Thread started 07 Aug 2008 (Thursday) 19:00
New 40D user needs flash help
reala65
Aug 07, 2008 19:00 |  #1
Hey folks,
I used previously an SB 800 with my Finepix S2. Now I am using a 40D w/ 580EX II. I was shooting in Av mode and got the attached result (blurred). When shooting indoor shots with movement, should I go to P mode or is there another option to prevent getting such a slow shutter speed? This was not an issue with my Nikon-based equipment. Thanks for any help you can offer!
Mr_J
Aug 07, 2008 19:05 |  #2
I've had people reccommend, and have had some success using shutter priority so that you limit your shutter speed from being too slow. I pretty new to photography and am finding that flag photography is a whole different beast. Try reading up on flash photography so you understand what the camera is doing in the different shooting modes.
Mr_J-http://www.flickr.com/​photos/blackdogphotos/
Canon 40D, Tamron 17-50 f2.8, 50mm f1.8, Canon 70-200 f2.8L, Canon S5IS
Diana+ 120mm
http://www.flickr.com/​photos/blackdogphotos/ (external link)
shybull
Gallery: 178 photos
Joined Jul 2003
Aug 07, 2008 19:18 as a reply to  @ Mr_J's post |  #3
The AV setting uses the flash as a fil flash and will set the eposure for the ambient light. Which can result in slow shutter speeds. It's best to use the manual setting, at maybe ISO 400, 1/125, F4. The flash will expose correctly. That's just a staring point. There is a custom function setting that allows you to always use a shutter speed of 1/250 for AV,
gooble
Aug 07, 2008 19:19 |  #4
When I use flash I put the camera on M (really I use M most of the time anyway).
Start at something like ISO 400, f/4-f/5.6 and meter. Set shutter to underexpose 1 to 1 2/3 stops and let the flash do the rest. Add some FEC if needed.
The problem with your shot is that you had too much ambient light so you had a fairly bright ambient exposure and the flash exposure. By underexposing the ambient you won't get ghosting.
Hermeto
Aug 07, 2008 20:24 as a reply to  @ gooble's post |  #5
With 1/3” , hand hold in Av mode, you cannot expect to get the shot any better than this one.
Set camera to: Manual, f/5.6, 1/125”, ISO 200
Set flash to: ETTL, bounced at 45°-75°.
Adjust f-number and/or shutter speed to change lighting of the background.
Adjust FEC and/or bouncing angle to change lighting of the subject.
Show us the shot.
number ­ six
fully entitled to be jealous
Aug 07, 2008 20:29 |  #6
As shybull said, Av mode normally chooses a shutter speed that will expose correctly under ambient light and then the flash fires to fill in the shadows.
Your shot, at a focal length of 115 mm, was taken at a shutter speed of 1/3 second. That's guaranteed to be blurry.
The answer? Don't use Av for flash unless fill flash is what you want.
You could use Tv at a higher shutter speed, up to 1/250. The higher your shutter speed, the less illumination you'll see from ambient light. At 1/250 all the light will be from the flash.
For most flash use, M is the best choice. If you want flash illumination only, choose 1/250 and f/8 or so. If you want some fill, use a slower shutter speed and larger aperture.
The flash exposure will be correct no matter what aperture and shutter speed you select (within reason) because the 580EX will adjust its output automatically.
-js
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
JeffreyG
Gallery: 42 photos
Aug 07, 2008 20:33 |  #7
Do Nikons work differently in aperture priority mode? How does one shoot fill flash with a Nikon if you want the camera to auto meter the ambient? So many people ask this question (Canon, Av and slow shutter speeds with flash on) that I start to wonder if other cameras do this differently or what?
Sorry if this is off topic but the last Nikon SLR I used was manual everything.
syntrix
Aug 07, 2008 20:40 as a reply to  @ number six's post |  #8
Yup, I shoot manual all the time with flash.
moew!!!!!
reala65
Aug 07, 2008 23:33 as a reply to  @ syntrix's post |  #9
Thanks for the comments everyone, I really appreciate it! It's nice to post to a board where everyone is genuinely helpful.
Hermeto
Aug 07, 2008 23:35 |  #10
Welcome to POTN, my friend!
JCH77Yanks
Gallery: 28 photos
Aug 08, 2008 03:21 |  #11
You should also consider bouncing your flash off of a wall or ceiling. Welcome to the forums!
Joe Halliday
7D | XT | 10-22 | 24-105 f/4L | 28 1.8 | 50 1.4 | 85 1.8 | 580EXII | 430EXII | 430EX | Flickr (external link)| 500px (external link) |
Dial "M" for Manual.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 08, 2008 10:22 as a reply to  @ JCH77Yanks's post |  #12
I agree on using M for flash is the best. You can make the exposure time as long or short as you want, but you have control of what you get.
Setting Av to always give 1/250 s when using a flash is rather pointless. Could just as well use M then, and leave Av for the moments when you do want fill flash. That works well outdoors, for example.
Setting the camera to P will save you from most of these issues, as it will select "safe" values.
Anders
magicman320
Aug 09, 2008 11:17 |  #13
JeffreyG wrote in post #6067272 (external link)
The answer is yes. Nikon works extremely well in Aperture Priority. I did a wedding and i was using canon 40D and the other two shooters had D300's. They shot aperture priority most of he night when i couldnt. I had to shoot manual.
5DM2, 24-105L, 580EXII, Nifty Fifty...and building.
JeffreyG
Gallery: 42 photos
Aug 09, 2008 11:23 |  #14
magicman320 wrote in post #6076369 (external link)
But what does it do for fill then? Or did they simply have a function enabled to drive the shutter speed to the maximum synch?
This is a Canon function BTW. If you want to shoot in AV mode with the flash on for some reason there is a custom function that will hold the shutter speed at the maximum synch speed.
I personally don't see the point, as this isn't really Av mode anymore....just kind of M with only 1 shutter speed allowed.
silvex
Gallery: 21 photos
Aug 09, 2008 11:38 |  #15
I did my first flash gig using P mode ISO 100 while adjusting the FEC. Also make sure you at least have a fast lens (f2.8+). You can also try 1/60 f/4 iso 200, which is the speed the P mode uses most of the time. Try chimping around at nite and you will see how much fun the 580EXII can be.
I would also advise you to read the 580EXII manual a couple of times and do use re-chargeable batteries. I use duracell 2650 and they last for a good 700+ flashes. Always carry at least 4 extra batteries.
I did read however :) these great set of links found here.
https://photography-on-the.net/forum/showthre​ad.php?t=138907
Welcome to POTN.
-Ed
CPS Platinum Member.
Canon Gear
SilvexPhoto.comexternal link
4,226 views & 0 likes for this thread, 16 members have posted to it.
2730 guests, 149 members online
