Thread started 02 Aug 2008 (Saturday) 21:41
Focus Point Questions
StephenHutchinson
Aug 02, 2008 21:41 |  #1
1. How many people have their cameras set to use all the focus points at once (automatic) and how many people set a specific focus point (for instance the centre one) when shooting?
2. I always tend to use the centre point when shooting, is there any advantage to using all the focus points rather than just any one focus point in particular?
Canon EOS 5D Mark III | Canon EOS 7D | Canon EOS 70D
70-200mm f/2.8 L IS USM II | 50mm 1.4 | 16-35mm f/ 2.8 L | 24-105mm f/4 L IS USM
Mark_Cohran
Joined Jul 2002
Aug 02, 2008 21:44 |  #2
Letting the camera choose your focus point will likely result in more times when the camera doesn't focus on the point you want to focus on. I always select the specific focus point I want to use and minimize any focus/recomposition issues.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
StephenHutchinson
Aug 02, 2008 21:51 |  #3
Thanks.. that what I thought.... I've had this nagging feeling though that all points focusing might affect DOF somewhat in how the camera determines shutter/aperature in Program mode... just a thought.
andrepaul
Aug 02, 2008 21:54 |  #4
Centre mostly, but commonly just use the one closest to the main subject or part of subject most important.
andre|paul design + photography (external link)
Website (external link) | Facebook (external link)
Sports_Dude
Aug 02, 2008 22:20 |  #5
Usually the center point.
Sports_Dude
7D Gripped | 17-55 f/2.8 IS | 70-200 f/2.8L IS | 100-400 f/4.5-5.6L IS II | 580EXII
PacAce
Joined Feb 2003
Aug 03, 2008 00:00 |  #6
Automatic Focus Point Selection behaves differently between OneShot and AIServo. I would never think of using AFPS in OneShot mode because the camera is going to determine what AF point it's going to use and you have no control over that.
However, in AIServo mode, the AF acquisition always starts with the center AF point and remains there unless the target moves off the center AF point. Then, the camera tracks the target with the one of the other AF points if the target is covered by any of the other AF points. There are times when I do use AFPS in AIServo mode when shooting birds in flight.
...Leo
m-bartelt
Aug 03, 2008 03:45 |  #7
I'm always changing my focus point... I love the 40D for this reason.... just push the button, spin the wheel and you focus where you want to, not where the camera does.
In the rare circumstances where I do want all the focus points, I just switch to A-DEP cause that's what I'm after.
Canon 40D 10-22mm 24-105L 580 EX II
Canon IIIA LTM Serenar 28mm 3.5
Serenar 50mm 1.8
Leica IIIf RD ST LTM Elmar 50mm 3.5
Nikkor 50mm 1.4
Kodak Brownie No 2
:P
SolidxSnake
Aug 03, 2008 03:56 |  #8
I use manual FP selection, and I use the multi-controller to select them. It is clearly the quickest and most efficient way to control the AF.
I don't track moving subjects much so I haven't tried auto selection in AI Servo.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
Weth
Aug 03, 2008 07:16 as a reply to  @ SolidxSnake's post |  #9
When I first got my XSi, used all the points.
You can get the hang of that, and as long as you pay attention to what is getting focus lock, it can be effective. But sometimes frustrating. Success once trained: 80% in focus
Then I used center point. Learned the DOF make a difference in DSLR when focus and recompose. Without recomposing, shots became boring - main subject always in center with lots of sky above head to get her eyes at the center focus point. Success 80 in focus (and still did some recomposing)
Live mode trial. inanimate objects 100% focus. Moving objects - object not technically out of focus, they just aren't in the frame any more. Live focus very effective for stationary objects (portraits, landscape), less helpul when used as a digicam.
The best method is to become very quick at selecting the ponit at your subject. It is a 9 point pattern so easy to memorize, and button pushing without looking will quickly develop. Ideally focus point right at eyes of main subject. Success 95% in focus
iwannabe
Aug 03, 2008 07:28 |  #10
I use center point exclusively with oneshot. Haven't ventured into AIServo much.
I wish there was a easier on the fly method to changing the focal point though on the XTI.
I realize there is the Cf selection but then I lose use of the ISO and metering functions.
Cameras: Canon 5D Mark III, 7D Mark II, Flashes: Canon 420EX, 580EX1
Lens: Canon 50 1.8II, Canon 85 1.8, Canon 17-55 2.8, Canon 24-70 F4.0,Sigma 30 1.4, Canon 70-200 F4/L IS, Tokina 11-16 2.8II, Tamron 70-200 2.8
herbe_nelson
Aug 03, 2008 08:25 |  #11
m-bartelt wrote in post #6036388 (external link)
change it so that you use the multi-controller to control which AF point. You will love this even more that a press+wheel spin method. One touch in the direction of the point and that is the one you will use.
Nelson
Nelson
www.flickr.com/photos/​herbe_nelson (external link)
www.nelpix.com (external link)
Larry ­ Weinman
Aug 03, 2008 08:34 |  #12
I went to a clinic recently given by a well known nature photographer. He described using all focus points as the Canon circle of failure. I have to agree. My camera seems to inevitably set the point on something I don't want in focus.
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
Wilt
Aug 03, 2008 08:36 |  #13
Consider this...the classic film SLR of 30 years ago had a focus aid in the center of the frame to help with precision focusing. The photographer manually focuses, then recomposes the frame for good composition, then shoots. Now simply apply that usage model to the modern dSLR, and you have a very workable solution.
Yet many photographers will challenge, "But what about the focus shift caused by focus-recompose?!" The response is, usually the DOF of the lens at the shooting aperture will more than compensate for the plane-of-focus shift which occurs, unless you are at very close distances at wide open aperture. In general, the DOF will compensate if the angular shift is under 20 degrees (outside the visible frame on a telephoto FL!) even with wide open aperture. Yes, using manual focus point selection initially, rather than the center AF point, would reduce the issue of focus-recompose, but I am merely pointing out the issue is not as dire as some would lead you to believe...after all, decades of film photographers coped, and they had the lesser DOF of 135 format and medium format SLRs to cope with!
Ade ­ H
Aug 03, 2008 09:02 |  #14
I almost always use the centre point for static subjects except situations that would result in a shift of the point of sharp focus away from the intended distance with narrow DOF. I don't do much of that kind of shooting, though.
With sports subjects, I mix between the centre point and all points depending upon the subject. Where all-points comes into its own is a reasonably flat subject that has a lot of large gaps in it. In other words, a cyclist passing your position. If a single point falls into one of the gaps, it just locks onto the background and wrecks the shot, but the all-points mode does a very good job of maintaining a lock on the bike/rider on the nearest point of good contrast without needing to compromise the composition. I get good results from that, while a single point fails too often. However, all-points is not very good at dealing with a subject that provides appreciably different planes of focus, which tends to produce a potentially unacceptable degree of inconsistency unless the DOF is deep.
PacAce
Joined Feb 2003
Aug 03, 2008 10:04 |  #15
Wilt wrote in post #6037048 (external link)
So, are you saying that you manually focus your lens instead of using AF? :confused:
...Leo
3,517 views & 0 likes for this thread, 19 members have posted to it.
1495 guests, 125 members online
