Thread started 03 Aug 2008 (Sunday) 12:29
POLL: "So which should I go with?"
Gitzo GM2540 (Older but lighter)
5
55.6%
Gitzo GM2541 (Newer but heavier)
4
44.4%
9 voters, 9 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
HELP! Difference Between Gitzo GM2540 And Newer GM2541 Monpods???
ben_r_
-POTN's Three legged Support-
Aug 03, 2008 12:29 |  #1
After spending the day in San Francisco, CA shooting at the San Francisco Zoo and then the Chihuly glass art exhibit in the De Young museum with crowds of people too thick to setup and use a tripod of any kind, I have decided I want my monopod back! I recently sold my Bogen / Manfrotto 680B because I thought I wasn't using it enough and because I figured if I found I did need it after it was gone I would just upgrade to a Gitzo/RRS setup when that time came.
Im looking at the Gitzo GM2540 (older model, but I found a place that still has them in stock) and the GM 2541 (newer model). I normally would just go with the newer and easier to find for sale model, however in this case there's an interesting issue... Based on the details given by both B&H and Gitzo directly, the new model actually weighs MORE! 12.8oz to 1.1lbs. Yet EVERYTHING else about the two monopods appears to be the same!
So who out there owns these or even better both and can comment on any other differences? If there truly aren't any (like maybe a newer twist lock grip design or something) then I will be going for the older model as the lighter weight is a good thing!
FWIW I will be topping any monopod I get with the RRS High Capacity Monopod Head and an RRS quick release clamp. LINK (external link)
Here is the details on both from B&H:
Gitzo GM-2540 Mountaineer 6X Carbon Fiber Monopod - Supports 26.4 lbs (12 kg)
IMAGE: http://www.bhphotovideo.com/images/largeimages/475914.jpg
The Gitzo GM-2540 Mountaineer 6X Carbon Fiber Monopod is 4 leg-section model that weighs less than one pound, but can still support cameras up to 26.4 lbs. This monopod also incorporates Gitzo's revolutionary 6X technology tube, which reduces overall monopods weight up to 25% without sacrificing strength or stability.
The G-Lock mechanism has been completely redesigned in order to achieve a 20% increase in rigidity, faster operation and stronger, safer locking. G-Lock's special design also provides a "gravity lock" effect: the higher the load applied vertically to the leg, the stronger the lock.
Key Features
• 1mm Gitzo 6X Carbon Fiber Tube
Gitzo was able to develop a six-crossed multilayer carbon fiber 30% lighter than the previous 1.5mm generation that features the same exceptional performance of stability and vibration absorption and unbeatable quality.
• Anti-Rotation Leg (ALR) System
The Anti-Rotation Leg (ALR) system makes it quick and easy to open and close the monopod. Simply turn all of the locking rings at once and the whole leg can be pulled out in seconds.
• Connected wrist strap
Specifications
Maximum Height: 63" (160 cm)
Folded Length: 20.9" (53 cm)
Load Capacity: 26.4 lbs (12 kg)
Leg Sections: 4
Leg Lock Type: Twist
Male Thread Size: 1/4"-20 & 3/8"-16 (reversible stud)
Weight: 12.8 oz (400 g)
Gitzo GM2541 6X Carbon Fiber Monopod - Supports 26.4 lbs (12kg)
IMAGE: http://www.bhphotovideo.com/images/largeimages/553781.jpg
The Gitzo GM2541 Mountaineer 6X Carbon Fiber Monopod is 4 leg-section model that weighs less than one pound, but can still support cameras up to 26.4 lbs. This monopod also incorporates Gitzo's revolutionary 6X technology tube, which reduces overall monopods weight up to 25% without sacrificing strength or stability.
Key Features
• Wrist Strap with Belt Clip
Connected to the top plate is a wrist strap, with a handy wide belt clip incorporated. This makes it possible to hang the monopod directly from a belt, strap, or pocket.
Specifications
Maximum Height: 63" (160cm)
Folded Length: 20.9" (53cm)
Load Capacity: 26.4 lbs (12kg)
Leg Sections: 4
Weight: 1.1 lb (500g)
da_nige
Aug 03, 2008 19:18 |  #2
It appears that the 2541 has the new safe lock top plate and power disk.
SAFE LOCK Safe Lock is a special techno polymer that maximises locking torque and equipment stabilisation. It is used on the upper discs of tripods and heads, and in applications where the equipment is rotated and screwed onto the support to eliminate micro movements and vibration.
POWER DISC The new tripod upper disc is called “Power Disc”. It is made of machined solid aluminum and it now features two locking screws, one to lock the head, the other to safely lock the disc onto the column. The “Power Disc” gives a rock solid connection of the whole system for additional safety and stability.
