Thread started 06 Aug 2008 (Wednesday) 20:58
100-400 Sharper than 300 f4 !!
Diver-Down
Aug 06, 2008 20:58 |  #1
I did some comparison shots today between a 300mm f4 that I just got and a 100-400 and I was surprised to find the 100-400 a bit sharper. Shouldn't it be the other way around ? I don't think it is a focusing issue with the 300 as I tried the battery test as well as a yard stick on an angle and found the focus to be spot on. The shots were off a tripod, with a remote, IS off and the 100-400 was set at 300mm. Any ideas why the 1-4 would be sharper ? Below are some 100% crops, without any processing, to judge.
300 f4 @ f4
100-400
@ 300mm f5.6
300 f4 @ 5.6
100-400
@300mm f8
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Aug 06, 2008 20:59 |  #2
looks like that 300 f4 box is over exposed alot more then the 100-400
My gear
R7, 7D, Canon RF 14-35 f4L, Canon RF 50 1.8 STM, Tamron 70-200 G2, Canon 100-400LII, Canon EF-RF
brianch
Aug 06, 2008 21:03 |  #3
those arent very good shots for comparing. the picture from the 300mm seems to be a bit blurry from hand shake. the second photo from the 300mm is out of focus. and you are comparing a shot that has an aperture for f/5.6 to f/8. the picture from the 300mm @ f/5.6 has shallower DOF. i believe its caused by user error.
Brian C - Alpha Auto Spa (external link)
5D Original
5D Mark II
EOS M
LeeSC
Aug 06, 2008 21:06 as a reply to  @ brianch's post |  #4
Hmmmm..... a lens wide open vs a lens stopped down a bit. Would you expect any different results?
Use both lenses at the f/stop and then you can compare.
GEAR
therock
Aug 06, 2008 21:08 |  #5
Don't leave out f/5.6 vs. f/8.
And sheesh dude! If your out doors, you give give us eye candy subjects not eye cr@pola!
therock @ alcphoto.net (external link)
50D/ EFS 10-22 / 17-55 2.8 IS / EF 50 1.4 / 28-135 Kit Lens / 70-200 2.8 IS / EF 300 f4L IS / EF 1.4x II
Diver-Down
Aug 06, 2008 21:10 as a reply to  @ brianch's post |  #6
No hand shake, camera was on a good tripod. I wanted to compare them both wide open as that is where I use them most, then I tried stopping down 1 full stop. I also have other pictures that show the 1-4 being sharper. Sorry about the squirrel cobs.
CountryBoy
"Tired of Goldmember label"
Aug 06, 2008 21:11 |  #7
LeeSC wrote in post #6060718 (external link)
The 300mm should be a lot sharper then these shots wide open. Something's wrong, user error or a lemon, I don't know
Hi
nicksan
Man I Like to Fart
Aug 06, 2008 21:12 |  #8
Hmmmm...100-400L 300mm @f5.6 = wide open.
Diver-Down
Aug 06, 2008 21:14 |  #9
The first 2 are both wide open.
LeeSC
Aug 06, 2008 21:16 as a reply to  @ Diver-Down's post |  #10
Sorry:oops:
Was looking mainly at the second shots!
GEAR
ed ­ rader
"I am not the final word"
Aug 06, 2008 21:20 as a reply to  @ LeeSC's post |  #11
my 300L was sharper wide open.....but not by much.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
ctrain
1 post
Aug 06, 2008 21:33 |  #12
My 300L f/4 stopped down to f/8. Compare this to the 100-400 at the same stop.
http://www.flickr.com …in/set-72157603259297388/ (external link)
nicksan
Man I Like to Fart
Aug 06, 2008 21:38 |  #13
Nothing shocking at f8.
Here...wide open at 400mm.
IMAGE: http://nicksan.zenfolio.com/img/v1/p118231306-4.jpg
IMAGE: http://nicksan.zenfolio.com/img/v0/p181998641-4.jpg
Sharp enough for you?
ctrain wrote in post #6060892 (external link)
Mike55
Aug 06, 2008 21:38 |  #14
Looks like your 300 is OOF.
6D | 70D | 24-105 L IS | 17-40 L | 300 F4 L IS | 50 1.8 II | 1.4x II | LR5 | HV30 | bug spray | wilderness
Gallatin National Forest, Montana (external link)/Lassen Volcanic NP Campgrounds (external link)
LightRules
Return of the Jedi
Joined Jun 2005
Aug 06, 2008 22:41 as a reply to  @ Mike55's post |  #15
Whether it's user error or the lens itself is off, your two pictures of the 300 L are out of focus.
4,506 views & 0 likes for this thread, 16 members have posted to it.
1332 guests, 137 members online
