Thread started 07 Aug 2008 (Thursday) 18:14
580ex II with my 10-22
tomdlgns
Aug 07, 2008 18:14 |  #1
camera is in M mode
focal length is 22mm (flash showing zoom at 24...i know why, no big deal on that)
aperture 250 (cant go faster with flash on)
flash seems to be in auto mode.
for some reason, my pics dont come out clear when i i'm in M mode on the camera using flash.
in auto...everything seems to look clear and sharp.
none
Haru
Aug 07, 2008 18:17 |  #2
Examples plzkthx, oh and EXIF intact would be a plus.
Gear: Stone slab, hammer, chiseL, and crushed barries.
tomdlgns
Aug 07, 2008 18:21 |  #3
haven't transferred to my PC yet....not at home.
thanks.
none
tomdlgns
Aug 07, 2008 18:27 |  #4
i just took 2 shots of an audio receiver....
first one everything auto- clear and sharp
second one M mode on camera (didnt touch flash settings)
both shots had the flash facing behind me
will upload as soon as i get home...leaving now.
none
tomdlgns
Aug 07, 2008 18:52 |  #5
1201.jpg EXIF (top pic)
f 4.5
1/250
iso 400
18mm
1202.jpg EXIF(bottom pic)
f4.5
1/60
iso400
18mm
none
tomdlgns
Aug 07, 2008 18:56 |  #6
i quickly compressed in mspaint and i am not saying the bottom one is the sharpest picture i have ever seen, but it is much, much better than the top pic.
again, the only difference here was that the blurry pic was in M mode on the camera.
the 10-22 was set to auto for focus.
thanks.
none
tomdlgns
Aug 07, 2008 19:01 |  #7
if i put my lens in manual focus i can use the 580ex and i get sharp pictures....
it seems that when i put the lens in auto and half press the button, i can hear the lens focus and then it stops. when it stops, it is blurry.
gonna try with another lens....hmmmm
none
tomdlgns
Aug 07, 2008 19:12 |  #8
ok, i guess it is not a flash problem, i took off the 580 and it does the same thing in m mode on the camera with the lens on auto.
sorry guys.
however, i had the same issues with all 3 of my lenses.
mods- what would the appropriate forum be if/when the topic gets moved???
none
Golf ­ Nut
Aug 07, 2008 20:01 as a reply to  @ tomdlgns's post |  #9
When in "auto" mode, is that P mode or the green square mode?
In the custom functions, do you have C.FnIV 1 set to 2 or 3?
What focus mode are you in? ONE SHOT, AI FOCUS, or AI SERVO?
40D w/ BG-E2 & RRS L Plate / 17-55 IS / 70-200 f/4L IS / 60 2.8 Macro / 85 1.8 / 580EX (2) / RRS B85-B Flash Bracket / Gitzo GT-2530 Tripod / RRS BH-40 LRII Ballhead
tomdlgns
Aug 08, 2008 08:15 |  #10
Golf Nut wrote in post #6067106 (external link)
auto meaning green box mode.
when i hold the cFn button down i see Fn 00 0
AI servo with all 3 lenses.
but as i stated above, i took the flash off and i had the same issues, so its obviously not a flash problem....
i brought my camera to work, so i can mess around with the settings here if needed.
none
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 08, 2008 08:26 |  #11
tomdlgns wrote in post #6069892 (external link)
Where is the cFn button? Please explain what you mean.
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 08, 2008 08:37 |  #12
Disregard the previous question.
At first, I couldn't figure out what you meant by cFn button. (there is no cFn button on the camera) But then I looked at my 580EX II and saw it.
"Golf Nut" was asking you about the Custom Functions you may have set on your camera., not flash. We are trying to help you figure out why your camera won't focus in manual mode.
Check out cFn IV 1 in your camera. This custom function changes the way the camera Auto Focus operates. You may have accidentally set it so that it won't AF with the shutter button.
tomdlgns
Aug 08, 2008 09:35 |  #13
msowsun wrote in post #6069981 (external link)
gotcha...
well when i half press the shutter button it focuses perfectly sharp (very quick) and then it stops at a blurry position...
i will check the cFn settings on the camera now...thanks for clearing that up for me.
none
msowsun
"approx 8mm"
Gallery: 18 photos
Aug 08, 2008 09:43 |  #14
tomdlgns wrote in post #6070225 (external link)
That doesn't sound good.
There is no point checking the custom functions if the camera is focusing with the shutter button.
You may have a camera problem from what you describe. But sometimes these "problems" turn out to be user error.
It is strange that the lens focuses perfectly sharp and then stops at a blurry position. Watch the focus distance scale on the lens as this happens and see if you can tell what is happening. Does it stop close to the actual distance? or is it way off?
tomdlgns
Aug 08, 2008 09:45 |  #15
ok, i am in the Cfn IV settings, but i dont see where it would be set to 1 or 2...
all i see is
1234567
0000000
that is in the bottom left.
Thanks.
none
1,879 views & 0 likes for this thread, 5 members have posted to it.
2713 guests, 154 members online
