Thread started 03 Aug 2008 (Sunday) 08:13
40D going hay-wire
MikeKS
Aug 03, 2008 08:13 |  #1
hey all,
I'm out here in Punta Cana, Dominican Republic for a week. It's beautiful! just one problem... My 40D decides to start acting up on me the second day i am out here:cry: I just wanna know if anyone has an idea of what might cause my problem. Whenever i go to take a shot the camera, doesn't matter what mode it is , starts to flicker 125 or 200 in the lcd display a top the camera. it's acting as if i were pressing the shutter button halfway repeatedly. I can still take shots but when it starts the 125 - 200 metering most of the time everything is off exposure. This also happens when i go to review pictures, i get to see the picture and then it turns off and i have a flickering 125- 200 shutter speed in my LCD display. The camera hasn't had any water spilled on it and didn't even get to the beach yet. I just see if anyone has any ideas before i send it off back to Canon for warranty repair when i get back home to NY
-Mike
5D | 24 1.4L II | Sigma-lux 50 1.4 | Canon 85 1.8 | 70-200 f4L | 430EX | 580EXII
MichaelSimonitsch.com (external link)
Blog (external link)
clipper_from_oz
Gallery: 29 photos
Aug 03, 2008 08:19 |  #2
MikeKS wrote in post #6036977 (external link)
hey all,
-Mike
Have you tried taking the battery out ...leave it out for a minute..... then start it back up again?
Clipper
R5, 5DSR, Fotoman 6x17cm Large Format Panorama Camera,Mamiya Universal 6x9
Canon EF 16-35mm f4 L, 17mm TSE f4 L,50mm f1.4, 24-70 f2.8 L, 70-200mm F4 L, 85mm f1.8, 100-400mm II L,
EF 400mm f2.8 IS II L, RF 600mm f4 IS L
Rodenstock, Sinar& Nikkor LF lens for Pano (75,95,150+210mm)
strobe ­ monkey
Aug 03, 2008 08:21 |  #3
Sorry to hear that. I'm off to Paris on Tuesday and hopefully my beloved 40D doesn't do that to me. Yeah worth trying removing both batteries out and leaving it for a few minutes and see if it helps.
R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
MikeKS
Aug 03, 2008 09:18 as a reply to  @ strobe monkey's post |  #4
Yeah, i took the batteries out, went out for a couple hours came back and when i put the battery back in it was ok for like a minute or two, then it went all crazy on me again :rolleyes: I even tried switching lenses + taking out the CF card + battery and leaving it off over night with the same results.
Strobe, i don't think this is a common happening with the 40D. i have seen several guest here where i'm staying with the 40D and they haven't had any issues, i just have a lil bad luck :confused: Enjoy your trip man, there is plenty to photograph out there
apersson850
Gallery: 35 photos
Aug 03, 2008 09:44 as a reply to  @ MikeKS's post |  #5
Never seen anything similar. Haven't had any problems with my 40D, really.
Anders
PhotoSportsOnline
Aug 03, 2008 09:49 as a reply to  @ apersson850's post |  #6
I was at the AMA tire test at Laguna, my 40D went nuts and shutdown. No menus, no af not able to take a single shot. powered up not even a sensor clean splash.
I took the batteries out, pulled the CF, pulled the lens and cleaned the mounts. It started working after I put it all together. I got home and flashed the firmware just to do it.
Has not repeated itself yet
www.SportCityRider.com (external link)
http://www.photosports​online.com (external link)
LW ­ Dail
Location: Where the wind comes sweeping down the plain!
Aug 03, 2008 09:52 as a reply to  @ apersson850's post |  #7
I had some unexplained funkiness with my Rebel before it became a 5D.
I believe (absolutely nothing technical to back it up, just gut feeling) that it had to do with the one battery that tended to live in my camera. I had two, but for whatever reason the one always ended up in the camera.
So it would get used, charged, used, charged..... The 'spare' got charged back to full, but rarely fully cycled.
After about two years, the 'regular' battery seemed to flake out, giving me funky errors and causing weird behavior. Turning off the camera and putting in the 'spare' solved the problems.
Problems would reoccur when the 'regular' battery made it back into the camera.
I'm very careful now to alternate both batteries equally when I'm not using the battery pack.
So I'd recommend finding a new battery STAT!
Canon 5D: 24-105mm L IS, 100-400mm L IS. Canon PowerShot ELPH 340HS, Canon GII. Canon AE-1: FD 50mm, 80-200mm. Holga 120N.
"Photography is my one recreation, and I think it should be done well." Lewis Carroll
MikeKS
Aug 03, 2008 14:56 as a reply to  @ LW Dail's post |  #8
I'm out of luck here guys, i think my 40D needs to go back to Canon for warranty repair. I tried everything, i switched batteries, pulled out the CF card, switched lens, cleaned the contacts. I even updated the firmware, still no changes.. in fact the camera is acting weirder and weirder. Oh, well thanks for the suggestions fellas.
Mike
zooxanthellae
Aug 03, 2008 18:24 |  #9
Did you remove the small round battery from the battery compartment too as this will reset the camera,you didn't specifically mention that one,just removing the camera battery wont do much.
Canon 5D MK II,7d,70-200 L F2.8,24-70L,100mm Macro usm F2.8,sigma 150-500 OS,50mm 1.8 mk II,580 ex II. :D
amfoto1
Aug 03, 2008 18:27 |  #10
Hi Mike,
When you rebooted the camera, did you pull out both batteries?
Besides the BP511A, there's a small, silver memory battery. You have to pull them both out for a while (not sure how long... I've heard everything from 15 min. to overnight), to force the camera to completely reboot. Just pulling the BP511A won't do it.
You will lose all special settings in the menu, the camera will reset to the defaults.
While it's out, wipe off the silver battery with a clean rag, just to be sure there are no finger oils on it. They can mess with the tiny amount of electrical power being provided (1.5 volts).
MikeKS
Aug 03, 2008 18:46 as a reply to  @ amfoto1's post |  #11
Thanks Zoox and Amfoto1, i'm gonna give that a try tonight and leave them both out over night.
-Mike
Hermeto
Aug 03, 2008 18:50 |  #12
Canon recommends 20-ish minutes with both batteries out.
That’s usually enough for all capacitors to discharge and completely reset the camera..
scbailey
Aug 03, 2008 20:51 |  #13
I don't have any suggestions but I hope it starts working because the beaches there are TOPLESS!!:lol:
MikeKS
Aug 04, 2008 17:45 as a reply to  @ scbailey's post |  #14
Ahh well, i put in both batteries this morning and still it's all wacky. Thanks everyone for showing a lot support to a fellow potn'r in distress. scbaily, thanks for the laugh and i'm sorry there will be no pics of the beautiful beach, and it's inhabitants :cry::cry:
DDCSD
GIVIN' GOOD KARMA
Aug 04, 2008 17:52 |  #15
Didn't read anything about you trying different modes. What mode is it in? I'd try M and work my way all the way around to the green box, see if any of them will work. Would stink to not have the thing working for the whole trip.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
3,978 views & 0 likes for this thread, 18 members have posted to it.
40D going hay-wire
1313 guests, 124 members online
