Thread started 04 Aug 2008 (Monday) 15:39
My 20D keeps underexposing images in P/Av mode
Persephone
Aug 04, 2008 15:39 |  #1
I just noticed this now, but all shots in P mode (a majority) are being underexposed by 1 1/3 and I can't figure out what option in the menu will fix this. I've read the manual - I must be missing something but I can't figure out what. The only way I can stop this for now is to shoot in M mode, except that sometimes I need to take a shot fast and I don't have time to flip through the right settings to expose it properly.
Gear list
"Do you think it was my choice to wed a man I did not love? Live a life I did not choose? I was betrayed by the very gods that once saw me as their own. But no more." - Περσεφόνη (external link), God of War
SolidxSnake
Aug 04, 2008 15:43 |  #2
Are you sure they are underexposing? Try shooting a gray card in manual and automatic modes with the same settings.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
Persephone
Aug 04, 2008 15:47 |  #3
SolidxSnake wrote in post #6045655 (external link)
On the little meter at the bottom of the top LCD screen it's about one stop to the left. The playback screen says +/- 1 1/3, that's how i know the exact number. No amount of top wheel turning will change it. And I loaded a sky shot just a few minutes ago and it was wayyy too dark.
If it helps...I shoot in AWB, WB shift/bracketing is 0, color temp is 5200K.
I'll try the gray card trick.
EDIT: Okay, so I shot my old gray Nikon camera (not 100% gray) at f/3.5 1/25. Histograms are about the same and it says +/- 1 1/3 next to the image shot in P mode.
Gear list
adas
Joined Aug 2004
Aug 04, 2008 15:53 |  #4
You must've been adding some EC then. Slide the power button to the uppest position (the line above the ON), half-press the shutter button then turn the dial on the back until the EC mark goes back in the center while looking in the viewfinder.
6D, 20D, G7X
Persephone
Aug 04, 2008 15:54 |  #5
adas wrote in post #6045730 (external link)
You must've been adding some EC then. Slide the power button to the uppest position (the line above the ON), half-press the shutter button then turn the dial on the back.
Thanks, that worked beautifully. EDIT: Although, to be honest, I don't know how that even happened...I normally don't touch the wheel when I half-press the shutter.
Gear list
Lowner
"I'm the original idiot"
Aug 04, 2008 15:57 |  #6
I think the problem might be that you have dialled some exposure compensation in at some stage in the past, either knowingly or unknowingly (its scarily easy to do by accident).
On my 30D, no amount of playing with the "top wheel" (AKA the main dial) will alter anything either. You need to turn the quick control dial on the rear of the body to bring the exposure compensation back to zero.
Have a play and let us know. Dont forget the dial needs to be turned on before it will do anything.
Sorry Guys, While I was typing, you had posted!
Richard
adas
Joined Aug 2004
Aug 04, 2008 16:05 |  #7
hbdragon88 wrote in post #6045741 (external link)
Yes you do, in M mode. And it's easy to do it in other modes then. Keep the power button to ON for a while, that will inactivate the back-wheel, if you don't need EC.
6D, 20D, G7X
Persephone
Aug 04, 2008 16:09 |  #8
adas wrote in post #6045802 (external link)
When I half-press. I was fairly certain that all i did was move the wheels around and then * and click the shutter. And a lot of old shots (I didn't start seriously using M mode until Friday) were also underexposed.
Okay, I just found out that I don't even need to half-press the shutter in P mode to move the EC around. I probably did it then.
Gear list
Lowner
Aug 04, 2008 16:21 |  #9
The dial can move simply by rubbing against your body while slung round your kneck IF the on/off switch is turned to allow it. I ruined a good half dozen films in my Eos-3 and was subsequently told that many pros taped the dial up to prevent expensive accidents. It really taught me a lesson.
Richard
adas
Joined Aug 2004
Aug 04, 2008 17:14 |  #10
The EC on the back dial is only active within 6 sec. after half-pressing the shutter button.
Never once happened to me to turn it inadvertently other than with my hand. Though sometimes I bump the button in the middle of that dial (which is set to preview on) with my nose.
6D, 20D, G7X
SolidxSnake
Aug 04, 2008 17:31 |  #11
In M you don't have to start metering to change the setting. I'm not sure if on one of the three automatic modes you'd have to, though it makes sense that you do.
1) RTFM.
2) Repeat Step 1.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 04, 2008 19:04 as a reply to  @ SolidxSnake's post |  #12
Yes, in any automatic mode it is as was stated above: You can change EC during the six seconds metering is active.
Anders
2,311 views & 0 likes for this thread, 5 members have posted to it.
976 guests, 101 members online
