Thread started 02 Aug 2008 (Saturday) 20:26
430EX
dtufino
Aug 02, 2008 20:26 |  #1
Hey guys, just for the 430EX... sort of new to lighting... can someone give me as setting for Dark/Indoor shooting.
I have read everything and for some reason i still can;t find that ONE setting that will give me good results.... i know that ISO and everything else is still a factor, but any help would be nice.
I need a setting for Indoor (apartment) shooting (family/parties etc)
-David T.
www.dtufinophoto.com (external link)
@dtufino_photo (external link)
Raker13
Aug 02, 2008 20:37 |  #2
ettl, M, 1/60, f5.6, low iso.
40D w kit lens/G9/1.8 50/Tamron 17-50
430 ex II/Manfrotto Tripod
D_CeLiRaToR
Aug 02, 2008 20:37 |  #3
if the ceiling is white or light colored, aim the flash head up at a 45 degree angle. depending on the height of the ceiling you may need to increase the flash power. also, a flash diffuser like a stofen omni-bounce helps a lot.
-Mike
Canon EOS Rebel T4i | Canon 70-200mm f/2.8 IS mkII USM| Canon 430EX II
AlanU
Gallery: 144 photos
Aug 03, 2008 01:42 |  #4
There are so many possible variables. With my XTI I can simply set my body to M, f5.6, 1/125, ISO 400 with my 580EXII to Ettl. Adjust the FEC to your liking. With your 430EX just adjust the FEC. That'll be your glorified point and shoot with a high percentage of keepers.
If you want more "pop" you may use a larger aperature like f3.5 on a 2.8 zoom (get more sharpness 2 stops down from wideopen) and get background blurr and play with the shutter speed and FEC for your desired exposure.( NO mention of equipment ??)
Bounce your flash to a wall or ceiling (assuming its light coloured and somewhat low 8-9ft). You may look into a flipit from joe demb.
http://www.dembflashpr​oducts.com/flipit/ (external link)
The flipit is a catch light card that helps throw light forward. For now you can simpy get a white piece of cardboard and use a rubber band to secure it on the head.
Not long ago I took many photos at my friends engagement party and the restaurant was extremely low lit. Virtually all of my photos were keepers regarding sharpness and exposure. And think I was getting away with f6.3, SS 1/160, ISO 400 not overly concerned with dragging the shutter since I didnt feel it neccesary to attempt to expose the virtually black dark lit background.
Indoors I wouldn't do direct flash. Even the 14mm diffuser grid on the 430EX would be a harsh source of light indoors.
5Dmkiv |5Dmkiii | 24LmkII | 85 mkII L | | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji - gone
Sony 2 x A7iii w/ Sigma MC-11 adapter | GM16-35 f/2.8 | Sigma 24-70 ART | GM70-200 f/2.8 |Sigma Art 24 f/1.4 | Sigma ART 35 f/1.2 | FE85 f/1.8 | Sigma ART 105 f/1.4 | Godox V860iiS & V1S
dale65bama
Aug 04, 2008 14:25 as a reply to  @ AlanU's post |  #5
For work inside an apartment, go with the bounce technique. Since your shots will be mostly closer than 10-12 ft, you may need to set the flash at a 60-90 degree angle. If the ceiling is white or light gray, you should get nicely diffused lighting that still has some of the other sources (lamps etc.) in it. Make a bunch of test exposures to determine your best settings. I am still using an old Vivitar flash that gives good results as long as I do some testing first. Once you get some good settings for your apartment, they should work in any other place that has a similar ceiling height. In a small space, a direct flash will blow out any light-colored surface and you risk the reflection from windows, mirrors and glass doors you may not have noticed.
Dale
EOS 5D, Digital Rebel, EF-S 18-55mm Kit Lens; EF 200mm F2.8L, EF 100 f2.8 Macro, 500mm Celestron 80EDF; Sigma 24-70mm F2.8 EX DG macro; Cool POTN strap; BG-E1 Grip, CanoScan 8800f; RRS BH-40 Pro II on 3021BPRO legs
1,283 views & 0 likes for this thread, 5 members have posted to it.
430EX
2673 guests, 153 members online
