Here's the deal: my Nikon was fried yesterday. A lens error. I took it into a camera shop, they tried, said they couldn't do it. The camera model is from four years ago and I have recently begun to notice that it really is noisy, even at 50 ISO in bright daylight. so I want to upgrade.
Here's some of the specs that I wanted in a new camera:
- 6-50mm focal length, or thereabouts
- SD media
- Dimensions similar to the Nikon (4.2x2.6x2.2) since I put it in my pocket and the Nikon was almost too big for my pants pocket
And then the cameras just started to fall:
- The A and SD series are far too short focal length-wise
- The S5 IS is far too huge, 1" taller and 0.5" wider than the Nikon
- The SX100 has poor flash recycling times
- The Coolpix P80 is just as big as the S5 IS
Which leaves me with the G series, either the G7 or G9, because:
- Similar length (7.44-44.4mm)
- Almost the same dimensions of the Nikon (0.2" wider but 0.5" shorter)
- Uses lithium-ion batteries
- Can mount Speedlites (I have a 420EX)
The thing is, I only wanted to spend about $200, while The G9 costs at least $445 and a used G7 for about $320.
Do you think I'm asking for way too much out of a P&S and the result is that the only PowerShot model that meets them is the highest-end one? The G-series seems to be a lot higher than what I was aiming for too (I wasn't particularly aiming for RAW support, manual controls, or 12.1 megapixels).
Should I just get the SX100 instead and overlook the AA batteries and the slow recycle times?