That said I'd still go for the 2540 as its lighter and also (probably) cheaper
Neil
1DIV -- 40D -- 12-24mm f4.5-5.6 EX -- 17-40mm f4 L -- 24-70mm f2.8 L -- 70-200mm f2.8 L II -- 100mm f2.8 Macro -- 300mm f4 L IS -- 500mm f4 [COLOR=red]L IS -- 1.4 II -- 580EXII x2 -- 430EXII
Gitzo 3530LSV tripod and Manfrotto monopod, various pieces of camo gear, various filters and cables. Lowepro (x3) Dakine and Crumpler bags.
jhom
Aug 03, 2008 19:40 |  #3
If you go to the Gitzo.com site and select the spare parts list, you can see the difference between the two. Besides the extra set screw and belt clip strap, the legs are the same. I think the weight difference may be due to the belt clip.
I don't think you will see any difference between the two in performance. The difference will likely be the additional set screw for the head (no big deal unless you have problems keeping the platform disk on). The interesting thing part is the belt clip. I wonder how it works. There have been times that I would have liked a belt clip to hold the unused monopod. I think I'm going to have to go and scope one out. If it is any good, I may have to order the part.
Jim
ben_r_
Aug 03, 2008 20:02 |  #4
da_nige wrote in post #6040051 (external link)
Neil
Well they are actually the exact same price. Sorry, should have mentioned that in the beginning.
jhom wrote in post #6040173 (external link)
The belt clip might be an interesting feature, but I have a feeling that once the RRS head and clamp is on there it will make the unit a little top heavy and thus a little awkward to hang from the belt. So I probably wont use that feature. That and I usually dont wear a belt either. So thats not gonna help much.
ben_r_
Aug 03, 2008 20:05 |  #5
The safe lock and power disc are nice features, I think I have them on my 1541T legs (have to check) but still, the fact that those somehow add a considerable amount of weight bothers me. The RRS head and clamp are already going to add 13.4oz as it is.
jhom
Aug 03, 2008 20:05 |  #6
ben_r_ wrote in post #6040300 (external link)
Then, 6 of one and a half a dozen of the other. The weight factor of 4oz might make your decision.
Jim
ben_r_
Aug 03, 2008 20:07 |  #7
jhom wrote in post #6040319 (external link)
Yea thats kinda how I was feeling about it before I created the thread. I just wanted to make sure there was nothing I was missing that only those who owned these monopods or those who know more about them knew. Like the Safe Lock and Power Disc. I had never heard of those features. The smaller weight is of course a huge deal and even though its only shaving off a few ounces, every little bit helps.
jrsforums
Aug 03, 2008 20:47 |  #8
...The interesting thing part is the belt clip. I wonder how it works. There have been times that I would have liked a belt clip to hold the unused monopod. I think I'm going to have to go and scope one out. If it is any good, I may have to order the part.
Hi, Jim...
A couple (two just for "safety) black cable ties to attach a 5/8" to 3/4" split ring allows the attachment of a carabineer....which hooks it to your belt, bag, whatever....and adds almost no weight.
I'm not much for hanging from my belt, but it works great hanging off the bag.
John
ben_r_
Aug 03, 2008 21:06 |  #9
jrsforums wrote in post #6040600 (external link)
Hi, Jim...
A couple (two just for "safety) black cable ties to attach a 5/8" to 3/4" split ring allows the attachment of a carabineer....which hocks it to your belt, bag, whatever....and adds almost no weight.
Got any pics of this setup?
jhom
Aug 03, 2008 21:13 |  #10
Hi, Jim...
Sounds good. I think I'll try it. My TT bags have tripod/monopod pockets so no problem there. However it would be nice to find a solution for when I use a TT belt or Change Up bag. The split ring to carbineer might just work.
Thanks.
Jim
jrsforums
Aug 03, 2008 21:36 |  #11
ben_r_ wrote in post #6040711 (external link)
No, but I think it is a pretty easy to figure out. Just go to Ace hardware, or equivalent, and pick up some cable ties (black works best on the Gitzo), small split ring (5/8" or 3/4" or ...), and the carabineer of your choice....I used a small one as I just hook it to the ring or belt hdwr of my Domkes.
Put the cable tie(s) through the ring and around the top of the monopod, above the foam handle and the head mount...snug up and clip off the end(s)...done.
BTW...I have the GM2540...love it...!!!
John
ben_r_
Aug 03, 2008 21:43 |  #12
jrsforums wrote in post #6040842 (external link)
OH OKAY! Now I know what youre talking about! Honestly I never knew what these things were called:
IMAGE: http://upload.wikimedia.org/wikipedia/commons/thumb/f/f6/HMS_Carabiner.png/180px-HMS_Carabiner.png
Yes that does sound like it would work quite well. Might flop around a lot if youre walking fast, but would still be plenty functional as a belt clip.
ben_r_
Aug 04, 2008 21:57 |  #13
Alright, so I ended up ordering the GM2540. 17th St Photo Supply through Amazon was the only place I could still find one in stock. They have already shipped it via UPS ground and hopefully it will be here by the end of the week! Now to order the head. I will do a review of the combo soon. :)
ben_r_
Aug 11, 2008 20:28 |  #14
Okay, and after ordering the GM2540, they ended up sending me the GM2541... Im not entirely displeased with the GM2541 as it is certainly light enough. I am still going to call though and inquire as to why they had the GM2540 listed as available and then ship me the newer one.
10,105 views & 0 likes for this thread, 4 members have posted to it.
1080 guests, 114 members online
