Thread started 01 Aug 2008 (Friday) 10:44
Auto and Manual
izzy35
Aug 01, 2008 10:44 |  #1
there are times that i use "auto" in order to see what settings will be chosen and the shot comes out ok...However, if i put the camera in "manual" and use those same settings, the shot is NOT right, AT ALL...
Why is this??
Canon Xti | Canon EFS 18-55 (Kit Lens) | Canon 70-200 f/4L IS
Doug ­ Pardee
Aug 01, 2008 10:59 |  #2
Because you can't see what ISO setting is being used in auto mode. Your ISO setting in manual mode probably doesn't match.
Try using P mode instead. It uses the same exposure calculations but at the same ISO as M mode. Of course, in many cases you might just as well take the picture in P mode rather than transfer the settings to M mode.
egordon99
Aug 01, 2008 11:06 as a reply to  @ Doug Pardee's post |  #3
What's NOT right about it? Like Doug said, make sure you are also setting the ISO the same.
Another thought, did the flash pop up in AUTO? In manual, you have to "manually" pop up the flash if you want it to fire.
izzy35
Aug 01, 2008 11:30 |  #4
Doug Pardee wrote in post #6026576 (external link)
OMG...i feel silly!! i didn't even realize that!! that was the only setting NOT showing..
egordon99 wrote in post #6026615 (external link)
yeah the flash was being used both times.....Must've been the ISO...THanks guys!!
Mike
ugly when I'm sober
Gallery: 51 photos
Aug 01, 2008 12:48 |  #5
Another problem with setting Manually from the Auto settings is that you are not being as creative with regards to choosing the aperture or shutter speed that you want.
With Auto modes the camera will set an aperture and shutter speed that it thinks will be best. Sometimes this is ok but on other occasions you may not get the best shutter speed for the shot you want to achieve or the best depth of field.
The way I work my camera is to set my aperture first, then set my shutter speed and if I cannot get a fast enough shutter speed I will up my iso until I do. Fire off a shot and then chimp and adjust shutter speed/iso until I get the exposure that I like.
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
540 views & 0 likes for this thread, 4 members have posted to it.
Auto and Manual
2939 guests, 139 members online
