I dont get the effects of shooting raw... what does it do to help and what is the difference in jpeg and raw?
ferry101 Senior Member 278 posts Joined Feb 2008 More info | Aug 06, 2008 10:42 | #1 I dont get the effects of shooting raw... what does it do to help and what is the difference in jpeg and raw? Bodies- 1d Mark II, 50d + Grip
Aug 06, 2008 10:45 | #2 there's alot of threads regarding this topic. basically raw enables you to adjust white balance later on pp, while jpeg can't. raw total control, jpeg lost of data and IQ. so goes the list Ben
stathunter "I am no one really" 5,659 posts Likes: 60 Joined Aug 2006 Location: California & Michigan More info | Aug 06, 2008 10:46 | #3 Hello! I would suggest you use the search feature and look at the threads on this same question. But to give you a quick answer RAW is a format like a digital negative that does not change the quality of the original. This means that you can change the lighting and color etc--- to extremes with RAW where you cannot with jpeg. Scott
pprice Goldmember 1,714 posts Joined Jun 2008 Location: Gods Country (aka Mississippi) More info | Aug 06, 2008 10:46 | #4 Raw saves more information than Jpeg allowing you to do more in PP. 1D MKIII 16-35 2.8L MKII 24-70 2.8L 70-200 2.8L [COLOR=black]IS 300 2.8L IS (few others) Bunch of AB lighting
AlexRechetov Member 204 posts Joined Sep 2007 Location: Toronto, Canada More info | Aug 06, 2008 10:47 | #5 The search function is your friend
Aweitzel Senior Member 412 posts Joined Jan 2008 Location: Chino hills More info | Aug 06, 2008 10:47 | #6 http://digital-photography-school.com/blog/raw-vs-jpeg/ g9, 40d,28-135 kit, 55-250, 430EX, t-50( Yes its film.)
canonloader Cream of the Crop More info | Aug 06, 2008 10:49 | #7 Shoot RAW all the time, even if you don't understand it yet. You won't be sorry and you will eventually understand the benefits. Mitch- ____...^.^...____
X-Warrior Senior Member 590 posts Joined Jul 2007 Location: Netherlands More info | Aug 06, 2008 11:01 | #8 canonloader wrote in post #6057423 A RAW file is Lossless. meaning unlike a jpg, you can open it a million times, copy a new jpg or tiff from it and it always stays as good as the day you shot it. A jpg, loses pixels and data every time you open and save it. You don't want the kids pictures to end up one pixel by one pixel ten years from now do you? Just kidding, but they will look worse over time. Just like film. Only if you overwrite the original JPGs. Obviously, when post processing, you should save the processed image somewhere else. Then the original JPG will be just as fine as before in 10 years. Provided your storage system hasn't failed on you of course... Something wide
Mark_Cohran Cream of the Crop More info | Aug 06, 2008 11:05 | #9 RAW and JPG each have their place - many photojournalists will often shoot JPG. I shoot in RAW 99% of the time because of the reasons mentioned above. Mark
canonloader Cream of the Crop More info | Aug 06, 2008 11:12 | #10 Obviously, when post processing, you should save the processed image somewhere else. Then the original JPG will be just as fine as before in 10 years. There has been so much written about JPG format and not all of it says the same thing. I understand that just the act of say, dragging the jpg from your C/: drive to an external drive, is saving it. Therefor, it loses some quality in the move. Not sure about this one. But I am sure, no one is going to remember every single time, to save as, a copy. Certainly not me, and then there are the program options already set to save open files automatically ever 10 minutes or every edit. Mitch- ____...^.^...____
yogestee "my posts can be a little colourful" More info | Aug 06, 2008 11:17 | #11 Mark_Cohran wrote in post #6057511 RAW and JPG each have their place - many photojournalists will often shoot JPG. I shoot in RAW 99% of the time because of the reasons mentioned above. We only shot in jpeg when I worked for a newspaper for a number of reasons.. Its much quicker to process jpegs especially when you have a hundred or so images to process,, our imaging department ( the guys who did all the heavy post processing) only worked in jpegs.. Jurgen
Mystwalker Senior Member 608 posts Joined Feb 2008 More info | Unless you know exactly what you are doing, start out with JPEG.
doctorgonzo Member 217 posts Joined Jun 2008 Location: Minneapolis, MN More info | Aug 06, 2008 11:30 | #13 canonloader wrote in post #6057547 I understand that just the act of say, dragging the jpg from your C/: drive to an external drive, is saving it. Therefor, it loses some quality in the move. No, this isn't true. Merely copying a JPG from one place to another does not degrade the quality. Canon 40D — Canon EF-S 17-55mm f/2.8 IS USM — Canon EF 28-135mm f/3.5-5.6 IS USM — Canon EF 50mm f/1.8 — Canon Speedlite 430EX II — A long B&H wish list!
canonloader Cream of the Crop More info | Aug 06, 2008 11:44 | #14 The only time a JPG is recompressed is if you open it in a program like Photoshop, make a change to the contents of the file by actually changing the pixels, and then save it. That makes sense to me, but I have followed the jpg format articles for 10 years and you wouldn't believe what some of them claim about the format. Also, different editors use slightly different compressors to create a jpg. I am guessing that might have something to do with them also. But beside the point, a lossless format is not the best to start out with if you want long term storage of your memories, without dgradation over time. Mitch- ____...^.^...____
cdifoto Don't get pissy with me 34,092 posts Likes: 48 Joined Dec 2005 More info | Aug 06, 2008 11:46 | #15 Did you lose Digital Photo Professional (DPP)? Get it here
| Latest registered member was a spammer, and banned as such! 2844 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
