Well, after previously asking about Battery Packs for my 420EX in THIS thread, I decided to try the DIY approach. After reading all of the suggestions and a half dozen articles I realized it wasn't really that difficult. So I bought the materials and I am off to the races.
I generally don't do things if I can't do them right, so one thing I am determined to do is to cut the door on my 420EX so the cable can come out of the battery compartment with the door CLOSED. I do not want to use rubber bands as most of the DIY articles suggest.
Here is my problem, I am going to need to cut my notch on the hinge side of the door, which means it will be MUCH easier if I can remove the door. Trouble is, I can't figure out how to do that. Does anyone here know how to remove the hinged door from a 420EX?
I almost cut it off last night, and then had the thought that the hinge might be an integral part of the locking mechanism. I can't tell if the hinge is necessary to the door's closure, or if it is just a convenient "So you don't drop it and lose it" device.
I figured someone on here has taken a 420 EX apart in the past and would know the answers... So, does anybody know?
