Thread started 07 Aug 2008 (Thursday) 14:58
Outdoor Fill Flash
dtufino
Aug 07, 2008 14:58 |  #1
I have the Canon 40D With the 28-135 Kit lens, I have the 430EX and the LumiQuest Bounce Kit.
I have been reading and reading and reading about lighting, on these forums, (thread after thread) but i cannot "comprehend" what i am reading, maybe i'm a retard... but i know alot about my camera but myFlash skills suck.
i wanted to test out the camera today will Outdoor fill Flash. How to iset my camera for outdoor Fill Flash?
With my flash do i point it up< with the Lumiquest Bounce kit? what it bounce from? lol
please point me into the right direction.
-David T.
www.dtufinophoto.com (external link)
@dtufino_photo (external link)
Mike ­ McCusker
Aug 07, 2008 15:17 |  #2
Shoot without any diffuser with flash pointed straight at subject. Use AV or manuel. I would use manuel, get an exposure reading from background shoot and dial in fec as neccessary.
20D with grip, 50D,Canon 50mm 1.8II,Canon 18-55,Canon EF 24-105mm IS, Canon 70-200 2,8L, Canon EFS 17-55mm f/2.8 IS USM, Sigma 10-20mm f/4-5.6, 580EX, 430EX, ST-E2
No one goes through life undefeated!
Haru
Aug 07, 2008 15:22 |  #3
Well seeing as you have no ceiling outside you aren't going to bounce it off anything. Outside is one of those times where direct flash isn't that bad. Just point, shoot, and adjust if they are washed out or underexposed.
Gear: Stone slab, hammer, chiseL, and crushed barries.
dtufino
Aug 07, 2008 15:25 as a reply to  @ Haru's post |  #4
Thanks Man....
here is an image i took outside with the flash directly at the subject yesterday:
HTTP response: NOT FOUND | MIME changed to 'image/png' | Redirected to error image by MYSPACECDN
Definitely Overexposed in the Face, right?
-David T.
shutter_blitz
Aug 07, 2008 15:35 |  #5
There are several solutions this problem:
Use your FEC settings to pull it back a bit
Reduce the flash power setting
Use a sto-fen diffuser
Move back.
All reduce flash light output/reach.
Gear:
Canon 50D
EF 50mm f1.4 USM, EF 70-200mm f/2.8 L IS USM
Sunpak 383
Quantaray QSX-9500
Kittygraphix
Aug 07, 2008 15:39 |  #6
Diffuser is your best bet for this, Lumiquest has a great one! I have the bounce kit too and it works incredible indoors but outdoors it's useless really.
~Kat
Gear: continually growing and changing!!!!
http://kittygraphix.sm​ugmug.com/ (external link) http://www.modelmayhem​.com/749345 (external link) http://myspace.com/kit​tygraphix (external link) ittygraphix@yahoo.com (external link)
Titus213
Aug 07, 2008 17:07 |  #7
Your easiest solution here is to turn the flash down with FEC. Diffusers, bounce cards, etc are just going to do nothing for you in this situation that you can't do free of charge. Assuming the issue is the blown areas on the faces and not the shadows.
You will also quickly discover that despite all it's great ability, ETTL is very easily confused. Lots of bright areas or lots of dark areas will dramatically impact exposure levels.
Dave
Perspiring photographer.
JeffreyG
Gallery: 42 photos
Aug 07, 2008 17:27 |  #8
Kittygraphix wrote in post #6065700 (external link)
But the problem is too much flash power, not harsh shadows. To fix too much power with a diffuser you have to diffuse it to the point that there isn't enough power left....which would be pretty inexact.
Better to simply select negative FEC until those faces stop glowing. I usually use about -1 stop FEC as a starting point for this kind of fill.
prime80
Aug 07, 2008 17:53 |  #9
Looks more like plain overexposure to me. The harsh light is coming from camera right, which is the same direction the sunlight is coming from (look at ALL of the shadows in the scene). If the harsh light was coming from the flash, the shadows would be directly below their chins.
John
R6, EF 100-400 L IS II, EF 24-70 L II, EF 85 f/1.8
Full Gear List
dtufino
Aug 07, 2008 17:58 as a reply to  @ prime80's post |  #10
Here are a few Pics taken after work at home with the LumiQuest Bounce Kit: (using the Silver Slide)
Me
My Lovely Wife Tanya:
My Wife Tanya and Venus
Me with the Gold Slide
Venus!
How are they?
-David T.
Kittygraphix
Aug 07, 2008 18:15 |  #11
MUCH better!!!!!!!!!!!
beautiful pittie btw :D
~Kat
moedizzle
Aug 07, 2008 19:04 as a reply to  @ Kittygraphix's post |  #12
MUCH, MUCH BETTER! Keep at it!
www.ericvargas.net (external link)
Blog (external link)| Facebook (external link)| Gear
dtufino
Aug 07, 2008 19:23 as a reply to  @ moedizzle's post |  #13
Thanks Guys...
-David T.
3,954 views & 0 likes for this thread, 9 members have posted to it.
Outdoor Fill Flash
2713 guests, 154 members online
