Thread started 06 Aug 2008 (Wednesday) 20:46
Macro Lens Recommendation
thedash71
Aug 06, 2008 20:46 |  #1
Hi,
I'm wanting to move into macro photography but I'm very inexperienced in this field so I'm hoping some of you can recommend a decent macro lens for my Canon 400d. I don't have a budget as such at present, the recommendations will decide how long I have to save up for :)
Thanks,
Jen
x.pozhr
Gallery: 328 photos
Aug 06, 2008 20:59 |  #2
Hi Jen
Take a look at this thread; it may help you. There are several others here.
https://photography-on-the.net/forum/showthre​ad.php?t=160960
Canon 100 2.8 seems to get the highest marks. 60 2.8 isn't bad - it depends on your needs.
Gear List + Marketplace Feedback
x.pozhr
Gallery: 328 photos
Aug 06, 2008 21:09 as a reply to  @ x.pozhr's post |  #3
Ok.., here is another one you may find useful.
https://photography-on-the.net …hread.php?t=548​053&page=2
Oh, and BTW, welcome to POTN..!! :)
nordstern1
Aug 06, 2008 21:15 |  #4
when i was looking for a macro lens, i only considered the 100 & 60 macro. im not a "canon lenses only" snob, its just that macro lenses from 3rd party companies extend when zooming/focusing(? pls correct me if im wrong) except for the Sigma 150 macro. the sigma 150 is nice but a little bit out of my budget.
i really wanted the 100 macro but i ended up with the 60 which im really liking more & more as i use it. i chose it over the 100 because its cheaper, smaller & lighter. the only disadvantage is that (if you consider it to be) its EF-S.
i also like using it as a portrait lens.:)
JOE
G10 | 5D | 40D | 17-55 2.8 IS | 16-35 2.8 L II | 24-70 2.8 L | 70-200 2.8 IS L | 85 1.2 L II | 430EX
manfrotto | tenba | crumpler | clik elite | tamrac | op/tech | blackrapid | sandisk | b+w | marumi | giottos | mac | buffalo
ben_r_
-POTN's Three legged Support-
Aug 06, 2008 23:58 |  #5
Any of the Canon lenses are way good!
thedash71
Aug 07, 2008 09:29 as a reply to  @ ben_r_'s post |  #6
Thanks for the info/links guys, most helpful. Much appreciated.
Jen
yogestee
Aug 07, 2008 11:03 as a reply to  @ thedash71's post |  #7
Tamron AF 90mm f/2.8 Di SP 1:1 Macro
http://www.photozone.d​e …macro-test-report--review (external link)
Jurgen
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Aug 07, 2008 11:28 as a reply to  @ yogestee's post |  #8
I think the Sigma 150 is AWESOME..reason i have one..you can find them selling used for around the same price as the canon 100..Like 450-500
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
macro_shooter
Aug 07, 2008 12:05 |  #9
If you want to spend little money, you can go with a 50mm lens + Kenko extension tubes. Then if you find yourself really into macro, you can get the 100mm macro lens.
http://flickr.com/phot​os/bigflytrap/ (external link)
amfoto1
Aug 07, 2008 16:44 |  #10
Hi,
I'd second the suggestion for extension tubes. The Kenko set or Adorama set are the two best deals for these. You can use tubes with many different lenses, for all sorts of close-up and macro work. Experiment with them.
If you do go with tubes, one thing is important if you ever plan to use them with any EF-S lens... Check that the set you get is EF-S compatible. Some aren't.
There are many macro lens possibilities, and they will work quite well with extension tubes, too, should you ever want more than 1:1 magnification.
For use on any of the crop sensor cameras, I'd suggest lenses in the focal lengths from 60mm to 105mm for most macro shooting.
Shorter macro lenses are useful for copy work - stamps, coins, etc. say - but put you too close to live critters (might scare em, or get bit or stung), and you can cast a shadow on them too easily.
60mm might be a bit short for my tastes, but okay for you. Canon's is great, but it's an EF-S lens, only usable on the digital Rebels and 20/30/40D.
70mm is a bit more like I'd want to use, personally. SIgma's is excellent from all I've heard, but I haven't used it. It is a full frame or crop sensor lens.
90mm is a good length on crop sensor cameras, Tamrons is great... At least older versions I still have are.
100mm is what I use now on my crop sensor cameras. It gives you some distance from your subject. I use Canon's, but everything I hear about Tokina's is very positive as well. Even the inexpensive Phoenix is said to be pretty good.
105mm is very close to the same, and available from Sigma. Also a lens I've heard a lot of good things about.
150mm (Sigma), 180mm (Sigma, Canon, older Tamron) are simply too long to be comfortably used on crop sensor cameras much. These almost require a tripod. I have the Canon and love it, but use it a lot less on my crop sensor cameras. The reason is simple... depth of field is razor thin with these lenses wide open. So, you have to stop them down quite a bit. As a result, you'll need slower shutter speeds. They are already pretty long to try to hand hold, and slower speeds make that even more difficult. So, while they are great lenses and all, I'd still not recommend them for use by someone starting out shooting macro with crop sensor cameras.
Now, yes, the Canon 100/2.8 is an internally focused lens. This means it doesn't change physical length when you focus it. Some of the other lenses mentioned are not internally focused, and they "grow longer" when focusing... In fact significantly longer to achieve full 1:1 magnification.
However, the effect of internal focusing is that the true focal length of the Canon changes as you focus. By the time you reach the closest focus, highest magnification of 1:1, the Canon 100 is effectively a 70mm lens. This fact puts you closer to the subject with the lens. Lenses that aren't internal focus don't change focal length, so you stay farther from your subject.This is not such a big deal with a 100mm IF lens, would be more of a concern to me with a 60mm IF lens (like the Canon EF-S 60/2.8).
I suggest you also look for books about macro shooting. Some by John Shaw and Tim Fitzharris come to mind, in particular. There is lots more to learn, such as special focusing techniques, working with flash, etc.
Have fun!
1,635 views & 0 likes for this thread, 8 members have posted to it.
2910 guests, 138 members online
