Messing around wtih DOF. I am working on technique. What can I do to get this sharper or better overall. Thanks.
slimninj4 Goldmember 1,151 posts Likes: 7 Joined Jun 2007 More info | Aug 08, 2008 12:21 | #1 Messing around wtih DOF. I am working on technique. What can I do to get this sharper or better overall. Thanks. Canon 40D 5Dm3 || 24-70 L 70-200 2.8 IS2 100mm Macro 50mm 1.8 35 1.4
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | Aug 08, 2008 13:17 | #2 Needs greater DOF. Stop down your lens at least 2 stops to see it broaden the depth. Bob
ibdb TD's worst nightmare! 6,484 posts Likes: 7 Joined Jan 2006 Location: Puyallup -- Don't worry. Nobody else can pronounce it either. More info | slimninj4 wrote in post #6071003 Messing around wtih DOF. I am working on technique. What can I do to get this sharper or better overall. Thanks. Have you taken a look at any depth of field calculators? There's one at DOFmaster.com, and there's another in the form of an Excel spreadsheet that one of the members here has put together. A Google search will give you lots of options. You can use them as a guide for setting up shots like this. As you learn, you'll have a better grasp without needing to use one. -David
| Latest registered member is semonsters 891 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
