unusable in a smaller space?
Robert McCadden
MM (external link)
tetrode
I am a walking repository of thoroughly useless information
Aug 01, 2008 22:26 as a reply to  @ doidinho's post |  #8
Seems to me you should be closely monitoring eBay for Norman or Lumedyne 200 or 400 WS battery powered flash systems. You shoot mostly on location, apparently like to travel light (inferred from the Nanos and Wescotts), and could use more power. Norman and Lumedyne meet those reqirements.
One thing to keep in mind: The Alien Bees 800 (or any monolight, for that matter) has all of its weight concentrated in one lump which will be perched high atop a light stand. That is not a particularly stable configuration when "on location" might mean outdoors. The Lumedyne and Norman type flash units are really mini pack and head systems. The heads weigh next to nothing and are thus much less of a problem when waving seven and a half feet in the air. Most of the weight is in the pack which will, most likely, be sitting on the ground.
I don't believe you mentioned budget. If cost is no object, there's always the Hensel Porty (and Elinchrom Ranger) system waiting to suck up your dollars.
Dave F.
bieber
Aug 01, 2008 23:23 |  #9
I'd say go with small strobes, if you want to do location lighting. If my setups go beyond a single light, I find unpacking and repacking even a couple of speedlights to be more hassle than I like: bulky studio strobes, especially if I had to use battery packs, would be even more cumbersome. Modeling lights, while nice, aren't really going to do you any good unless they're in a relatively dark studio, and even then it's gonna be hard to get very far with them with any modifiers mounted. Assuming you're shooting digital, just fire off a test-shot, and that'll show you where your light's going well enough.
So I guess my recommendation is to buy a couple more Speedlights and accessories. I'd tend to advise going for older Nikon units with optical slaves built in, so you can get away without extra radio receivers if necessary (the one on my SB-26 works so well that I still haven't gotten around to buying a third PW, in over six months of owning the strobe. It's sometimes difficult to use, but usually it works great, even outdoors in the sun). Studio strobes are great if you have a studio to leave them set up in, but for location work, they're just way too bulky, imo.
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
1,562 views & 0 likes for this thread, 6 members have posted to it.
2724 guests, 150 members online
